Question / Help Unpredictable Audio Delay
Futureman
Hello everybody!
Looking for a little bit of help here as I'm having some audio issues and after hours of tweaking/adjusting settings I just can't get it figured out!
After streaming successfully for about a month, I booted up my stream a couple weeks ago and my chat started telling me that there was a bad delay on my audio. I was puzzled because to my knowledge I hadn't changed anything. I stopped the stream, checked my setting and all seemed to be normal so I decided to boot the stream right back up and lo and behold the audio delay was gone. Unfortunately, the next day the same exact thing happened with the delay... I reboot and it had fixed itself again. I have been doing that, but it messes up my vods/stream beginnings so I'm looking to figure out what causes the delay
Now, I do have a unique audio setup, but I don't think its too overly complicated.
My Studio Projects B1 mic is running through a Roland VT-3(Vocal Sound FX) which provides phantom power to the mic. The Roland VT-3 is then plugged into my computer via USB.
Check the log for my OBS settings-
https://gist.github.com/9403bc5ba9694c11a7c8
I made a couple quick videos showing the the issue at hand:
Delay vid- http://www.twitch.tv/thepowerfalcon/b/585936713
Non Delay Vid-http://www.twitch.tv/thepowerfalcon/b/585927177
Or
Check my actual stream
Delay- http://www.twitch.tv/futuremangaming/b/585084945
Non Delay- http://www.twitch.tv/futuremangaming/b/585094355
...So now I just tested it again and it seemed to be off again after being good. So I really have no idea when or why it decides to delay.
Thanks for any and all help!
-Futureman
