Can you record that noise? Different problems have different sounds.Hi AaronD, im having the same problem again, everything is fine until a audio noise suddenly appears and disappears, after that the dis-match problem appears again..... and i got the log file uploaded....!
For the log files:
13-39-27 looks normal with only 21ms of buffering, but it has this at the end, as you shut down with the stream still running:
14:23:19.763: fill_buffer: AudioQueueEnqueueBuffer failed: -66632
14:23:19.763: fill_buffer: Failed to enqueue buffer
14-23-22 still has one "failed" message at the end, instead of three, but it also has 341ms of buffering! You're definitely going to notice that! And it's right at the top too, as part of the startup. Still just the one message though, and no other error messages around it, so I really don't know what's going on there.
You might also run your logs through the automated analyzer, and see what it comes up with:
Analyzer | OBS
OBS (Open Broadcaster Software) is free and open source software for video recording and live streaming. Stream to Twitch, YouTube and many other providers or record your own videos with high quality H264 / AAC encoding.
