Wito Nightmare
I saw something weird, when i was streaming today, when my cam is on, frames in obs are unstable, but when i turn it off everything is ok.
Cam: Microsoft Lifecam HD-3000
Log file:
Log file:
17:48:21: Multithreaded optimizations: On
17:48:21: Base resolution: 1920x1080
17:48:21: Output resolution: 1280x720
17:48:21: ------------------------------------------
17:48:21: Loading up D3D10 on NVIDIA GeForce GTX 660...
17:48:21: Playback device {0.0.0.00000000}.{58b75c64-54bf-4089-8a49-a09e4020eb1d}
17:48:21: Using desktop audio input: Głośniki (Urządzenie zgodne ze standardem High Definition Audio)
17:48:21: Using auxilary audio input: Mikrofon (4 — Samson GoMic)
17:48:21: Audio Encoding: AAC
17:48:21: bitrate: 160
17:48:21: device: Microsoft LifeCam HD-3000,
17:48:21: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
17:48:21: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
17:48:21: audio device: Wyłącz,
17:48:21: audio device id Disabled,
17:48:21:
17:48:21: Using directshow input
17:48:21: Using Window Capture
17:48:21: Video Encoding: x264
17:48:21: fps: 60
17:48:21: width: 1280, height: 720
17:48:21: preset: veryfast
17:48:21: CBR: yes
17:48:21: CFR: yes
17:48:21: max bitrate: 2000
17:48:21: MMDeviceAudioSource: Frequency for device 'Głośniki (Urządzenie zgodne ze standardem High Definition Audio)' is 1536000, samples per sec is 192000
17:48:21: MMDeviceAudioSource: Frequency for device 'Mikrofon (4 — Samson GoMic)' is 176400, samples per sec is 44100
17:48:21: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
17:48:23: Using RTMP service: Twitch / Justin.tv
17:48:23: Server selection: rtmp://live-ams.justin.tv/app
17:48:23: Interface: Kontroler Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
17:48:24: SO_SNDBUF was at 65536
17:48:24: SO_SNDBUF is now 65536
17:48:51: Total frames rendered: 1698, number of late frames: 249 (14.66%) (it's okay for some frames to be late)
17:48:51: Total duplicated frames to ensure constant framerate: 99 (5.83%)
17:48:52: RTMPPublisher::SocketLoop: Graceful loop exit
17:48:52: Number of times waited to send: 0, Waited for a total of 0 bytes
17:48:52: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:48:52:
17:48:52: Profiler results:
17:48:52:
17:48:52: ==============================================================
17:48:52: frame - [100%] [avg time: 9.048 ms (cpu time: avg 4.299 ms, total 7300.85 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0774%]
17:48:52: | frame preprocessing and rendering - [44.1%] [avg time: 3.993 ms (cpu time: avg 2.453 ms, total 4165.23 ms)] [avg calls per frame: 1] [children: 23.6%] [unaccounted: 20.5%]
17:48:52: | | scene->Preprocess - [23.6%] [avg time: 2.138 ms (cpu time: avg 0.946 ms, total 1606.81 ms)] [avg calls per frame: 1]
17:48:52: | video encoding and uploading - [55.8%] [avg time: 5.048 ms (cpu time: avg 1.846 ms, total 3135.62 ms)] [avg calls per frame: 1] [children: 28.4%] [unaccounted: 27.4%]
17:48:52: | | flush - [2.29%] [avg time: 0.207 ms (cpu time: avg 0.128 ms, total 218.401 ms)] [avg calls per frame: 1]
17:48:52: | | CopyResource - [0.409%] [avg time: 0.037 ms (cpu time: avg 0.036 ms, total 62.4 ms)] [avg calls per frame: 0]
17:48:52: | | conversion to 4:2:0 - [1.61%] [avg time: 0.146 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
17:48:52: | | call to encoder - [23.8%] [avg time: 2.149 ms (cpu time: avg 1.662 ms, total 2823.62 ms)] [avg calls per frame: 1]
17:48:52: | | sending stuff out - [0.309%] [avg time: 0.028 ms (cpu time: avg 0.009 ms, total 15.6 ms)] [avg calls per frame: 1]
17:48:52: | Convert444Threads - [376%] [avg time: 33.994 ms (cpu time: avg 1.708 ms, total 2901.62 ms)] [avg calls per frame: 1]
17:48:52:
17:48:52: =====Stream End: 2013-08-18, 17:48:52=================================================
17:48:55: Using fixed low latency mode, factor 20
17:48:55: =====Stream Start: 2013-08-18, 17:48:55===============================================
17:48:55: Multithreaded optimizations: On
17:48:55: Base resolution: 1920x1080
17:48:55: Output resolution: 1280x720
17:48:55: ------------------------------------------
17:48:55: Loading up D3D10 on NVIDIA GeForce GTX 660...
17:48:55: Playback device {0.0.0.00000000}.{58b75c64-54bf-4089-8a49-a09e4020eb1d}
17:48:55: Using desktop audio input: Głośniki (Urządzenie zgodne ze standardem High Definition Audio)
17:48:55: Using auxilary audio input: Mikrofon (4 — Samson GoMic)
17:48:55: Audio Encoding: MP3
17:48:55: bitrate: 160
17:48:55: device: Microsoft LifeCam HD-3000,
17:48:55: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
17:48:55: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
17:48:55: audio device: Wyłącz,
17:48:55: audio device id Disabled,
17:48:55:
17:48:55: Using directshow input
17:48:55: Using Window Capture
17:48:56: ------------------------------------------
17:48:56: Video Encoding: x264
17:48:56: fps: 60
17:48:56: width: 1280, height: 720
17:48:56: preset: veryfast
17:48:56: CBR: yes
17:48:56: CFR: yes
17:48:56: max bitrate: 2000
17:48:56: MMDeviceAudioSource: Frequency for device 'Głośniki (Urządzenie zgodne ze standardem High Definition Audio)' is 1536000, samples per sec is 192000
17:48:56: MMDeviceAudioSource: Frequency for device 'Mikrofon (4 — Samson GoMic)' is 176400, samples per sec is 44100
17:48:57: Using RTMP service: Twitch / Justin.tv
17:48:57: Server selection: rtmp://live-ams.justin.tv/app
17:48:57: Interface: Kontroler Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
17:48:58: SO_SNDBUF was at 65536
17:48:58: SO_SNDBUF is now 65536
18:09:28: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 276480)
18:13:30: Using Monitor Capture
18:13:32: ------------------------------------------
18:13:32: device: Microsoft LifeCam HD-3000,
18:13:32: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
18:13:32: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
18:13:32: audio device: Wyłącz,
18:13:32: audio device id Disabled,
18:13:32:
18:13:32: Using directshow input
18:19:40: Using Monitor Capture
18:21:26: Using Monitor Capture
18:40:07: Using Monitor Capture
18:40:08: Using Window Capture
18:42:01: Using Monitor Capture
19:55:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
19:55:13: New Scene
19:55:13: Using bitmap image
19:55:13: ------------------------------------------
19:55:13: device: Microsoft LifeCam HD-3000,
19:55:13: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
19:55:13: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
19:55:13: audio device: Wyłącz,
19:55:13: audio device id Disabled,
19:55:13:
19:55:13: Using directshow input
19:55:13: Using Window Capture
19:55:13: PERFORMANCE WARNING: Scene change took 649 ms, maybe some sources should be global sources?
20:14:01: ------------------------------------------
20:14:01: device: Microsoft LifeCam HD-3000,
20:14:01: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:14:01: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:14:01: audio device: Wyłącz,
20:14:01: audio device id Disabled,
20:14:01:
20:14:01: Using directshow input
20:14:40: ------------------------------------------
20:14:40: device: Microsoft LifeCam HD-3000,
20:14:40: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:14:40: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:14:40: audio device: Wyłącz,
20:14:40: audio device id Disabled,
20:14:40:
20:20:59: ------------------------------------------
20:20:59: device: Microsoft LifeCam HD-3000,
20:20:59: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:20:59: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:20:59: audio device: Wyłącz,
20:20:59: audio device id Disabled,
20:20:59:
20:20:59: Using directshow input
20:36:28: ------------------------------------------
20:36:28: device: Microsoft LifeCam HD-3000,
20:36:28: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:36:28: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:36:28: audio device: Wyłącz,
20:36:28: audio device id Disabled,
20:36:28:
20:36:28: Using directshow input
20:36:58: ------------------------------------------
20:36:58: device: Microsoft LifeCam HD-3000,
20:36:58: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:36:58: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:36:58: audio device: Wyłącz,
20:36:58: audio device id Disabled,
20:36:58:
20:36:58: Using directshow input
20:42:03: ------------------------------------------
20:42:03: device: Microsoft LifeCam HD-3000,
20:42:03: device id \\?\usb#vid_045e&pid_0779&mi_00#6&1f559d7b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:42:03: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666, fourCC: 'YUY2'
20:42:03: audio device: Wyłącz,
20:42:03: audio device id Disabled,
20:42:03:
20:42:03: Using directshow input
20:42:18: Total frames rendered: 544898, number of late frames: 77584 (14.24%) (it's okay for some frames to be late)
20:42:18: Total duplicated frames to ensure constant framerate: 95464 (17.52%)
20:42:18: RTMPPublisher::SocketLoop: Graceful loop exit
20:42:19: Number of times waited to send: 8, Waited for a total of 30635 bytes
20:42:19: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:42:19:
20:42:19: Profiler results:
20:42:19:
20:42:19: ==============================================================
20:42:19: frame - [100%] [avg time: 9.411 ms (cpu time: avg 3.889 ms, total 2.11943e+006 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.117%]
20:42:19: | frame preprocessing and rendering - [37.1%] [avg time: 3.491 ms (cpu time: avg 1.925 ms, total 1.04937e+006 ms)] [avg calls per frame: 1] [children: 17.1%] [unaccounted: 20%]
20:42:19: | | scene->Preprocess - [17.1%] [avg time: 1.611 ms (cpu time: avg 0.708 ms, total 386103 ms)] [avg calls per frame: 1]
20:42:19: | video encoding and uploading - [62.8%] [avg time: 5.909 ms (cpu time: avg 1.961 ms, total 1.06865e+006 ms)] [avg calls per frame: 1] [children: 58.5%] [unaccounted: 4.27%]
20:42:19: | | flush - [4.61%] [avg time: 0.434 ms (cpu time: avg 0.09 ms, total 49280.7 ms)] [avg calls per frame: 1]
20:42:19: | | CopyResource - [1.24%] [avg time: 0.117 ms (cpu time: avg 0.017 ms, total 9687.66 ms)] [avg calls per frame: 0]
20:42:19: | | conversion to 4:2:0 - [0.871%] [avg time: 0.082 ms (cpu time: avg 0.005 ms, total 3182.42 ms)] [avg calls per frame: 0]
20:42:19: | | call to encoder - [51.4%] [avg time: 4.84 ms (cpu time: avg 1.805 ms, total 983789 ms)] [avg calls per frame: 1]
20:42:19: | | sending stuff out - [0.361%] [avg time: 0.034 ms (cpu time: avg 0.017 ms, total 9750.05 ms)] [avg calls per frame: 1]
20:42:19: | Convert444Threads - [406%] [avg time: 38.176 ms (cpu time: avg 1.602 ms, total 873278 ms)] [avg calls per frame: 1]
20:42:19:
20:42:19: =====Stream End: 2013-08-18, 20:42:19=================================================
