Updated OBS not showing me entire drop-down or right-click options
mattyoutwest
After updating OBS, I can't seem to access all options for right-clicking or even drop-down menus from the top. It seems to just cut off and I can't even scroll down for more options. It makes accessing newer features impossible when I'm trying to adjust the quality of my setup. I've been deleting and redownloading just so I can make adjustments to continue using it however, with the older version, I don't have access to any features that I'd really like to use. I'm currently still on Windows 10 and am wondering if this could be the issue if the most updated version of OBS is optimized for Windows 11. Any help would be great!
Are you using a third party skin/theme? Try updating it or changing for a default one.
Not at all. I’m wondering though, are you using the updated version of OBS on Windows 11? Because if it works for you on Windows 11, then I don’t mind switching over from Windows 10 in order to make it work.
Can you please post some images of the issue.
I use windows 10, updated. The other thing I can think of causing this issue to you is a crappy plugin.
A log file is need too.
So after updating it again, I can access the options from the top drop down menus, but right clicking still doesn’t show all options
