Question / Help Virtual Audio Cable issues
Calusifa
Hey!
I'm aware this problem isn't directly linked to OBS, but I thought many of you are possibly using software such as VAC or something similar to it.
2 days ago I got VAC installed and working correctly so I could stream from OBS to Twitch. I use VAC to be able to have a Skype call going with my friend without the stream picking it up. Everything was working fine until today and after 5 hours we have yet to figure out the issue. I'm not very good at these things, but I'll try and explain it as best I can.
I've got the Virtual Line 1 set as default in Playback Devices and in Recording Devices I set Line 1 to Listen to through my Headset. I hear Skype fine through the headset.
Since this morning I have been able to get no sound from Line 1, only if I put my headset back as being the default. I see OBS picking up the sound, but I cannot hear it as I should. I also tried installing VB Cable and using that, but the issue remains the same. I tried connecting a different headset which also works fine as default, but if I try and listen through Line 1, I hear nothing.
I hope this explains it and you have a few ideas.
