Hi,
it would be nice to choose the Audio Device for sound.
Why?
If you want to Stream without transfering Voicechat like Ventrilo/Teamspeak etc. you can do this by using Virtual Audio Cable as microfon device and mute default sound. The downside to this is you can't seperately control your mic anymore. So all the nice features for micsound are gone. If you make it possible to choose the device for sound instead of using the default one we can do this again by using the "Streaming Virtual Audio Cable" and the microfon as before!
Would be a nice seperation and allowing for advanced setups!
Congratz on the great Program so faar.
greetings Tak0r
Why?
greetings Tak0r
