Hello all at first thank you for your help,
My stream makes very shrill noises online with which you can't stand a minute. I'm new to the platform and I don't know myself well yet, but I think it has to be on the microphone because when I remove the mic it's gone. The headset works flawlessly I used it only a few days ago. With the table microphone that is integrated into my webcam comes the same shrill sound and the device is only one day old, I think it must be down to the settings. When I start a normal recording, the sound sounds normal (video).
In the attach you can see my currently Settings.
Thanks a lot
Thanks a lot
