Spotify music turns noisy/static using Application Audio Output Capture
Wurmfist
Added: Posting this again without the log file as my original post has been stuck in "admin pending" for over a day now...
Greetings - I did search for similar problems but I have come up empty.
After about an hour or so of streaming while using Spotify as a separate music source under the Application Audio Output Capture feature, spotify will turn staticy/noisy for viewers.
This does not happen with desktop audio. Only when using application audio output capture. And is consistently reproducible after about an hour or hour and half of streaming. Users complain of noise - closing and reopening spotify seems to reset the clock.
Has anyone else experienced this?
Apologies if this is posted in the wrong space. Thank you for helping if you can.
