Question / Help "USB Disonnect" sound keeps playing when OBS is running; Yeti Microphone
Marscaleb
Okay, I've been doing some investigating, and this problem is only running when OBS is either streaming or previewing a stream.
It doesn't do this when OBS is open but not streaming/previewing, just when it is streaming/previewing. I just stopped the preview and the problem hasn't happened for fifteen minutes. But once the preview was running it has happened five times in two minutes.
I keep having USB devices randomly plug and then immediately unplug, which causes the "USB disconnect" sound to randomly play while I'm streaming.
I've been looking around and I downloaded a program that gives me a record of every USB device as it connects and disconnects. The item is just described as "USB Composite Device" and the Device type is unknown. Serial Number rev8, Vendor ID b58e, Product ID 9e84, firmware Revision 1.0
A little google-fu reveals that this must be my Blue Yeti microphone. A little further investigation shows that it is more likely to happen when there is more noise than when it is silent.
I've been trying to narrow down this problem further, but I have not gotten anywhere. I appreciate any advice/help.
