DamianLIVE
OBS was working amazingly, but after I updated it, I was no longer able to record or livestream and the error message that kept coming up said: "Starting output failed. Please check the log for details. Note: If you are using NVENC or AMD encoders, make sure your drivers are up to date" I updated my drivers to the best version and it still doesn't work. I also tried almost everything that everyone else has been suggesting in the forums and still no luck. Any feedback is greatly appreciated!
Thank You :)
(btw I'm not that good with computers so i'm sorry if there is something very easy that I missed out)
Log:
20:14:00.959: [NVENC encoder: 'recording_h264'] settings:
20:14:00.959: rate_control: CBR
20:14:00.959: bitrate: 5000
20:14:00.959: cqp: 0
20:14:00.959: keyint: 120
20:14:00.959: preset: default
20:14:00.959: profile: main
20:14:00.959: level: auto
20:14:00.959: width: 1280
20:14:00.959: height: 720
20:14:00.959: 2-pass: true
20:14:00.959: b-frames: 2
20:14:00.959: GPU: 0
20:14:00.959:
20:14:00.962: [NVENC encoder: 'recording_h264'] Failed to open NVENC codec: Function not implemented
Thank You :)
Log:
20:14:00.959:
