Hello,
I use OBS every week with no problem but tonight after the windows update (I know bad idea), I only have a blank screen when I open OBS.
Here's the log
00:44:57.326: CPU Name: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
00:44:57.326: CPU Speed: 2304MHz
00:44:57.326: Physical Cores: 4, Logical Cores: 4
00:44:57.326: Physical Memory: 16265MB Total, 11451MB Free
00:44:57.326: Windows Version: 10.0 Build 17134 (revision: 48; 64-bit)
00:44:57.326: Running as administrator: false
00:44:57.326: Aero is Enabled (Aero is always on for windows 8 and above)
00:44:57.326: Windows 10 Gaming Features:
00:44:57.326: Game DVR: On
00:44:57.327: Sec. Software Status:
00:44:57.328: Antivirus Windows Defender: enabled (AV)
00:44:57.329: Pare-feu Windows: enabled (FW)
00:44:57.329: Antivirus Windows Defender: enabled (ASW)
00:44:57.329: Portable mode: false
00:44:57.436: OBS 21.1.2 (64bit, windows)
00:44:57.436: ---------------------------------
00:44:57.437: ---------------------------------
00:44:57.437: audio settings reset:
00:44:57.437: samples per sec: 44100
00:44:57.437: speakers: 2
00:44:57.438: ---------------------------------
00:44:57.438: Initializing D3D11...
00:44:57.438: Available Video Adapters:
00:44:57.443: Adapter 1: NVIDIA GeForce GTX 980M
00:44:57.443: Dedicated VRAM: 4250337280
00:44:57.443: Shared VRAM: 4233052160
00:44:57.443: output 1: pos={0, 0}, size={1920, 1080}, attached=true
00:44:57.443: Adapter 2: Intel(R) HD Graphics 530
00:44:57.443: Dedicated VRAM: 134217728
00:44:57.449: Loading up D3D11 on adapter NVIDIA GeForce GTX 980M (0)
00:44:57.918: D3D11 loaded successfully, feature level used: 45056
00:44:58.727: ---------------------------------
00:44:58.727: video settings reset:
00:44:58.727: base resolution: 1920x1080
00:44:58.727: output resolution: 1920x1080
00:44:58.727: downscale filter: Bicubic
00:44:58.727: fps: 30/1
00:44:58.727: format: NV12
00:44:58.727: YUV mode: 601/Partial
00:44:58.729: Audio monitoring device:
00:44:58.729: name: Par défaut
00:44:58.729: id: default
00:44:58.729: ---------------------------------
00:44:58.730: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
00:44:58.737: [CoreAudio encoder]: Adding CoreAudio AAC encoder
00:44:58.764: [AMF] AMF Test failed due to one or more errors.
00:44:58.764: Failed to initialize module 'enc-amf.dll'
00:44:58.775: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
00:44:58.776: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': (null) (127)
00:44:58.776: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
00:44:58.776: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
00:44:58.777: [browser_source: 'Version: 1.31.0']
00:44:58.781: NVENC supported
00:44:58.841: Couldn't find VLC installation, VLC video source disabled
00:44:58.850: No blackmagic support
00:44:58.854: ---------------------------------
00:44:58.854: Loaded Modules:
00:44:58.854: win-wasapi.dll
00:44:58.854: win-mf.dll
00:44:58.854: win-dshow.dll
00:44:58.854: win-decklink.dll
00:44:58.854: win-capture.dll
00:44:58.854: vlc-video.dll
00:44:58.854: text-freetype2.dll
00:44:58.854: rtmp-services.dll
00:44:58.854: obs-x264.dll
00:44:58.854: obs-vst.dll
00:44:58.854: obs-transitions.dll
00:44:58.854: obs-text.dll
00:44:58.854: obs-qsv11.dll
00:44:58.854: obs-outputs.dll
00:44:58.854: obs-filters.dll
00:44:58.854: obs-ffmpeg.dll
00:44:58.854: obs-browser.dll
00:44:58.854: image-source.dll
00:44:58.854: frontend-tools.dll
00:44:58.854: enc-amf.dll
00:44:58.854: coreaudio-encoder.dll
00:44:58.854: ==== Startup complete ===============================================
If someone can help me... Thank you
Here's the log
