Hello,
I have a MacBook pro 13' from early 2013, and I'm trying to stream my Zwift races, therefore something not too crazy of a task given the specs of this machine.
However, as I'm trying to make everything work, I've noticed if I choose to do a window capture of the game, the recording was in a lower frame rate (to a level of a stop motion). I've played around with some things, and I've opted to capture the screen instead which solve the problem and the framerate was back to normal.
This opens the question: Does the window capture have some issue, and should I stick to screen only?
Cheers
Cheers
