Bug Report Sync-offset Audio and Compressor Filter
kiichan
System: Debian Testing, x86_64, building from git:
HEAD 30d967eafa13fcf7179585017bf432ce9cda1ac2
Issue: Adding a sync offset to an audio source delays the playback of the audio, however it does not delay it as a sidechain source, causing audio ducking to behave improperly.
Steps to reproduce:
  1. Create two audio sources, A and B
  2. Add an arbitrary sync offset to source A using the Advanced Audio Properties dialog
  3. Add a compressor filter to source B
  4. Set the sidechain source to A
Expected behavior: The audio is delayed by the offset, also delaying the sidechain compression.
Exhibited behavior: The sidechain compression lowers the audio track on source B when source A is received, before being delayed. The result is B's ducking losing synchronization with source A's input.
Edit: Also submitted as a bug report
