Use custom audio device missing in newer versions
DanL
Hello, I need to configure an old video card capture on OBS that I can correctly set on "Video capture device", the only problem is that it's unable to acquire audio.
I found a YouTube tutorial showing how to fix that, and it needs to check the option "Use custom audio device" as shown in the attached image.
The problem is that this checkbox is missing in OBS newer versions and I cannot understand how can I fix that.
Why this feature is missing? How can I fix this problem using latest version?
Thanks
