Using badlion client (Minecraft client) Help please
ExolityHD
I'm on my laptop and when I go onto streamlabs 0.27.0 it uses my nvidia gpu and so does badlion but when I open badlion java minecraft it doesn't show and most times it would crash but streamlabs doesn't show a crash log, but when I change the gpu on badlion it will show, why???
I want to use my nvidia gpu for both and run it so everything is faster, how? I use the same gpu for normal java minecraft and it streams fine, but the client rises my fps a lot so i'd rather stream on that.
I know I have the right window to capture because when I changed the gpu i used on the client it worked but then the game was laggy. So please help stream from my laptop on badlion client running the same gpu as streamlabs on game capture.
Also in game capture i've tried all the properties it has been so annoying to deal with please help.
1. this is OBS not streamlabs so ask by streamlabs
2. for laptops you need to special configure apps and OBS to work on specific GPU (there need to be the same) there pined topics you can take a look
but over all we not make support for thirdparty software here
