Just a heads up - it starts to look like this card is not capable of 60FPS period. but there are a few things to consoder and test still:
me and another user that owns the same card (990fx chipset) have been experimenting with it extensively over a few days/nights,
and for me atleast there is no solution at all to get rid of the stutters, but his results have been somewhat better than mine altho not perfect.
have tested it both in the X99, and AMD FX (970a) systems, with and without overclocks, with GTX650 or GTX780 in the encoding machines
tried every possible pci-e slot from the lowest ones up to the top slot on x99 that's pci-e 3.0 x16 (the card of course links as x1 according to bios) - only time there were issues was when the gpu in encoding machine was linked as x1
have tried obs, obs multi, xsplit, wirecast, mishira, vmix, amarec ... maybe smth else i dont quite remember,
multiple versions of drivers, amarec stutters as well and sometimes even freezes .. atleast on the x99... so its unusable
have tried limiting the card to max 1536x864p custom resolution input through the driver settings and using that as canvas... no change
for me the best result is to put 70fps (or jsut something above 60) in the device settings, -OBS (not driver) panel.
then the small random stutters turn into longer but more rare ones, making the card run perfectly smooth for up to a few minutes at a time until the stutter come,
have tried inputting more HZ into the card, handles 80ish no problem but (can get visual errors when going towards 90 etc.) - its doesnt change a thing it seems ( a 70 70 combo seems to get rid of major stutters by replacing it with a constant sort of "wave" of non-fluidness...
(also the previously mentioned audio desync only happens if i restart the source machine or reinstall nvidia driver mid-stream stuff like that ... works great otherwise)
NOW:
on dec 8 micomsoft site was updated with the 160.5 driver
http://www.micomsoft.co.jp/sc-512n1_download.htm
if you google translate the changelog there is something interesting in there:
"When intel Corporation X99, X79, P67 used by connecting to a computer or motherboard that was equipped with a chip set, or the operation is unstable, it may not work properly. Therefore, intel company X99, X79, operation guarantee of P67 in equipped with a personal computer or motherboard will not do. • If the AMD's CPU (FX type of CPU) used by connecting to the equipped with a personal computer or motherboard, or operation is unstable, it may not work properly. Operation guarantee of these CPU in equipped with a personal computer or motherboard I can not do."
-that sounds scary since i have a x99 and a AMD FX 970a chipset system and both act identically....
any thoughts?
