Question / Help Stream is choppy/hiccups, super low cpu usage. Not a hardware/connection issue
threefoldmisery
Using OBS on windows 10. Single pc setup.
Specs
9900k @ 5ghz
16gb 3600mhz ram
strix oc 2080 ti
I've never had this issue in the past with a much weaker PC. For some reason when I use display capture or game capture(anything really) the stream will be choppy and hiccup. I'm getting around 180-200 fps in the games I'm playing while streaming and cpu usage is pretty darn low. 10+ upload speed, no dropped frames.
Here's the settings I use for OBS
display capture(sometimes game capture)
720p @ 60fps. cbr 5000 fast preset
Will post a log shortly
edit: Tried NVENC, still getting the same issue.
Here is the log:
18:56:32.652: CPU Name: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
18:56:32.652: CPU Speed: 3600MHz
18:56:32.652: Physical Cores: 8, Logical Cores: 16
18:56:32.652: Physical Memory: 16302MB Total, 10958MB Free
18:56:32.652: Windows Version: 10.0 Build 17763 (revision: 194; 64-bit)
18:56:32.652: Running as administrator: false
18:56:32.652: Aero is Enabled (Aero is always on for windows 8 and above)
18:56:32.652: Windows 10 Gaming Features:
18:56:32.652: Game Bar: Off
18:56:32.652: Game DVR: Off
18:56:32.652: Game DVR Background Recording: Off
18:56:32.653: Sec. Software Status:
18:56:32.654: Windows Defender Antivirus: enabled (AV)
18:56:32.654: Windows Firewall: enabled (FW)
18:56:32.655: Windows Defender Antivirus: enabled (ASW)
18:56:32.655: Browser Hardware Acceleration: true
18:56:32.655: Portable mode: false
18:56:32.720: OBS 22.0.2 (64-bit, windows)
18:56:32.720: ---------------------------------
18:56:32.720: audio settings reset:
18:56:32.720: samples per sec: 44100
18:56:32.720: speakers: 2
18:56:32.728: ---------------------------------
18:56:32.728: Initializing D3D11...
18:56:32.728: Available Video Adapters:
18:56:32.729: Adapter 1: NVIDIA GeForce RTX 2080 Ti
18:56:32.729: Dedicated VRAM: 2995781632
18:56:32.729: Shared VRAM: 4252448768
18:56:32.729: output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:56:32.731: Loading up D3D11 on adapter NVIDIA GeForce RTX 2080 Ti (0)
18:56:32.768: D3D11 loaded successfully, feature level used: 45056
18:56:33.265: ---------------------------------
18:56:33.265: video settings reset:
18:56:33.265: base resolution: 1920x1080
18:56:33.265: output resolution: 1920x1080
18:56:33.265: downscale filter: Bicubic
18:56:33.265: fps: 60/1
18:56:33.265: format: NV12
18:56:33.265: YUV mode: 601/Partial
18:56:33.266: Audio monitoring device:
18:56:33.266: name: Default
18:56:33.266: id: default
18:56:33.266: ---------------------------------
18:56:33.307: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
18:56:33.310: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:56:33.354: [AMF] AMF Test failed due to one or more errors.
18:56:33.354: Failed to initialize module 'enc-amf.dll'
18:56:33.458: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
18:56:33.472: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
18:56:33.472: (127)
18:56:33.472: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
18:56:33.496: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
18:56:33.522: [obs-browser]: Version 2.1.5
18:56:33.546: NVENC supported
18:56:33.683: Couldn't find VLC installation, VLC video source disabled
18:56:33.699: No blackmagic support
18:56:33.718: ---------------------------------
18:56:33.718: Loaded Modules:
18:56:33.718: win-wasapi.dll
18:56:33.718: win-mf.dll
18:56:33.718: win-dshow.dll
18:56:33.718: win-decklink.dll
18:56:33.718: win-capture.dll
18:56:33.718: vlc-video.dll
18:56:33.718: text-freetype2.dll
18:56:33.718: rtmp-services.dll
18:56:33.718: obs-x264.dll
18:56:33.718: obs-vst.dll
18:56:33.718: obs-transitions.dll
18:56:33.718: obs-text.dll
18:56:33.718: obs-qsv11.dll
18:56:33.718: obs-outputs.dll
18:56:33.718: obs-filters.dll
18:56:33.718: obs-ffmpeg.dll
18:56:33.718: obs-browser.dll
18:56:33.718: image-source.dll
18:56:33.718: frontend-tools.dll
18:56:33.718: enc-amf.dll
18:56:33.718: coreaudio-encoder.dll
18:56:33.719: ==== Startup complete ===============================================
18:56:33.734: All scene data cleared
18:56:33.734: ------------------------------------------------
18:56:33.776: WASAPI: Device 'VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)' initialized
18:56:33.783: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
18:56:33.785: Switched to scene 'Scene'
18:56:33.786: ------------------------------------------------
18:56:33.786: Loaded scenes:
18:56:33.786: - scene 'Scene':
18:56:33.786: - source: 'Display Capture' (monitor_capture)
18:56:33.827: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
18:56:33.840: CalculateFileHash: Failed to open file 'C:\Users\three\AppData\Roaming\obs-studio\updates\whatsnew.json':
18:57:04.300: ---------------------------------
18:57:04.300: video settings reset:
18:57:04.300: base resolution: 1920x1080
18:57:04.300: output resolution: 1280x720
18:57:04.300: downscale filter: Bicubic
18:57:04.300: fps: 60/1
18:57:04.300: format: NV12
18:57:04.300: YUV mode: 601/Partial
18:57:04.310: Settings changed (video)
18:57:04.310: ------------------------------------------------
18:57:16.695: Settings changed (outputs)
18:57:16.695: ------------------------------------------------
18:57:59.451: ---------------------------------
18:57:59.451: video settings reset:
18:57:59.451: base resolution: 1920x1080
18:57:59.451: output resolution: 1280x720
18:57:59.451: downscale filter: Lanczos
18:57:59.451: fps: 60/1
18:57:59.451: format: NV12
18:57:59.451: YUV mode: 601/Partial
18:57:59.461: Settings changed (video)
18:57:59.461: ------------------------------------------------
19:01:51.395: Settings changed (outputs)
19:01:51.395: ------------------------------------------------
19:02:46.430: Settings changed (outputs)
19:02:46.430: ------------------------------------------------
19:03:31.151: ---------------------------------
19:03:31.153: [NVENC encoder: 'streaming_h264'] settings:
19:03:31.153: rate_control: CBR
19:03:31.153: bitrate: 5000
19:03:31.153: cqp: 0
19:03:31.153: keyint: 120
19:03:31.153: preset: hq
19:03:31.153: profile: high
19:03:31.153: level: auto
19:03:31.153: width: 1280
19:03:31.153: height: 720
19:03:31.153: 2-pass: true
19:03:31.153: b-frames: 2
19:03:31.153: GPU: 0
19:03:31.153:
19:03:31.493: ---------------------------------
19:03:31.493: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
19:03:31.493:
19:03:31.496: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-lax.twitch.tv/app...
19:03:31.518: [rtmp stream: 'adv_stream'] Interface: Intel(R) Ethernet Connection (7) I219-V (ethernet, 1000 mbps)
19:03:32.024: [rtmp stream: 'adv_stream'] Connection to rtmp://live-lax.twitch.tv/app successful
19:03:32.027: ==== Streaming Start ===============================================
19:05:31.820: [rtmp stream: 'adv_stream'] User stopped the stream
19:05:31.820: Output 'adv_stream': stopping
19:05:31.820: Output 'adv_stream': Total frames output: 7167
19:05:31.820: Output 'adv_stream': Total drawn frames: 6900 (7220 attempted)
19:05:31.820: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 320 (4.4%)
19:05:31.822: ==== Streaming Stop ================================================
Limit your framerate. OBS needs GPU resources to render the scene. If you're letting the GPU spend 100% utilization on the game, you'll encounter rendering lag.
Capped it at 144 and the issue still persists. Gpu never goes over 90%.
Even before on my older slightly weaker pc I would leave it uncapped and it would never be an issue
