travissickle
I can't figure out what else I can do here. If I import the file into premiere pro, the video preview doesn't show at all. If I save the premiere pro file and re-open it then it will work. I tried like 15 times with the same results. Premiere pro is showing it as a Variable Frame Rate file which I don't know where to control this setting in OBS. I also tried to remove and reinstall OBS.
At the same time, I'm trying to figure out why my videos are a bit laggy. I'm recording only, not streaming. Dropping the bitrate or raising it seems to have zero effect.
I'm recording with a sony a6400 to a camlink. I'm wondering too if 30 vs 29.97 FPS is an issue?
