21:53:10: Open Broadcaster Software v0.551b - 32bit (´・ω・`)
21:53:10: -------------------------------
21:53:10: CPU Name: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz
21:53:10: CPU Speed: 2993MHz
21:53:10: Physical Memory: 4095MB Total, 3649MB Free
21:53:10: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
21:53:10: monitor 1: pos={0, 0}, size={1920, 1080}
21:53:10: Windows Version: 6.2 Build 9200
21:53:10: Aero is Enabled
21:53:10: OBS Modules:
21:53:10: Base Address Module
21:53:10: 010F0000 OBS.exe
21:53:10: 53A50000 OBSApi.dll
21:53:10: 649B0000 DShowPlugin.dll
21:53:10: 64C30000 GraphicsCapture.dll
21:53:10: 64A10000 NoiseGate.dll
21:53:10: 5DB50000 PSVPlugin.dll
21:53:10: ------------------------------------------
21:53:10: Adapter 1
21:53:10: Video Adapter: Intel(R) HD Graphics
21:53:10: Video Adapter Dedicated Video Memory: 33554432
21:53:10: Video Adapter Shared System Memory: 1711276032
21:53:10: =====Stream Start: 2013-08-16, 21:53:10===============================================
21:53:10: Multithreaded optimizations: On
21:53:10: Base resolution: 1920x1080
21:53:10: Output resolution: 1280x720
21:53:10: Loading up D3D10 on Intel(R) HD Graphics...
21:53:10: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
21:53:10: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
21:53:10: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
21:53:10: Audio Encoding: AAC
21:53:10: bitrate: 128
21:53:11: ------------------------------------------
21:53:11: device: Microsoft LifeCam VX-3000,
21:53:11: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:53:11: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
21:53:11: audio device: Disable,
21:53:11: audio device id Disabled,
21:53:11:
21:53:11: Using directshow input
21:53:11: Using Monitor Capture
21:53:12: ------------------------------------------
21:53:12: Video Encoding: x264
21:53:12: fps: 30
21:53:12: width: 1280, height: 720
21:53:12: preset: veryfast
21:53:12: CBR: yes
21:53:12: CFR: no
21:53:12: max bitrate: 1000
21:53:12: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
21:53:12: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
21:53:15: Total frames rendered: 76, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:53:16:
21:53:16: Profiler results:
21:53:16:
21:53:16: ==============================================================
21:53:16: frame - [100%] [avg time: 3.713 ms (cpu time: avg 3.289 ms, total 250 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.215%]
21:53:16: | frame preprocessing and rendering - [38.8%] [avg time: 1.441 ms (cpu time: avg 1.233 ms, total 93.75 ms)] [avg calls per frame: 1] [children: 18.8%] [unaccounted: 20%]
21:53:16: | | scene->Preprocess - [18.8%] [avg time: 0.697 ms (cpu time: avg 0.616 ms, total 46.875 ms)] [avg calls per frame: 1]
21:53:16: | video encoding and uploading - [61%] [avg time: 2.264 ms (cpu time: avg 2.055 ms, total 156.25 ms)] [avg calls per frame: 1] [children: 60.4%] [unaccounted: 0.539%]
21:53:16: | | flush - [4.61%] [avg time: 0.171 ms (cpu time: avg 0.205 ms, total 15.625 ms)] [avg calls per frame: 1]
21:53:16: | | CopyResource - [2.29%] [avg time: 0.085 ms (cpu time: avg 0.411 ms, total 31.25 ms)] [avg calls per frame: 0]
21:53:16: | | conversion to 4:2:0 - [0.35%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:53:16: | | call to encoder - [53.2%] [avg time: 1.974 ms (cpu time: avg 1.439 ms, total 109.375 ms)] [avg calls per frame: 0]
21:53:16: | | sending stuff out - [0.0269%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:53:16: | Convert444Threads - [1.39e+003%] [avg time: 51.732 ms (cpu time: avg 1.233 ms, total 93.75 ms)] [avg calls per frame: 1]
21:53:16:
21:53:16: =====Stream End: 2013-08-16, 21:53:16=================================================
21:53:17: Using fixed low latency mode, factor 20
21:53:17: =====Stream Start: 2013-08-16, 21:53:17===============================================
21:53:17: Multithreaded optimizations: On
21:53:17: Base resolution: 1920x1080
21:53:17: Output resolution: 1280x720
21:53:17: ------------------------------------------
21:53:17: Loading up D3D10 on Intel(R) HD Graphics...
21:53:17: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
21:53:17: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
21:53:17: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
21:53:17: Audio Encoding: AAC
21:53:17: bitrate: 128
21:53:17: device: Microsoft LifeCam VX-3000,
21:53:17: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:53:17: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
21:53:17: audio device: Disable,
21:53:17: audio device id Disabled,
21:53:17:
21:53:17: Using directshow input
21:53:17: Using Monitor Capture
21:53:18: ------------------------------------------
21:53:18: Video Encoding: x264
21:53:18: fps: 30
21:53:18: width: 1280, height: 720
21:53:18: preset: veryfast
21:53:18: CBR: yes
21:53:18: CFR: no
21:53:18: max bitrate: 1000
21:53:18: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
21:53:18: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
21:53:19: Using RTMP service: Twitch / Justin.tv
21:53:19: Server selection: rtmp://live.justin.tv/app
21:53:19: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
21:53:20: SO_SNDBUF was at 65536
21:53:20: SO_SNDBUF is now 65536
22:08:57: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 144384)
22:31:55: Total frames rendered: 63697, number of late frames: 18620 (29.23%) (it's okay for some frames to be late)
22:31:56: RTMPPublisher::SocketLoop: Graceful loop exit
22:31:56: Number of times waited to send: 0, Waited for a total of 0 bytes
22:31:56: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:31:56:
22:31:56: Profiler results:
22:31:56:
22:31:56: ==============================================================
22:31:56: frame - [100%] [avg time: 20.457 ms (cpu time: avg 4.452 ms, total 283625 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0489%]
22:31:56: | frame preprocessing and rendering - [32.1%] [avg time: 6.564 ms (cpu time: avg 1.836 ms, total 116984 ms)] [avg calls per frame: 1] [children: 14.1%] [unaccounted: 18%]
22:31:56: | | scene->Preprocess - [14.1%] [avg time: 2.883 ms (cpu time: avg 1.135 ms, total 72312.5 ms)] [avg calls per frame: 1]
22:31:56: | video encoding and uploading - [67.9%] [avg time: 13.883 ms (cpu time: avg 2.615 ms, total 166578 ms)] [avg calls per frame: 1] [children: 15.2%] [unaccounted: 52.6%]
22:31:56: | | flush - [0.802%] [avg time: 0.164 ms (cpu time: avg 0.109 ms, total 7000 ms)] [avg calls per frame: 1]
22:31:56: | | CopyResource - [0.733%] [avg time: 0.15 ms (cpu time: avg 0.108 ms, total 6890.63 ms)] [avg calls per frame: 0]
22:31:56: | | conversion to 4:2:0 - [0.494%] [avg time: 0.101 ms (cpu time: avg 0.01 ms, total 671.875 ms)] [avg calls per frame: 0]
22:31:56: | | call to encoder - [13%] [avg time: 2.669 ms (cpu time: avg 2.306 ms, total 146891 ms)] [avg calls per frame: 0]
22:31:56: | | sending stuff out - [0.171%] [avg time: 0.035 ms (cpu time: avg 0.027 ms, total 1781.25 ms)] [avg calls per frame: 0]
22:31:56: | Convert444Threads - [356%] [avg time: 72.728 ms (cpu time: avg 2.504 ms, total 159516 ms)] [avg calls per frame: 1]
22:31:56:
22:31:56: =====Stream End: 2013-08-16, 22:31:56=================================================
22:37:22: =====Stream Start: 2013-08-16, 22:37:22===============================================
22:37:22: Multithreaded optimizations: On
22:37:22: Base resolution: 1920x1080
22:37:22: Output resolution: 1280x720
22:37:22: ------------------------------------------
22:37:22: Loading up D3D10 on Intel(R) HD Graphics...
22:37:23: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
22:37:23: ------------------------------------------
22:37:23: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
22:37:23: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
22:37:23: Audio Encoding: AAC
22:37:23: bitrate: 128
22:37:23: device: Microsoft LifeCam VX-3000,
22:37:23: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
22:37:23: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
22:37:23: audio device: Disable,
22:37:23: audio device id Disabled,
22:37:23:
22:37:23: Using directshow input
22:37:23: Using Monitor Capture
22:37:24: ------------------------------------------
22:37:24: Video Encoding: x264
22:37:24: fps: 30
22:37:24: width: 1280, height: 720
22:37:24: preset: veryfast
22:37:24: CBR: yes
22:37:24: CFR: no
22:37:24: max bitrate: 1000
22:37:24: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
22:37:24: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
22:37:28: Total frames rendered: 121, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
22:37:29:
22:37:29: Profiler results:
22:37:29:
22:37:29: ==============================================================
22:37:29: frame - [100%] [avg time: 4.271 ms (cpu time: avg 3.615 ms, total 437.5 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.187%]
22:37:29: | frame preprocessing and rendering - [34.4%] [avg time: 1.469 ms (cpu time: avg 1.291 ms, total 156.25 ms)] [avg calls per frame: 1] [children: 17.4%] [unaccounted: 17%]
22:37:29: | | scene->Preprocess - [17.4%] [avg time: 0.743 ms (cpu time: avg 0.774 ms, total 93.75 ms)] [avg calls per frame: 1]
22:37:29: | video encoding and uploading - [65.4%] [avg time: 2.794 ms (cpu time: avg 2.324 ms, total 281.25 ms)] [avg calls per frame: 1] [children: 64.7%] [unaccounted: 0.702%]
22:37:29: | | flush - [3.68%] [avg time: 0.157 ms (cpu time: avg 0.129 ms, total 15.625 ms)] [avg calls per frame: 1]
22:37:29: | | CopyResource - [2.34%] [avg time: 0.1 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:37:29: | | conversion to 4:2:0 - [0.211%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:37:29: | | call to encoder - [58.5%] [avg time: 2.497 ms (cpu time: avg 2.066 ms, total 250 ms)] [avg calls per frame: 0]
22:37:29: | | sending stuff out - [0.0234%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:37:29: | Convert444Threads - [1.34e+003%] [avg time: 57.284 ms (cpu time: avg 2.582 ms, total 312.5 ms)] [avg calls per frame: 1]
22:37:29:
22:37:29: =====Stream End: 2013-08-16, 22:37:29=================================================
22:41:50: Using fixed low latency mode, factor 20
22:41:50: =====Stream Start: 2013-08-16, 22:41:50===============================================
22:41:50: Multithreaded optimizations: On
22:41:50: Base resolution: 1920x1080
22:41:50: Output resolution: 1280x720
22:41:50: ------------------------------------------
22:41:50: Loading up D3D10 on Intel(R) HD Graphics...
22:41:50: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
22:41:50: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
22:41:50: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
22:41:50: Audio Encoding: AAC
22:41:50: bitrate: 96
22:41:50: device: Microsoft LifeCam VX-3000,
22:41:50: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
22:41:50: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
22:41:50: audio device: Disable,
22:41:50: audio device id Disabled,
22:41:50:
22:41:50: Using directshow input
22:41:50: Using Monitor Capture
22:41:51: ------------------------------------------
22:41:51: Video Encoding: x264
22:41:51: fps: 30
22:41:51: width: 1280, height: 720
22:41:51: preset: veryfast
22:41:51: CBR: yes
22:41:51: CFR: no
22:41:51: max bitrate: 1000
22:41:51: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
22:41:51: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
22:41:53: Using RTMP service: Twitch / Justin.tv
22:41:53: Server selection: rtmp://live.justin.tv/app
22:41:53: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
22:41:53: SO_SNDBUF was at 65536
22:41:53: SO_SNDBUF is now 65536
22:42:01: Total frames rendered: 287, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
22:42:02: RTMPPublisher::SocketLoop: Graceful loop exit
22:42:02: Number of times waited to send: 0, Waited for a total of 0 bytes
22:42:02: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:42:02:
22:42:02: Profiler results:
22:42:02:
22:42:02: ==============================================================
22:42:02: frame - [100%] [avg time: 4.267 ms (cpu time: avg 4.028 ms, total 1156.25 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.234%]
22:42:02: | frame preprocessing and rendering - [37.1%] [avg time: 1.582 ms (cpu time: avg 1.415 ms, total 406.25 ms)] [avg calls per frame: 1] [children: 18.7%] [unaccounted: 18.4%]
22:42:02: | | scene->Preprocess - [18.7%] [avg time: 0.797 ms (cpu time: avg 0.816 ms, total 234.375 ms)] [avg calls per frame: 1]
22:42:02: | video encoding and uploading - [62.7%] [avg time: 2.675 ms (cpu time: avg 2.613 ms, total 750 ms)] [avg calls per frame: 1] [children: 60.2%] [unaccounted: 2.51%]
22:42:02: | | flush - [4.31%] [avg time: 0.184 ms (cpu time: avg 0.272 ms, total 78.125 ms)] [avg calls per frame: 1]
22:42:02: | | CopyResource - [2.77%] [avg time: 0.118 ms (cpu time: avg 0.108 ms, total 31.25 ms)] [avg calls per frame: 0]
22:42:02: | | conversion to 4:2:0 - [0.984%] [avg time: 0.042 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:42:02: | | call to encoder - [51.7%] [avg time: 2.205 ms (cpu time: avg 2.177 ms, total 625 ms)] [avg calls per frame: 0]
22:42:02: | | sending stuff out - [0.445%] [avg time: 0.019 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:42:02: | Convert444Threads - [1.47e+003%] [avg time: 62.708 ms (cpu time: avg 2.504 ms, total 718.75 ms)] [avg calls per frame: 1]
22:42:02:
22:42:02: =====Stream End: 2013-08-16, 22:42:02=================================================
22:47:17: Using fixed low latency mode, factor 20
22:47:17: =====Stream Start: 2013-08-16, 22:47:17===============================================
22:47:17: Multithreaded optimizations: On
22:47:17: Base resolution: 1920x1080
22:47:17: Output resolution: 1280x720
22:47:17: ------------------------------------------
22:47:17: Loading up D3D10 on Intel(R) HD Graphics...
22:47:17: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
22:47:17: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
22:47:17: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
22:47:17: Audio Encoding: AAC
22:47:17: bitrate: 96
22:47:17: device: Microsoft LifeCam VX-3000,
22:47:17: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
22:47:17: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
22:47:17: audio device: Disable,
22:47:17: audio device id Disabled,
22:47:17:
22:47:17: Using directshow input
22:47:17: Using Monitor Capture
22:47:18: ------------------------------------------
22:47:18: Video Encoding: x264
22:47:18: fps: 30
22:47:18: width: 1280, height: 720
22:47:18: preset: veryfast
22:47:18: CBR: yes
22:47:18: CFR: no
22:47:18: max bitrate: 1000
22:47:18: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
22:47:18: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
22:47:19: Using RTMP service: Twitch / Justin.tv
22:47:19: Server selection: rtmp://live.justin.tv/app
22:47:19: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
22:47:20: SO_SNDBUF was at 65536
22:47:20: SO_SNDBUF is now 65536
22:47:28: Total frames rendered: 305, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
22:47:29: RTMPPublisher::SocketLoop: Graceful loop exit
22:47:29: Number of times waited to send: 0, Waited for a total of 0 bytes
22:47:29: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:47:30:
22:47:30: Profiler results:
22:47:30:
22:47:30: ==============================================================
22:47:30: frame - [100%] [avg time: 4.451 ms (cpu time: avg 3.688 ms, total 1125 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.202%]
22:47:30: | frame preprocessing and rendering - [33.7%] [avg time: 1.501 ms (cpu time: avg 1.28 ms, total 390.625 ms)] [avg calls per frame: 1] [children: 17.5%] [unaccounted: 16.2%]
22:47:30: | | scene->Preprocess - [17.5%] [avg time: 0.778 ms (cpu time: avg 0.563 ms, total 171.875 ms)] [avg calls per frame: 1]
22:47:30: | video encoding and uploading - [66.1%] [avg time: 2.941 ms (cpu time: avg 2.407 ms, total 734.375 ms)] [avg calls per frame: 1] [children: 62.5%] [unaccounted: 3.55%]
22:47:30: | | flush - [3.82%] [avg time: 0.17 ms (cpu time: avg 0.102 ms, total 31.25 ms)] [avg calls per frame: 1]
22:47:30: | | CopyResource - [2.36%] [avg time: 0.105 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:47:30: | | conversion to 4:2:0 - [1.01%] [avg time: 0.045 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:47:30: | | call to encoder - [54.8%] [avg time: 2.441 ms (cpu time: avg 2.305 ms, total 703.125 ms)] [avg calls per frame: 0]
22:47:30: | | sending stuff out - [0.494%] [avg time: 0.022 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:47:30: | Convert444Threads - [1.41e+003%] [avg time: 62.941 ms (cpu time: avg 3.227 ms, total 984.375 ms)] [avg calls per frame: 1]
22:47:30:
22:47:30: =====Stream End: 2013-08-16, 22:47:30=================================================
22:49:16: Using fixed low latency mode, factor 20
22:49:16: =====Stream Start: 2013-08-16, 22:49:16===============================================
22:49:16: Multithreaded optimizations: On
22:49:16: Base resolution: 1920x1080
22:49:16: Output resolution: 1280x720
22:49:16: ------------------------------------------
22:49:16: Loading up D3D10 on Intel(R) HD Graphics...
22:49:16: Playback device {0.0.0.00000000}.{fade5729-0994-4d0d-af7c-0796239bf0dd}
22:49:16: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
22:49:16: Using auxilary audio input: Microphone (3- Microsoft LifeCam VX-3000.)
22:49:16: Audio Encoding: AAC
22:49:16: bitrate: 96
22:49:16: device: Microsoft LifeCam VX-3000,
22:49:16: device id \\?\usb#vid_045e&pid_00f5&mi_00#7&2b5aefac&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
22:49:16: chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666, fourCC: 'I420'
22:49:16: audio device: Disable,
22:49:16: audio device id Disabled,
22:49:16:
22:49:16: Using directshow input
22:49:16: Using Monitor Capture
22:49:17: ------------------------------------------
22:49:17: Video Encoding: x264
22:49:17: fps: 30
22:49:17: width: 1280, height: 720
22:49:17: preset: veryfast
22:49:17: CBR: yes
22:49:17: CFR: no
22:49:17: max bitrate: 1000
22:49:17: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
22:49:17: MMDeviceAudioSource: Frequency for device 'Microphone (3- Microsoft LifeCam VX-3000.)' is 64000, samples per sec is 16000
22:49:19: Using RTMP service: Twitch / Justin.tv
22:49:19: Server selection: rtmp://live.justin.tv/app
22:49:19: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
22:49:19: SO_SNDBUF was at 65536
22:49:19: SO_SNDBUF is now 65536
22:49:22: Total frames rendered: 136, number of late frames: 2 (1.47%) (it's okay for some frames to be late)
22:49:23: RTMPPublisher::SocketLoop: Graceful loop exit
22:49:23: Number of times waited to send: 0, Waited for a total of 0 bytes
22:49:23: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:49:23:
22:49:23: Profiler results:
22:49:23:
22:49:23: ==============================================================
22:49:23: frame - [100%] [avg time: 5.612 ms (cpu time: avg 5.17 ms, total 703.125 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.143%]
22:49:23: | frame preprocessing and rendering - [41.2%] [avg time: 2.313 ms (cpu time: avg 2.297 ms, total 312.5 ms)] [avg calls per frame: 1] [children: 19%] [unaccounted: 22.2%]
22:49:23: | | scene->Preprocess - [19%] [avg time: 1.067 ms (cpu time: avg 0.919 ms, total 125 ms)] [avg calls per frame: 1]
22:49:23: | video encoding and uploading - [58.6%] [avg time: 3.291 ms (cpu time: avg 2.872 ms, total 390.625 ms)] [avg calls per frame: 1] [children: 57.2%] [unaccounted: 1.41%]
22:49:23: | | flush - [13.6%] [avg time: 0.762 ms (cpu time: avg 0.689 ms, total 93.75 ms)] [avg calls per frame: 1]
22:49:23: | | CopyResource - [1.66%] [avg time: 0.093 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:49:23: | | conversion to 4:2:0 - [1.07%] [avg time: 0.06 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:49:23: | | call to encoder - [40.6%] [avg time: 2.281 ms (cpu time: avg 2.068 ms, total 281.25 ms)] [avg calls per frame: 0]
22:49:23: | | sending stuff out - [0.285%] [avg time: 0.016 ms (cpu time: avg 0.114 ms, total 15.625 ms)] [avg calls per frame: 0]
22:49:23: | Convert444Threads - [1.08e+003%] [avg time: 60.761 ms (cpu time: avg 3.216 ms, total 437.5 ms)] [avg calls per frame: 1]
22:49:23:
22:49:23: =====Stream End: 2013-08-16, 22:49:23=================================================
