Question / Help Upgraded my PC same issues. Need help
iJona
New pc Specs:
Mobo: AsRock Xtreme z77
CPU: Intel 3750k i5 Oclocked to 4.5
GPU: Nvidia Geforce 560 Gtx Ti
Ram: 8gb DDR3
Internet: 10/1.4
I am getting really high ping spikes running LoL and OBS with no other programs open, at 8 Quality 800/800 for bit
1680 x 1050 scaled down to 746x466 FPS at 29. Aero Disabled.
iJona
I changed it to 500 500 bit and it was fine for 20min then i get a huge lag spike and have to turn it off, Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU Speed: 3400MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 560 Ti
Video Adapter Dedicated Video Memory: 1025966080
Video Adapter Shared System Memory: 3221106688
Base resolution: 1680x1050
Output resolution: 744x466
Loading up D3D10...
Using auxilary audio input: Microphone (2- USB2.0 Audio Device)
Audio Encoding: AAC
bitrate: 128
Using Monitor Capture
Video Encoding: x264
fps: 29
width: 744, height: 466
preset: veryfast
CBR: no
max bitrate: 500
buffer size: 500
quality: 8
Server selection: rtmp://live-iad.justin.tv/app
bufferTime: 2078, outputRateWindowTime: 1000, dropThreshold: 2578
Warning -- Capture BitBlt failed.. just so you know
iJona
Here are two more logs, after i upgraded my internet to 20/2
Got big lag spike till i went all the way down to 500 bit and 8quality, I know my internet and Computer can handle more than that...
CPU Speed: 3400MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 29
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 8
bufferTime: 2193, outputRateWindowTime: 1000, dropThreshold: 2693
Total frames rendered: 2167, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
  Output resolution: 1120x700
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    width: 1120, height: 700
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 8
bufferTime: 2077, outputRateWindowTime: 1000, dropThreshold: 2577
Total frames rendered: 19062, number of frames that lagged: 14 (0.07%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
    device: HP Webcam 2100,
    device id \\?\usb#vid_04f2&pid_a149&mi_00#6&2a80d949&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
    chosen type: YUY2, usingFourCC: false, res: 1280x1024 - 1280x1024, fps: 5-9, fourCC: 'YUY2'
Using directshow input
Total frames rendered: 1301, number of frames that lagged: 1 (0.08%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
bufferTime: 2116, outputRateWindowTime: 1000, dropThreshold: 2616
Total frames rendered: 2682, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
RTMPPublisher::BufferedSend: Buffer is full (128717 / 131072 bytes), waiting to send 4097 bytes
CPU Speed: 3400MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
bufferTime: 2115, outputRateWindowTime: 1000, dropThreshold: 2615
RTMPPublisher::BufferedSend: Buffer is full (130741 / 131072 bytes), waiting to send 404 bytes
RTMPPublisher::BufferedSend: Buffer is full (128907 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (128526 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (128926 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (130204 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (130682 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129395 / 131072 bytes), waiting to send 3946 bytes
RTMPPublisher::BufferedSend: Buffer is full (130060 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129264 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (128601 / 131072 bytes), waiting to send 3299 bytes
RTMPPublisher::BufferedSend: Buffer is full (130945 / 131072 bytes), waiting to send 3986 bytes
RTMPPublisher::BufferedSend: Buffer is full (129625 / 131072 bytes), waiting to send 2988 bytes
RTMPPublisher::BufferedSend: Buffer is full (130912 / 131072 bytes), waiting to send 356 bytes
RTMPPublisher::BufferedSend: Buffer is full (131058 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (128901 / 131072 bytes), waiting to send 2929 bytes
RTMPPublisher::BufferedSend: Buffer is full (127188 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (127801 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (130964 / 131072 bytes), waiting to send 411 bytes
RTMPPublisher::BufferedSend: Buffer is full (129326 / 131072 bytes), waiting to send 2431 bytes
RTMPPublisher::BufferedSend: Buffer is full (128485 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (130567 / 131072 bytes), waiting to send 1508 bytes
RTMPPublisher::BufferedSend: Buffer is full (129591 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (131025 / 131072 bytes), waiting to send 376 bytes
RTMPPublisher::BufferedSend: Buffer is full (129958 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (130517 / 131072 bytes), waiting to send 938 bytes
RTMPPublisher::BufferedSend: Buffer is full (129939 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (130620 / 131072 bytes), waiting to send 701 bytes
RTMPPublisher::BufferedSend: Buffer is full (130700 / 131072 bytes), waiting to send 380 bytes
RTMPPublisher::BufferedSend: Buffer is full (130547 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129490 / 131072 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (128588 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (127252 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129750 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (130754 / 131072 bytes), waiting to send 376 bytes
RTMPPublisher::BufferedSend: Buffer is full (128319 / 131072 bytes), waiting to send 3311 bytes
RTMPPublisher::BufferedSend: Buffer is full (128230 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129427 / 131072 bytes), waiting to send 3471 bytes
RTMPPublisher::BufferedSend: Buffer is full (130908 / 131072 bytes), waiting to send 378 bytes
RTMPPublisher::BufferedSend: Buffer is full (130672 / 131072 bytes), waiting to send 1500 bytes
RTMPPublisher::BufferedSend: Buffer is full (129810 / 131072 bytes), waiting to send 1697 bytes
RTMPPublisher::BufferedSend: Buffer is full (127940 / 131072 bytes), waiting to send 4097 bytes
Total frames rendered: 72198, number of frames that lagged: 22 (0.03%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
Number of b-frames dropped: 492 (0.28%), Number of p-frames dropped: 354 (0.2%), Total 846 (0.48%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
Total frames rendered: 1, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
  Output resolution: 840x524
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    width: 840, height: 524
    preset: veryfast
    CBR: no
    max bitrate: 900
    buffer size: 900
    quality: 9
bufferTime: 2529, outputRateWindowTime: 1000, dropThreshold: 3029
RTMPPublisher::BufferedSend: Buffer is full (130919 / 131072 bytes), waiting to send 2423 bytes
RTMPPublisher::BufferedSend: Buffer is full (129677 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (129263 / 131072 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (128410 / 131072 bytes), waiting to send 4097 bytes
Total frames rendered: 610, number of frames that lagged: 2 (0.33%) (it's okay for some frames to lag)
Number of b-frames dropped: 66 (5.2%), Number of p-frames dropped: 36 (2.8%), Total 102 (8%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 700
    buffer size: 700
    quality: 9
bufferTime: 2145, outputRateWindowTime: 1000, dropThreshold: 2645
RTMPPublisher::BufferedSend: Buffer is full (103364 / 105472 bytes), waiting to send 2195 bytes
RTMPPublisher::BufferedSend: Buffer is full (103146 / 105472 bytes), waiting to send 4104 bytes
Total frames rendered: 507, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 96
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 700
    buffer size: 700
    quality: 8
Total frames rendered: 746, number of frames that lagged: 2 (0.27%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 96
    fps: 30
    preset: veryfast
    CBR: no
    max bitrate: 500
    buffer size: 500
    quality: 8
bufferTime: 2052, outputRateWindowTime: 1000, dropThreshold: 2552
RTMPPublisher::BufferedSend: Buffer is full (75630 / 75776 bytes), waiting to send 320 bytes
RTMPPublisher::BufferedSend: Buffer is full (73083 / 75776 bytes), waiting to send 3236 bytes
RTMPPublisher::BufferedSend: Buffer is full (74477 / 75776 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (74610 / 75776 bytes), waiting to send 1650 bytes
RTMPPublisher::BufferedSend: Buffer is full (73852 / 75776 bytes), waiting to send 3797 bytes
RTMPPublisher::BufferedSend: Buffer is full (72385 / 75776 bytes), waiting to send 4052 bytes
RTMPPublisher::BufferedSend: Buffer is full (74861 / 75776 bytes), waiting to send 3094 bytes
RTMPPublisher::BufferedSend: Buffer is full (74079 / 75776 bytes), waiting to send 3207 bytes
Total frames rendered: 74601, number of frames that lagged: 8 (0.01%) (it's okay for some frames to lag)
Number of b-frames dropped: 122 (0.067%), Number of p-frames dropped: 63 (0.035%), Total 185 (0.1%)
Profiler results:
frame - [100%] [avg time: 8.569 ms] [avg calls per frame: 1] [children: 96.2%] [unaccounted: 3.76%]
| scene->Preprocess - [59.3%] [avg time: 5.079 ms] [avg calls per frame: 1]
| video encoding and uploading - [37%] [avg time: 3.168 ms] [avg calls per frame: 1] [children: 11.5%] [unaccounted: 25.5%]
| | CopyResource - [0.117%] [avg time: 0.01 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.175%] [avg time: 0.015 ms] [avg calls per frame: 0]
| | call to encoder - [11.1%] [avg time: 0.951 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0817%] [avg time: 0.007 ms] [avg calls per frame: 0]
Memory Leaks Were Detected.
hilalpro
there is no reason to why you should be drooping frames at a 500kbits buffer. if you have picked the closest twitch server to you, then it must be a problem within your pc configuration lan network (router) or isp. have you used some kind of tcp/internet optimizer before ? is it a public wifi ? do you watch your stream while streaming ? if no you should do another test on a non busy hour. like between 1 and 7am see if your line drops as much packets
iJona
I have it at 600 and its not dropping packets, i do have asrock xxfast lan. Im running fine at 1120x 700 8 quality 600/600 bit. But I want better quality.
iJona
Is there anything at all I can do to make the quality better? I cant get any better upload and its not my pc that is causing the problem.
hilalpro
you can use the latest test build from the download page and try out low latency mode on your "broadcasting settings"
