Question / Help What is my best settings ? Please help !
Durumadam
i have 2700x 1660ti 16gb ram 7mb upload what should be my bitrate encoder preset resolution bla bla and my best server vienna 84 quality i play high motion games like cod warzone thank you for helping
For that CPU/GPU combination, try this:
  1. Output resolution 900p (1600x900) Twitch); 720p (1280x720) YouTube
  2. Downscale Lanczos
  3. 60FPS
  4. NVENC new
  5. CBR
  6. 4000-6000 bitrate
  7. Keyframes 2
  8. Quality
  9. High
  10. Pyscho visual tuning enabled
  11. Max B-frames 2
Don't push your bitrate more than 6000 (6Mbps) as you only have 7Mbps. You need some room for error in case your connection takes a dump (15-20%). Make sure you download the latest Nvidia drivers and keep them updated via GeForce Experience too.
Have fun.
  3. 60FPS
  4. NVENC new
  5. CBR
  7. Keyframes 2
  8. Quality
  9. High
  11. Max B-frames 2
Have fun.
are you sure about for nvenc ? i think i have great processor and my upload not great i think will be great x264 ? for warzone or big games like battlefield ?
What do you need help with? Did you try the settings proposed? What issues did you encounter?
I haven't tried the recommended settings, but not better for x264 graphics quality, I just want to get the best image quality I can get without fps problem, the best image I can get is with the above settings, but I don't think
sorry my englist i just wanna best image quality settings for my pc and my internet have no issue fps problem ping etc
A Ryzen 2700X coupled with a 1660Ti is a good balanced setup. Don't fool yourself into thinking it is the most powerful system out there. It is not. It is an above average gaming system compared to todays 3rd gen Ryzen and i9/i10 systems today.
Now what I am going to offer you is experience using that exact CPU as I own one. Last year, I used a Ryzen 2700X and GTX 1070 in a single PC gaming/streaming setup. The results were good and were capable of producing 1080p@144FPS at x264 medium preset with the first person shooter games I played. It is still a very good gaming/streaming setup to use for single PC streaming/gaming setups.
I no longer use that setup and have replaced it with a dual PC streaming configuration. Why? Because what you will eventually find is that the CPU load along with x264 and all the other services and applications that you run will be close to 80% CPU utilization. In my case, I didn't care for that level of utilization and wanted high 200FPS in the games I was playing.
So I split the CPU load across two PCs. Now, I have 25-30% CPU utilization on the Ryzen 2700X dedicated x264 box, and 35-50% playing games on an i9-9900K. NVENC new wasn't available back then.
In your case, you are eventually going to find out that you will reach heavy CPU utilization as you play demanding games along with trying to do x264 encoding. This is the reason why I suggest that you reduce resolution to 900p, set a decent bitrate up to 5Mbps, and use NVENC.
That's all I am going to say of this. So please, do not contact me any further. You got what I had to offer.
Have fun.
