OBS Studio comes with encoder presets to make recording videos in high-quality simple.
| Preset | Information |
Same as stream |
This preset uses the same settings as the streaming video encoder. This lets you record exactly the same quality as your stream. Note: recordings cannot be paused if the recording quality is set to "Same as stream". |
High Quality |
This preset produces a high quality video with a medium file size. |
Indistinguishable |
This preset provides a higher quality video at the cost of larger file sizes and a potential performance impact on older or weaker hardware, depending on the choice of encoder. |
Lossless |
This preset produces tremendously large file sizes, around 7 GB of data per minute of video, in lossless quality. This also uses the CPU encoder. |
