XRGB input -> low FPS
WoW.Rambler
I am having an issue with OBS and frame grabber in XRGB mode.
The encoding machine has an industrial tier frame grabber (AverMedia CL511HN) and RTX 3060Ti as the NVENC encoder. NV12 and YUY2 color formats set as source give smooth 60 FPS on recordings. When I set XRGB the preview lags and frame rate goes drastically down.
I have tried XSplit which - to my surprise - worked well. It lists more color formats: RGB24 and RGB32. RGB24 works perfectly smooth. RGB32 is reported as 48 FPS on preview.
So it comes to a question - what is wrong with OBS not showing RGB24 mode?
There is a "bonus issue" with colors (see attached image) - OBS has them washed out in comparison to XSplit. It seems it is not connected to full/partial (neither on the frame grabber nor recording settings).
  • 2021-01-30 16-53-35.txt
