Question / Help USB Wireless Adapter stops working when I stream. Please help.
Jpugh99
Every single time I try to stream my Wireless USB Adapter (plugged into USB due to not having a network card) crashes and I have to restart my computer for it to work. Every time I restart it I get a blue screen with USB_Bugcode or Bugcode_USB (can't remember). If anyone could help me that would be great. For some additional information my Router is the Belkin F9K1002 N300 Wireless N Router IEEE 802.11 b/g/n and my Wireless Adapter is the Netgear N600 Wireless Dual Band USB Adapter. I have had the Chip for 2 years 1 month and the router about as long so maybe that's the problem. Thanks in advance.
personally, I would check for an updated driver for your USB and/or try a different USB port. I dont know if this is an OBS issue though.
Lastly, you should never attempt to stream over wireless.
Alright, thank you. I have to have a router due to having other people living with me using WiFi. It would be fine to run the Router into my room and connect it to my pc via ethernet, correct?
If possible yes. Next time you post here with an issue, make sure you post a log file. its under the help menu then just link it to your post
