Trying to figure out an audio not equal to video issue
macjohn
I've got a camera showing the video correctly coming from an iPhone's IP Camera app. I can use a webcam viewing app on another phone or on my pc that accurately displays the video and the audio coming from the camera. The problem is, in OBS, the only way I can get audio is if I activate a device called 'stereo mix'. This would be ok but the sound is delayed by 12-14 seconds from the video. While looking at my audio mixer in OBS Studio, I can see the sound bars being activated for 'stereo mix', but not for my iphone (which is displayed in the device list). I've tried removing all mic devices in general settings (setting all to disabled) as recommended by an old thread when trying to troubleshoot the sound sync issue. I feel, however, I have a bigger issue that I'm just not seeing.
Ideally, I'd be able to control the sound (muting, adjusting sync, etc) from the iphone device in the audio mixer within OBS Studio, but that device seems to have no impact. The sound is definitely coming from OBS Studio because when I mute that app in the windows sound mixer, it's quiet.
I'm still pretty new to this program, although I have several scenes and over 30 sources (ip cams set up around my house), so any help is appreciated. I'm assuming there's something obvious I just don't get.
Log file:
OBS 27.0.1 (64-bit, windows) log file uploaded at 2021-06-16, 17:48:12
19:06:58.334: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
19:06:58.334: CPU Speed: 3696MHz
19:06:58.334: Physical Cores: 6, Logical Cores: 12
19:06:58.334: Physical Memory: 16242MB Total, 9813MB Free
19:06:58.334: Windows Version: 10.0 Build 19042 (release: 2009; revision: 1052; 64-bit)
19:06:58.334: Running as administrator: false
19:06:58.334: Aero is Enabled (Aero is always on for windows 8 and above)
19:06:58.335: Windows 10 Gaming Features:
19:06:58.335: Game DVR: On
19:06:58.346: Sec. Software Status:
19:06:58.370: Microsoft Defender Antivirus: enabled (AV)
19:06:58.370: Windows Firewall: enabled (FW)
19:06:58.371: Current Date/Time: 2021-06-14, 19:06:58
19:06:58.371: Browser Hardware Acceleration: true
19:06:58.371: Portable mode: false
19:06:59.319: OBS 27.0.0 (64-bit, windows)
19:06:59.319: ---------------------------------
19:06:59.320: ---------------------------------
19:06:59.320: audio settings reset:
19:06:59.320: samples per sec: 48000
19:06:59.320: speakers: 2
19:06:59.322: ---------------------------------
19:06:59.322: Initializing D3D11...
19:06:59.322: Available Video Adapters:
19:06:59.336: Adapter 0: Intel(R) UHD Graphics 630
19:06:59.336: Dedicated VRAM: 134217728
19:06:59.336: Shared VRAM: 4220534784
19:06:59.336: PCI ID: 8086:3e92
19:06:59.337: Driver Version: 27.20.100.8681
19:06:59.337: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=DELL E2414H
19:06:59.337: output 1: pos={1920, 0}, size={900, 1440}, attached=true, refresh=60, name=SyncMaster
19:06:59.337: Adapter 1: Intel(R) UHD Graphics 630
19:06:59.337: Dedicated VRAM: 134217728
19:06:59.337: Shared VRAM: 4220534784
19:06:59.337: PCI ID: 8086:3e92
19:06:59.338: Driver Version: 27.20.100.8681
19:06:59.373: Loading up D3D11 on adapter Intel(R) UHD Graphics 630 (0)
19:06:59.432: D3D11 loaded successfully, feature level used: b000
19:06:59.433: DXGI increase maximum frame latency success
19:06:59.991: ---------------------------------
19:06:59.991: video settings reset:
19:06:59.991: base resolution: 1920x1080
19:06:59.991: output resolution: 1280x720
19:06:59.991: downscale filter: Bicubic
19:06:59.991: fps: 30/1
19:06:59.991: format: NV12
19:06:59.991: YUV mode: 709/Partial
19:06:59.991: NV12 texture support not available
19:06:59.992: Audio monitoring device:
19:06:59.992: name: Default
19:06:59.992: id: default
19:06:59.997: ---------------------------------
19:06:59.997: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
19:07:00.034: [CoreAudio encoder]: Adding CoreAudio AAC encoder
19:07:00.035: Failed to load 'en-US' text for module: 'decklink-captions.dll'
19:07:00.037: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
19:07:00.068: [AMF] Unable to load 'amfrt64.dll', error code 126.
19:07:00.072: [AMF] AMF Test failed due to one or more errors.
19:07:00.072: Failed to initialize module 'enc-amf.dll'
19:07:00.080: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
19:07:00.095: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
19:07:00.097: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
19:07:00.105: [obs-browser]: Version 2.14.3
19:07:00.105: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
19:07:00.105: [obs-browser]: Blacklisted device detected, disabling browser source hardware acceleration.
19:07:00.111: [noise suppress: Nvidia RTX denoiser disabled, redistributable not found]
19:07:01.359: Skipping module '../../obs-plugins/64bit/RecordSplitter.dll', not an OBS plugin
19:07:01.361: LoadLibrary failed for '../../obs-plugins/64bit/RecordSplitter.dll': %1 is not a valid Win32 application.
19:07:01.361: (193)
19:07:01.361: Module '../../obs-plugins/64bit/RecordSplitter.dll' not loaded
19:07:01.376: VLC found, VLC video source enabled
19:07:01.390: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
19:07:01.391: No blackmagic support
19:07:01.398: ---------------------------------
19:07:01.398: Loaded Modules:
19:07:01.398: win-wasapi.dll
19:07:01.398: win-mf.dll
19:07:01.398: win-dshow.dll
19:07:01.398: win-decklink.dll
19:07:01.398: win-capture.dll
19:07:01.398: vlc-video.dll
19:07:01.398: text-freetype2.dll
19:07:01.398: rtmp-services.dll
19:07:01.398: obs-x264.dll
19:07:01.398: obs-vst.dll
19:07:01.398: obs-transitions.dll
19:07:01.398: obs-text.dll
19:07:01.398: obs-qsv11.dll
19:07:01.398: obs-outputs.dll
19:07:01.398: obs-filters.dll
19:07:01.398: obs-ffmpeg.dll
19:07:01.398: obs-browser.dll
19:07:01.398: image-source.dll
19:07:01.398: frontend-tools.dll
19:07:01.398: enc-amf.dll
19:07:01.398: decklink-ouput-ui.dll
19:07:01.398: decklink-captions.dll
19:07:01.398: coreaudio-encoder.dll
19:07:01.398: ==== Startup complete ===============================================
19:07:01.417: Switched to Preview/Program mode
19:07:01.417: ------------------------------------------------
19:07:01.423: All scene data cleared
19:07:01.423: ------------------------------------------------
19:07:01.665: WASAPI: Device 'Speakers (Realtek High Definition Audio)' [48000 Hz] initialized
19:07:01.665: [Loaded global audio device]: 'Desktop Audio'
19:07:02.004: WASAPI: Device 'Stereo Mix (Realtek High Definition Audio)' [48000 Hz] initialized
19:07:02.004: [Loaded global audio device]: 'Mic/Aux'
19:07:02.005: [Media Source 'Iphone5s']: settings:
19:07:02.005: input: http://192.168.1.21:8081
19:07:02.005: input_format:
19:07:02.005: speed: 100
19:07:02.005: is_looping: no
19:07:02.005: is_hw_decoding: no
19:07:02.005: is_clear_on_media_end: no
19:07:02.005: restart_on_activate: no
19:07:02.005: close_when_inactive: no
<clipped a bunch of sources>
19:07:02.028: Switched to scene 'cams for recording'
19:07:02.029: warning: deprecated pixel format used, make sure you did set range correctly
19:07:02.032: [Media Source 'Cam24Media']: Disconnected. Reconnecting...
19:07:02.032: ------------------------------------------------
19:07:02.032: Loaded scenes:
19:07:02.032: - scene 'Driveway':
19:07:02.032: - source: 'Cam09' (ffmpeg_source)
<clipped a bunch of scenes>
19:07:02.033: ------------------------------------------------
19:07:02.037: warning: deprecated pixel format used, make sure you did set range correctly
<clipped dupe messages>
19:07:02.302: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
19:07:02.468: warning: deprecated pixel format used, make sure you did set range correctly
19:07:02.481: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
19:07:02.919: ---------------------------------
19:07:02.919: [DShow Device: 'Office Cam vid cap device'] settings updated:
19:07:02.919: video device: Microsoft LifeCam VX-3000
19:07:02.919: video path: \\?\usb#vid_045e&pid_00f5&mi_00#6&267eee31&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
19:07:02.919: resolution: 320x240
19:07:02.919: flip: 0
19:07:02.919: fps: 30.00 (interval: 333333)
19:07:02.919: format: XRGB
19:07:03.112: DShow: HDevice::ConnectPins: failed to connect pins (0x80040207): The owner SID on a per-user subscription doesn't exist
19:07:03.112:
19:07:03.729: DShow: HDevice::ConnectFilters: RenderStream failed (0x80070057): The parameter is incorrect.
19:07:03.729:
19:07:04.014: warning: max delay reached. need to consume packet
19:07:04.014: warning: RTP: missed 1 packets
19:07:04.357: error: cabac decode of qscale diff failed at 115 15
19:07:04.357: error: error while decoding MB 115 15, bytestream 156564
19:07:04.798: warning: deprecated pixel format used, make sure you did set range correctly
19:07:04.989: warning: deprecated pixel format used, make sure you did set range correctly
19:07:05.273: warning: max delay reached. need to consume packet
19:07:05.273: warning: RTP: missed 1 packets
19:07:06.184: warning: deprecated pixel format used, make sure you did set range correctly
19:07:07.221: warning: deprecated pixel format used, make sure you did set range correctly
19:07:07.265: warning: deprecated pixel format used, make sure you did set range correctly
19:07:07.427: error: cabac decode of qscale diff failed at 115 15
19:07:07.427: error: error while decoding MB 115 15, bytestream 156564
19:07:07.447: warning: deprecated pixel format used, make sure you did set range correctly
19:07:07.457: adding 341 milliseconds of audio buffering, total audio buffering is now 512 milliseconds (source: Cam06)
19:07:07.457:
19:07:08.172: warning: deprecated pixel format used, make sure you did set range correctly
19:07:08.441: MP: Failed to open media: 'http://user:pass@
19:07:08.462: [Media Source 'Cam24']: Disconnected. Reconnecting...
19:07:08.555: warning: deprecated pixel format used, make sure you did set range correctly
19:07:08.584: warning: max delay reached. need to consume packet
19:07:08.584: warning: RTP: missed 1 packets
19:07:08.855: adding 170 milliseconds of audio buffering, total audio buffering is now 682 milliseconds (source: IP Cam 04)
19:07:08.855:
<clipped a bunch of stuff just to get under 15000 characters>
19:07:10.459: Max audio buffering reached!
19:07:10.459: adding 277 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Cam12)
19:07:10.459:
19:07:32.070: error: non-existing SPS 32 referenced in buffering period
19:07:32.245: error: non-existing SPS 32 referenced in buffering period
19:07:32.279: error: cabac decode of qscale diff failed at 96 28
19:07:42.747: error: overread 8
19:07:42.747: warning: EOI missing, emulating
19:07:54.713: WASAPI: Device 'Speakers (Realtek High Definition Audio)' Terminated
19:07:54.719: WASAPI: Device 'Stereo Mix (Realtek High Definition Audio)' Terminated
19:07:54.724: All scene data cleared
19:07:54.724: ------------------------------------------------
19:07:54.816: [Scripting] Total detached callbacks: 0
19:07:54.831: Freeing OBS context data
19:07:54.847: == Profiler Results =============================
19:07:54.847: run_program_init: 4410.87 ms
19:07:54.847: ┣OBSApp::AppInit: 65.375 ms
19:07:54.847: ┃ ┗OBSApp::InitLocale: 2.081 ms
19:07:54.847: ┗OBSApp::OBSInit: 3979.26 ms
19:07:54.847: ┣obs_startup: 36.705 ms
19:07:54.847: ┗OBSBasic::OBSInit: 2993.87 ms
19:07:54.847: ┣OBSBasic::InitBasicConfig: 0.724 ms
19:07:54.847: ┣OBSBasic::ResetAudio: 0.144 ms
19:07:54.847: ┣OBSBasic::ResetVideo: 671.342 ms
19:07:54.847: ┣OBSBasic::InitOBSCallbacks: 0.005 ms
19:07:54.847: ┣OBSBasic::InitHotkeys: 0.036 ms
19:07:54.847: ┣obs_load_all_modules: 1401.32 ms
19:07:54.847: ┃ ┣obs_init_module(coreaudio-encoder.dll): 33.704 ms
19:07:54.847: ┃ ┣obs_init_module(decklink-captions.dll): 0.024 ms
<more clipping to get under character limit>
19:07:54.847: ┗OBSBasic::Load: 627.644 ms
19:07:54.847: obs_hotkey_thread(25 ms): min=0.004 ms, median=0.01 ms, max=140.733 ms, 99th percentile=0.277 ms, 99.9089% below 25 ms
19:07:54.847: audio_thread(Audio): min=0 ms, median=0.12 ms, max=7.082 ms, 99th percentile=0.777 ms
19:07:54.847: obs_graphics_thread(33.3333 ms): min=0.036 ms, median=1.054 ms, max=75.447 ms, 99th percentile=3.57 ms, 99.9391% below 33.333 ms
19:07:54.847: ┣tick_sources: min=0.001 ms, median=0.1 ms, max=2.792 ms, 99th percentile=0.332 ms
19:07:54.847: ┣output_frame: min=0.028 ms, median=0.321 ms, max=7.034 ms, 99th percentile=2.239 ms
19:07:54.847: ┃ ┗gs_context(video->graphics): min=0.027 ms, median=0.321 ms, max=7.034 ms, 99th percentile=2.238 ms
19:07:54.847: ┃ ┣render_video: min=0.006 ms, median=0.301 ms, max=6.926 ms, 99th percentile=2.177 ms
19:07:54.847: ┃ ┃ ┗render_main_texture: min=0.003 ms, median=0.297 ms, max=6.923 ms, 99th percentile=2.17 ms
19:07:54.847: ┃ ┗gs_flush: min=0.011 ms, median=0.028 ms, max=1.59 ms, 99th percentile=0.121 ms
19:07:54.847: ┗render_displays: min=0 ms, median=0.536 ms, max=6.83 ms, 99th percentile=1.865 ms
19:07:54.847: =================================================
19:07:54.847: == Profiler Time Between Calls ==================
19:07:54.847: obs_hotkey_thread(25 ms): min=24.909 ms, median=25.697 ms, max=166.067 ms, 38.2688% within ±2% of 25 ms (0% lower, 61.7312% higher)
19:07:54.847: obs_graphics_thread(33.3333 ms): min=24.537 ms, median=33.333 ms, max=75.463 ms, 99.6346% within ±2% of 33.333 ms (0.182704% lower, 0.182704% higher)
19:07:54.862: Number of memory leaks: 0
