Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
CPU Speed: 3502MHz
Physical Memory: 7149MB Total, 3700MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
monitor 2: pos={-1680, -152}, size={1680, 1050}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 570
Video Adapter Dedicated Video Memory: 1293352960
Video Adapter Shared System Memory: 2952671232
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{93446ccc-62f6-4af1-bd9e-f5a960dff8cc}
Using desktop audio input: Speakers (USB Audio Device)
Using auxilary audio input: Microphone (USB Audio Device)
Audio Encoding: AAC
bitrate: 128
Using text output
Using text output
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264: profile High, level 3.2
Video Encoding: x264
fps: 60
width: 1280, height: 720
preset: medium
CBR: no
CFR: no
max bitrate: 2800
buffer size: 2800
quality: 10
New Scene
Using graphics capture
SharedTexCapture hooked
Server selection:
rtmp://live-ams.justin.tv/app
bufferTime: 1937, outputRateWindowTime: 1000, dropThreshold: 2437
Total frames rendered: 873, number of frames that lagged: 96 (11.00%) (it's okay for some frames to lag)
x264: frame I:4 Avg QP:19.71 size: 69385
x264: frame P:287 Avg QP:21.79 size: 8659
x264: frame B:498 Avg QP:23.87 size: 1224
x264: consecutive B-frames: 13.4% 5.6% 4.2% 76.9%
x264: mb I I16..4: 25.6% 51.3% 23.0%
x264: mb P I16..4: 1.1% 3.3% 0.5% P16..4: 33.0% 6.3% 3.7% 0.0% 0.0% skip:52.1%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 17.2% 0.7% 0.1% direct: 0.2% skip:81.8% L0:36.1% L1:62.2% BI: 1.6%
x264: 8x8 transform intra:63.4% inter:78.1%
x264: coded y,uvDC,uvAC intra: 51.9% 45.8% 16.6% inter: 6.2% 7.0% 0.6%
x264: i16 v,h,dc,p: 42% 22% 13% 23%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 13% 29% 8% 9% 6% 11% 5% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 20% 21% 7% 9% 7% 9% 5% 6%
x264: i8c dc,h,v,p: 65% 17% 13% 4%
x264: Weighted P-Frames: Y:12.9% UV:5.2%
x264: ref P L0: 61.7% 24.7% 10.2% 3.0% 0.4%
x264: ref B L0: 95.7% 3.5% 0.9%
x264: ref B L1: 96.7% 3.3%
x264: kb/s:1849.25
Profiler results:
frame - [100%] [avg time: 9.67 ms] [avg calls per frame: 1] [children: 73%] [unaccounted: 27%]
| scene->Preprocess - [0.672%] [avg time: 0.065 ms] [avg calls per frame: 1]
| video encoding and uploading - [72.3%] [avg time: 6.992 ms] [avg calls per frame: 1] [children: 25.6%] [unaccounted: 46.7%]
| | CopyResource - [0.29%] [avg time: 0.028 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0414%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [25.2%] [avg time: 2.438 ms] [avg calls per frame: 0]
| | sending stuff out - [0.103%] [avg time: 0.01 ms] [avg calls per frame: 0]
heres a 10 sec record.
