Question / Help VAC virtual audio cable hiss static buzz noise when streaming
EvilOverlord
Looking some help with VAC Virtual audio cable producing a static noise
I'm using Microphone AT2020USB. The reason I need VAC is I use Adobe Audition to do some audio clean
up, filters and changes
Tried using different audio program same issue. If I don’t use VAC there is no static noise,
I’ve gone online trying to find a solution and have tried changing
various setting buffering and options Tried changing to VB audio virtual cable
Still has static
I’ve uploaded a video to youtube showing the difference in sound with
VAC and without Vac as well as my various setting on VAC and OBS and Adobe Audition Here a video example
It not quite as loud in this video as when i stream but its still noticeable in the video
https://www.youtube.com/watch?v=eOBGXpwxDCM
Here a video without VAC where i go through my setting
you can hear the difference
https://www.youtube.com/watch?v=w-C4cpXseKk
if anyone can help spot what is wrong and help my fix it
Or
Any suggestion for Not using VAC
How i can have my edited audio stream and not hear the edited change voice on my end but my viewers can.
That would work to
dping
Still has static
Or
That would work to
https://obsproject.com/forum/resources/microphone-dsp-plugin.127/
use without VAC or audition. this uses the same DSP filter that skype and other programs use for noise filtering.
EvilOverlord
I should had made it more clear
I dont use Adobe Audition just fr noise removal i'm doing other needed filters changes and edits
Hence i either need VAC or way to make those changes but not hear the changed audio on my end
