Make sure you have not more than 1 display capture source across all your scene. If you need your monitor in more than one scene, remove additional display capture sources and re-add them with the "add existing" option. This way you're creating a reference to the one capture, not a duplicate. Rule of thumb: same monitors must have the same source name. Otherwise they stomp on each other and one may be black.
The same goes with game capture sources that are set to "capture any fullscreen application". They may collide with display capture once the game goes fullscreen. To fix, set the mode to "Capture specific window" and specify the game with the "Window" dropdown list. If the game goes fullscreen, it's still being captured by this source, despite the wording of that option. However, capturing a game fullscreen and having a display capture for the same monitor at the same time still may lead to one of the two being black.
