AfterglowAmpharos
Hi! I use VLC Video Source to play music in streams. Specifically, it pulls from a playlist directory. This has worked fine for several streams but recently my viewers have complained that they can hear the music playing twice simultaneously. I tested it with recordings, and sure enough, two instances of the songs overlapped, one delayed.
See, when I play any song, this happens.
VLC Video Source is playing audio, and that audio comes through my main desktop audio, which goes to headphones or speakers. That's why you can see the top bar going green, and also why I as the streamer can hear it. But unfortunately, that also means my viewers hear both at once.
Removing Desktop Audio to Headphones isn't an option because that's the way my viewers hear games, alerts, and anything else happening on my PC.
I can remove VLC's music showing up in Desktop Audio to Headphones by switching VLC Video Source to Monitor Off, but then I as the streamer can't hear it, and that's A) not good and B) not how most streamers operate, they can usually hear the music too.
How can I get VLC Video Source to play in my headphones without it playing double for the audience? To put it another way, how can I listen in on VLC Video Source without it lighting up Desktop Audio green in the audio mixer?
I considered the clunky solution of switching VLC Video Source to Monitor Only (mute output), but that moves the music audio onto the Desktop Audio in the Audio Mixer, instead of having it in its own dedicated source. That doesn't seem ideal, so there's probably something simple I'm overlooking, since I'm probably not the first person to use this source to play music/video that I also want to hear.
Obligatory log file https://obsproject.com/logs/s1NEpV2zWzUTgYE5
And yes, I know I'm not on the newest OBS, I had to roll back to fix other issues I was having.
