Hey every time i stream I get a good 5 minutes in to it then I hear a DING! Then it pauses my game and says it has to reload. This has been going on since I got it. Its really bugging me if you know please comment down below. I also know its not my internet i Had the techs come to see if it was good and they said every thing was normal they just said must be the program.
My Log is Here and computers specs
23:54:04: CLR host plugin strings not found, dynamically loading 4 strings
23:54:04: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
23:54:04: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
23:54:04: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
23:54:04: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
23:54:04: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
23:54:04: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
23:54:05: CLRHost:: Could not find/load browser settings at location C:\Users\Aidan22\AppData\Roaming\OBS\pluginData\browser.json
23:54:05: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
23:54:12: Open Broadcaster Software v0.625b - 32bit (´・ω・`)
23:54:12: -------------------------------
23:54:12: CPU Name: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
23:54:12: CPU Speed: 3200MHz
23:54:12: Physical Memory: 4095MB Total, 4095MB Free
23:54:12: stepping id: 5, model 26, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
23:54:12: monitor 1: pos={0, 0}, size={1920, 1080}
23:54:12: Windows Version: 6.1 Build 7601 S
23:54:12: Aero is Enabled
23:54:12: OBS Modules:
23:54:12: Base Address Module
23:54:12: 013D0000 OBS.exe
23:54:12: 5FAC0000 OBSApi.dll
23:54:12: 602A0000 CLRHostPlugin.dll
23:54:12: 5E290000 DShowPlugin.dll
23:54:12: 5F720000 GraphicsCapture.dll
23:54:12: 5F750000 NoiseGate.dll
23:54:12: 60900000 PSVPlugin.dll
23:54:12: ------------------------------------------
23:54:12: Adapter 1
23:54:12: Video Adapter: AMD Radeon HD 6800 Series
23:54:12: Video Adapter Dedicated Video Memory: 1053077504
23:54:12: Video Adapter Shared System Memory: 3241824256
Specs
DellStudio XPS 9100
12.0 RAM
64BIT
23:54:12: Adapter 1
Specs
DellStudio XPS 9100
12.0 RAM
64BIT
