Audio cuts out when using application audio capture
MeTaLRAW
The sound is interrupted for about 3 seconds when capturing different applications, I tried to use different versions of OBS up to 28.0 but the problem is the same, but if you capture sound from the desktop, everything is fine, the sound is also fixed if you use the win-capture-audio plugin, the sample rate is not the same it helps, the exclusive mode in windows turned off also does not help, maybe someone faced such a problem?
