Bug Report Using a Bluetooth-Headset with OBS makes it crash and other problems.
Ilias Emmanouil
So I use a Bluetooth Headset for streaming. But it's very tricky to get to work.
I change the Audio Source to Bluetooth but then I have to be sure to already have the Bluetooth connected to the PC before starting the stream or OBS will not caputure the audio for some reason.
And another big problem is that whenever I disengage the Bluetooth while streaming (because my hedphones die or I remove the power pack while trying to charge them) OBS decides to crash hard.
Please fix Bluetooth support for OBS :(
Thank you so much for your hard work!
Greetings
Feurigerilias
OBS does not support adding / removing desktop audio devices that are in use during a stream.
