Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
CPU Speed: 3502MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 670
Video Adapter Dedicated Video Memory: 2091581440
Video Adapter Shared System Memory: 2147479552
Base resolution: 1920x1080
Output resolution: 852x480
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using graphics capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264: profile High, level 3.1
Video Encoding: x264
fps: 30
width: 852, height: 480
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
Server selection: rtmp://live-3c.justin.tv/app
SharedTexCapture hooked
bufferTime: 2330, outputRateWindowTime: 1000, dropThreshold: 2830
Total frames rendered: 18097, number of frames that lagged: 3 (0.02%) (it's okay for some frames to lag)
x264: frame I:90 Avg QP:21.81 size: 38724
x264: frame P:7328 Avg QP:25.87 size: 4972
x264: frame B:10641 Avg QP:27.84 size: 1218
x264: consecutive B-frames: 7.7% 39.1% 6.2% 47.0%
x264: mb I I16..4: 25.4% 27.5% 47.1%
x264: mb P I16..4: 7.8% 5.6% 1.1% P16..4: 22.0% 6.7% 2.8% 0.0% 0.0% skip:54.1%
x264: mb B I16..4: 0.5% 0.2% 0.1% B16..8: 6.6% 2.2% 0.4% direct: 2.0% skip:87.9% L0:32.4% L1:54.7% BI:12.9%
x264: 8x8 transform intra:37.0% inter:29.1%
x264: coded y,uvDC,uvAC intra: 38.2% 38.6% 17.2% inter: 5.5% 6.6% 1.3%
x264: i16 v,h,dc,p: 35% 27% 29% 9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 16% 48% 3% 6% 4% 5% 3% 6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 20% 22% 7% 8% 6% 8% 6% 7%
x264: i8c dc,h,v,p: 64% 18% 13% 4%
x264: Weighted P-Frames: Y:3.0% UV:1.6%
x264: kb/s:702.70
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
bufferTime: 2308, outputRateWindowTime: 1000, dropThreshold: 2808
Total frames rendered: 2716, number of frames that lagged: 1 (0.04%) (it's okay for some frames to lag)
x264: frame I:15 Avg QP:21.10 size: 35614
x264: frame P:1064 Avg QP:25.96 size: 6693
x264: frame B:1599 Avg QP:29.07 size: 1377
x264: consecutive B-frames: 5.2% 34.8% 32.4% 27.6%
x264: mb I I16..4: 26.6% 29.8% 43.6%
x264: mb P I16..4: 7.9% 6.3% 1.2% P16..4: 27.8% 9.1% 4.7% 0.0% 0.0% skip:43.1%
x264: mb B I16..4: 0.4% 0.2% 0.1% B16..8: 6.4% 2.5% 0.5% direct: 2.7% skip:87.1% L0:28.8% L1:55.7% BI:15.5%
x264: 8x8 transform intra:39.2% inter:30.5%
x264: coded y,uvDC,uvAC intra: 38.1% 42.0% 16.5% inter: 7.5% 10.3% 1.7%
x264: i16 v,h,dc,p: 36% 27% 29% 9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 19% 46% 3% 5% 3% 5% 3% 6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 22% 7% 8% 7% 8% 6% 7%
x264: i8c dc,h,v,p: 62% 19% 14% 5%
x264: Weighted P-Frames: Y:5.3% UV:2.6%
x264: kb/s:883.03
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
bufferTime: 2183, outputRateWindowTime: 1000, dropThreshold: 2683
Total frames rendered: 2065, number of frames that lagged: 1 (0.05%) (it's okay for some frames to lag)
x264: frame I:12 Avg QP:20.17 size: 32364
x264: frame P:790 Avg QP:24.60 size: 5715
x264: frame B:1225 Avg QP:27.36 size: 1398
x264: consecutive B-frames: 4.7% 39.6% 13.9% 41.8%
x264: mb I I16..4: 30.9% 29.3% 39.9%
x264: mb P I16..4: 7.8% 5.0% 1.2% P16..4: 24.5% 8.2% 3.5% 0.0% 0.0% skip:49.8%
x264: mb B I16..4: 0.5% 0.2% 0.1% B16..8: 8.5% 2.6% 0.5% direct: 2.1% skip:85.5% L0:30.7% L1:56.4% BI:12.9%
x264: 8x8 transform intra:34.4% inter:30.0%
x264: coded y,uvDC,uvAC intra: 38.6% 38.0% 14.1% inter: 6.4% 7.2% 1.3%
x264: i16 v,h,dc,p: 37% 26% 28% 8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 17% 46% 3% 6% 3% 6% 3% 6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 20% 22% 7% 8% 6% 8% 6% 7%
x264: i8c dc,h,v,p: 64% 18% 14% 4%
x264: Weighted P-Frames: Y:3.5% UV:1.5%
x264: kb/s:783.18
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
bufferTime: 2210, outputRateWindowTime: 1000, dropThreshold: 2710
Total frames rendered: 2844, number of frames that lagged: 2 (0.07%) (it's okay for some frames to lag)
x264: frame I:14 Avg QP:23.86 size: 21638
x264: frame P:1371 Avg QP:28.60 size: 5496
x264: frame B:1421 Avg QP:31.33 size: 2084
x264: consecutive B-frames: 5.4% 79.8% 3.5% 11.3%
x264: mb I I16..4: 42.4% 32.0% 25.7%
x264: mb P I16..4: 11.7% 7.7% 1.6% P16..4: 20.5% 6.9% 2.5% 0.0% 0.0% skip:49.0%
x264: mb B I16..4: 1.1% 0.5% 0.3% B16..8: 10.9% 3.6% 0.6% direct: 2.0% skip:81.2% L0:31.7% L1:56.3% BI:12.0%
x264: 8x8 transform intra:35.8% inter:25.5%
x264: coded y,uvDC,uvAC intra: 34.0% 33.6% 14.9% inter: 6.2% 7.5% 1.9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 15% 50% 3% 6% 4% 5% 3% 5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 18% 24% 7% 7% 7% 7% 6% 7%
x264: i8c dc,h,v,p: 66% 17% 13% 3%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:923.22
Output resolution: 1920x1080
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
x264: profile High, level 4.0
fps: 30
width: 1920, height: 1080
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
bufferTime: 2299, outputRateWindowTime: 1000, dropThreshold: 2799
Total frames rendered: 5312, number of frames that lagged: 3 (0.06%) (it's okay for some frames to lag)
x264: frame I:27 Avg QP:33.11 size: 30797
x264: frame P:3022 Avg QP:40.44 size: 5366
x264: frame B:2225 Avg QP:37.04 size: 1644
x264: consecutive B-frames: 30.8% 38.1% 2.7% 28.4%
x264: mb I I16..4: 63.0% 31.2% 5.7%
x264: mb P I16..4: 8.2% 4.7% 0.1% P16..4: 5.5% 0.9% 0.2% 0.0% 0.0% skip:80.3%
x264: mb B I16..4: 0.6% 0.3% 0.0% B16..8: 3.0% 0.4% 0.0% direct: 1.3% skip:94.3% L0:41.4% L1:54.9% BI: 3.7%
x264: 8x8 transform intra:35.5% inter:25.9%
x264: coded y,uvDC,uvAC intra: 16.0% 34.6% 8.8% inter: 0.7% 2.6% 0.2%
x264: i16 v,h,dc,p: 48% 28% 19% 6%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 6% 9% 72% 2% 3% 2% 3% 2% 3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 20% 23% 6% 7% 6% 6% 5% 5%
x264: i8c dc,h,v,p: 82% 10% 7% 1%
x264: Weighted P-Frames: Y:0.8% UV:0.7%
x264: kb/s:941.75
Profiler results:
frame - [100%] [avg time: 2.328 ms] [avg calls per frame: 1] [children: 80.4%] [unaccounted: 19.6%]
| scene->Preprocess - [0.129%] [avg time: 0.003 ms] [avg calls per frame: 1]
| video encoding and uploading - [80.3%] [avg time: 1.869 ms] [avg calls per frame: 1] [children: 34.3%] [unaccounted: 46%]
| | CopyResource - [0.687%] [avg time: 0.016 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.515%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | call to encoder - [32.6%] [avg time: 0.758 ms] [avg calls per frame: 0]
| | sending stuff out - [0.515%] [avg time: 0.012 ms] [avg calls per frame: 0]
