Question / Help Using VAC to exclude audio, but huge delay on sound for stream?
Defiasen
I'm using this method, however everything recorded on the stream is hugely delayed. Is there a way to sync video with sound while using this method?
Would the "Force desktop audio to use video timestamps as a base for audio time" help solve this problem? I think that feature is for when audio is behind though no?
That's strange because VAC usually should work fine. Are you using the latest version of VAC? You can always try that option out, though.
If you use the Listen feature of Windows you shouldn't have any noticeable delay, normally delay is just an issue when you use the VAC Audio Repeaters. Can you please make sure you setup everything like in the guide?
