Bug Report Sound problem
Bonom Denej
Hi,
I'm using OBS since a few weeks and I was very happy about it until today (well, I don't know exactly when it started) but I have a very annoying sound problem. I discovered that when I was done recording a DayZ video (the first one I make with OBS) and checking how the recording was. The sound was crappy and heavy in bass as you can see in that short video I just uploaded from StarCraft II :
http://youtu.be/yn_14iuun5s
I tried with many different settings, 720p, 1080p, different games... Didn't change anything.
Here is an other recording I made with the almost the same settings a week ago also on StarCraft II:
http://youtu.be/o5-cs6iQ5A8
On this one, the sound is perfectly normal. I didn't change anything inside OBS since that day. But I actually changed something in my computer since I had to send back my second graphic card (SLI) to customer service because it was defective. But I don't think it comes from this since I always turn off SLI when recording on StarCraft II since the game doesn't support at all SLI. On ArmA II tho I use SLI, but it's apparently not the source of the problem...
I hope I was clear, let me know if you want me to post some kind of log to help you out, I don't know what happened to kill the sound like this =/
EDIT
This is the log of the second link, the perfectly working video from february 26th :
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
CPU Speed: 2673MHz
Physical Memory:  8182MB Total, 5888MB Free
stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
Windows Version: 6.2 Build 9200
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 570
  Video Adapter Dedicated Video Memory: 1293352960
  Video Adapter Shared System Memory: 2952343552
Adapter 2
  Video Adapter Dedicated Video Memory: 1293484032
Adapter 3
  Video Adapter: Microsoft Basic Render Driver
  Video Adapter Dedicated Video Memory: 0
  Video Adapter Shared System Memory: 268435456
  Base resolution: 1920x1080
  Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{eaeda7a8-9c20-44f6-b910-6e98f3adde09}
Using desktop audio input: Haut-parleurs et casque (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Périphérique audio USB)
Audio Encoding: AAC
    bitrate: 192
Using Monitor Capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264: profile High, level 3.2
Video Encoding: x264
    fps: 60
    width: 1280, height: 720
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Total frames rendered: 433, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:22.98  size: 51485
x264: frame P:132   Avg QP:25.72  size:  8679
x264: frame B:240   Avg QP:30.87  size:  1837
x264: consecutive B-frames:  9.6% 10.2% 12.8% 67.4%
x264: mb I  I16..4: 43.0% 20.2% 36.8%
x264: mb P  I16..4: 10.8%  0.6%  1.7%  P16..4: 11.6%  6.3%  2.3%  0.0%  0.0%    skip:66.7%
x264: mb B  I16..4:  2.3%  0.1%  0.1%  B16..8:  6.4%  3.1%  0.2%  direct: 1.2%  skip:86.7%  L0:41.6% L1:43.5% BI:14.9%
x264: 8x8 transform intra:5.4% inter:26.1%
x264: coded y,uvDC,uvAC intra: 24.1% 32.1% 18.6% inter: 3.5% 2.2% 0.5%
x264: i16 v,h,dc,p: 42% 55%  2%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 31% 32%  3%  4%  3%  4%  2%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 44% 15%  1%  2%  2%  2%  1%  3%
x264: i8c dc,h,v,p: 26% 47% 26%  1%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:2168.27
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
  New Scene
Using graphics capture
  New Scene
    device: Microsoft® LifeCam VX-7000,
    device id \\?\usb#vid_045e&pid_0723&mi_00#7&20ff9e61&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
    chosen type: MJPG, usingFourCC: false, res: 640x480 - 640x480, fps: 30-30, fourCC: 'MJPG'
Using directshow input
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Warning -- D3D10Texture::CreateFromFile: Could not get information about texture file 'D:\Mes images\Créations\YouTube\DayZ - Surcouche Map.png'
Warning -- BitmapImageSource::UpdateSettings: could not create texture 'D:\Mes images\Créations\YouTube\DayZ - Surcouche Map.png'
Using bitmap image
Using Window Capture
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Total frames rendered: 12150, number of frames that lagged: 24 (0.20%) (it's okay for some frames to lag)
x264: frame I:52    Avg QP:16.82  size: 35024
x264: frame P:3155  Avg QP:19.81  size:   707
x264: frame B:8884  Avg QP:20.84  size:    79
x264: consecutive B-frames:  1.8%  0.4%  0.5% 97.3%
x264: mb I  I16..4: 77.2%  5.0% 17.8%
x264: mb P  I16..4:  0.8%  0.1%  0.1%  P16..4:  1.3%  0.4%  0.2%  0.0%  0.0%    skip:97.2%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.2%  0.1%  0.0%  direct: 0.0%  skip:99.6%  L0:41.8% L1:49.0% BI: 9.3%
x264: 8x8 transform intra:7.4% inter:28.2%
x264: coded y,uvDC,uvAC intra: 20.7% 21.9% 14.6% inter: 0.2% 0.2% 0.0%
x264: i16 v,h,dc,p: 74% 22%  3%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 31% 25%  4%  4%  4%  4%  3%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 31% 13%  5%  5%  5%  5%  5%  6%
x264: i8c dc,h,v,p: 68% 18% 12%  1%
x264: Weighted P-Frames: Y:1.0% UV:1.0%
x264: kb/s:187.33
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
Using bitmap image
Using bitmap image
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Using bitmap image
Total frames rendered: 8411, number of frames that lagged: 1 (0.01%) (it's okay for some frames to lag)
x264: frame I:34    Avg QP:23.26  size:137793
x264: frame P:2413  Avg QP:25.39  size:  3733
x264: frame B:5905  Avg QP:29.30  size:   347
x264: consecutive B-frames:  4.1%  4.0%  2.9% 89.1%
x264: mb I  I16..4: 35.8%  5.0% 59.3%
x264: mb P  I16..4:  3.7%  0.1%  0.5%  P16..4:  4.8%  1.8%  1.0%  0.0%  0.0%    skip:88.2%
x264: mb B  I16..4:  0.3%  0.0%  0.0%  B16..8:  1.0%  0.4%  0.0%  direct: 0.3%  skip:97.9%  L0:39.5% L1:44.0% BI:16.5%
x264: 8x8 transform intra:2.7% inter:23.1%
x264: coded y,uvDC,uvAC intra: 28.6% 24.7% 20.4% inter: 1.2% 0.7% 0.3%
x264: i16 v,h,dc,p: 42% 57%  1%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 47% 21%  3%  2%  2%  2%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 32% 12%  5%  5%  5%  5%  5%  7%
x264: i8c dc,h,v,p: 40% 40% 18%  1%
x264: Weighted P-Frames: Y:0.2% UV:0.2%
x264: kb/s:904.64
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
Using bitmap image
Using bitmap image
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
SharedTexCapture hooked
Total frames rendered: 1617, number of frames that lagged: 18 (1.11%) (it's okay for some frames to lag)
x264: frame I:7     Avg QP:20.85  size: 43607
x264: frame P:429   Avg QP:22.68  size:  1073
x264: frame B:1122  Avg QP:26.33  size:    65
x264: consecutive B-frames:  3.8%  0.3%  0.4% 95.6%
x264: mb I  I16..4: 61.1% 13.0% 25.9%
x264: mb P  I16..4:  1.2%  0.2%  0.2%  P16..4:  2.3%  0.5%  0.2%  0.0%  0.0%    skip:95.4%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.2%  0.0%  0.0%  direct: 0.1%  skip:99.7%  L0:46.9% L1:49.8% BI: 3.3%
x264: 8x8 transform intra:12.9% inter:23.8%
x264: coded y,uvDC,uvAC intra: 29.4% 28.4% 18.3% inter: 0.2% 0.3% 0.0%
x264: i16 v,h,dc,p: 65% 29%  4%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 32% 26%  4%  5%  4%  6%  2%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 35% 13%  3%  4%  4%  5%  3%  5%
x264: i8c dc,h,v,p: 65% 22% 11%  2%
x264: kb/s:252.24
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
Using bitmap image
Using bitmap image
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Total frames rendered: 2553, number of frames that lagged: 7 (0.27%) (it's okay for some frames to lag)
x264: frame I:11    Avg QP:20.83  size: 68603
x264: frame P:754   Avg QP:22.18  size:  1736
x264: frame B:1729  Avg QP:26.13  size:    78
x264: consecutive B-frames:  7.5%  0.2%  0.2% 92.1%
x264: mb I  I16..4: 38.5% 21.3% 40.2%
x264: mb P  I16..4:  0.8%  0.2%  0.1%  P16..4:  4.9%  1.0%  0.5%  0.0%  0.0%    skip:92.4%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.2%  0.0%  0.0%  direct: 0.1%  skip:99.6%  L0:43.1% L1:47.2% BI: 9.7%
x264: 8x8 transform intra:19.5% inter:24.4%
x264: coded y,uvDC,uvAC intra: 44.1% 40.5% 26.7% inter: 0.7% 0.4% 0.0%
x264: i16 v,h,dc,p: 42% 46%  9%  4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 34% 26%  4%  4%  3%  5%  2%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 36% 11%  4%  4%  4%  5%  3%  6%
x264: i8c dc,h,v,p: 52% 31% 15%  3%
x264: Weighted P-Frames: Y:0.8% UV:0.0%
x264: kb/s:418.01
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
Using bitmap image
Using bitmap image
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Total frames rendered: 2430, number of frames that lagged: 8 (0.33%) (it's okay for some frames to lag)
x264: frame I:11    Avg QP:17.75  size: 52517
x264: frame P:1116  Avg QP:20.85  size:  3677
x264: frame B:1244  Avg QP:26.35  size:    59
x264: consecutive B-frames: 29.9%  0.2%  0.0% 69.9%
x264: mb I  I16..4: 38.1% 29.6% 32.3%
x264: mb P  I16..4:  0.6%  0.2%  0.0%  P16..4: 11.4%  2.1%  1.1%  0.0%  0.0%    skip:84.6%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.1%  skip:99.8%  L0:30.1% L1:59.0% BI:10.9%
x264: 8x8 transform intra:27.3% inter:25.6%
x264: coded y,uvDC,uvAC intra: 38.3% 27.2% 14.3% inter: 3.1% 0.3% 0.0%
x264: i16 v,h,dc,p: 44% 35% 13%  9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  9% 35% 29%  5%  5%  4%  6%  1%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 32% 12%  5%  6%  4% 10%  3%  9%
x264: i8c dc,h,v,p: 68% 23%  8%  2%
x264: Weighted P-Frames: Y:0.1% UV:0.0%
x264: kb/s:949.86
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Total frames rendered: 10268, number of frames that lagged: 27 (0.26%) (it's okay for some frames to lag)
x264: frame I:45    Avg QP:20.06  size: 78557
x264: frame P:2659  Avg QP:23.61  size:  1558
x264: frame B:7505  Avg QP:27.62  size:   120
x264: consecutive B-frames:  1.8%  0.4%  0.4% 97.4%
x264: mb I  I16..4: 56.5%  5.1% 38.4%
x264: mb P  I16..4:  1.6%  0.2%  0.3%  P16..4:  2.5%  0.7%  0.4%  0.0%  0.0%    skip:94.4%
x264: mb B  I16..4:  0.2%  0.0%  0.0%  B16..8:  0.4%  0.1%  0.0%  direct: 0.1%  skip:99.3%  L0:40.2% L1:48.7% BI:11.1%
x264: 8x8 transform intra:7.0% inter:29.3%
x264: coded y,uvDC,uvAC intra: 28.5% 24.6% 18.4% inter: 0.4% 0.3% 0.1%
x264: i16 v,h,dc,p: 51% 45%  3%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 36% 26%  4%  2%  2%  3%  4%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 35% 10%  5%  4%  4%  5%  5%  6%
x264: i8c dc,h,v,p: 70% 19% 10%  1%
x264: Weighted P-Frames: Y:1.2% UV:0.9%
x264: kb/s:399.00
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 192
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
  New Scene
Using bitmap image
Using bitmap image
  New Scene
  New Scene
Using bitmap image
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Using bitmap image
  New Scene
Using bitmap image
Using bitmap image
  New Scene
Total frames rendered: 29798, number of frames that lagged: 30 (0.10%) (it's okay for some frames to lag)
x264: frame I:122   Avg QP:18.98  size: 48069
x264: frame P:7927  Avg QP:21.21  size:  1405
x264: frame B:21690 Avg QP:22.81  size:   107
x264: consecutive B-frames:  2.4%  0.9%  0.9% 95.9%
x264: mb I  I16..4: 64.5% 10.0% 25.6%
x264: mb P  I16..4:  0.8%  0.2%  0.2%  P16..4:  1.7%  0.6%  0.3%  0.0%  0.0%    skip:96.2%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.3%  0.1%  0.0%  direct: 0.1%  skip:99.5%  L0:42.2% L1:47.2% BI:10.6%
x264: 8x8 transform intra:11.5% inter:23.0%
x264: coded y,uvDC,uvAC intra: 32.4% 30.7% 20.4% inter: 0.3% 0.2% 0.1%
x264: i16 v,h,dc,p: 63% 32%  3%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 26% 24%  5%  5%  4%  5%  4%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 31% 14%  5%  5%  5%  6%  4%  6%
x264: i8c dc,h,v,p: 59% 25% 14%  2%
x264: Weighted P-Frames: Y:0.7% UV:0.5%
x264: kb/s:310.69
Profiler results:
frame - [100%] [avg time: 3.61 ms] [avg calls per frame: 1] [children: 88%] [unaccounted: 12%]
| scene->Preprocess - [5.32%] [avg time: 0.192 ms] [avg calls per frame: 1]
| video encoding and uploading - [82.7%] [avg time: 2.986 ms] [avg calls per frame: 1] [children: 40.7%] [unaccounted: 42%]
| | CopyResource - [0.332%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0554%] [avg time: 0.002 ms] [avg calls per frame: 0]
| | call to encoder - [40.2%] [avg time: 1.453 ms] [avg calls per frame: 0]
| | sending stuff out - [0.111%] [avg time: 0.004 ms] [avg calls per frame: 0]
And this is the one from the short failed recording I uploaded earlier today :
CPU Speed: 2673MHz
Physical Memory:  8182MB Total, 4922MB Free
Aero is Enabled
Adapter 1
Adapter 2
  Output resolution: 1920x1080
Loading up D3D10...
Using auxilary audio input: Microphone (5- Périphérique audio USB)
Audio Encoding: AAC
    bitrate: 192
Using bitmap image
Using bitmap image
x264: profile High, level 4.0
    fps: 30
    width: 1920, height: 1080
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 20000
    buffer size: 20000
    quality: 10
Syncing audio to video time
Total frames rendered: 3943, number of frames that lagged: 9 (0.23%) (it's okay for some frames to lag)
x264: frame I:24    Avg QP:19.38  size:285779
x264: frame P:1216  Avg QP:20.60  size: 26324
x264: frame B:2659  Avg QP:24.54  size:  1521
x264: consecutive B-frames:  7.0%  5.7%  1.2% 86.1%
x264: mb I  I16..4: 29.7% 13.2% 57.2%
x264: mb P  I16..4:  1.4%  0.9%  0.7%  P16..4: 14.0%  3.7%  3.0%  0.0%  0.0%    skip:76.4%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.9%  0.4%  0.1%  direct: 0.7%  skip:97.8%  L0:32.3% L1:43.8% BI:23.9%
x264: 8x8 transform intra:22.4% inter:23.6%
x264: coded y,uvDC,uvAC intra: 67.4% 31.8% 15.7% inter: 3.8% 0.9% 0.1%
x264: i16 v,h,dc,p: 43% 35% 17%  4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 13% 31%  8%  7%  8%  6%  8%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 16% 14%  9%  9%  9%  7%  9%  9%
x264: Weighted P-Frames: Y:1.2% UV:1.2%
x264: kb/s:2634.93
Profiler results:
frame - [100%] [avg time: 6.686 ms] [avg calls per frame: 1] [children: 92%] [unaccounted: 8.03%]
| scene->Preprocess - [0.0449%] [avg time: 0.003 ms] [avg calls per frame: 1]
| video encoding and uploading - [91.9%] [avg time: 6.146 ms] [avg calls per frame: 1] [children: 54.8%] [unaccounted: 37.1%]
| | CopyResource - [0.344%] [avg time: 0.023 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0598%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [54.2%] [avg time: 3.621 ms] [avg calls per frame: 0]
| | sending stuff out - [0.254%] [avg time: 0.017 ms] [avg calls per frame: 0]
Lain
Forum Admin
Lain
Forum Moderator
Developer
I unfortunately don't have any answers.. Some sound devices have specific equalizer control panels, though I doubt realtek does.
I'll see what I can do about a workaround for this and various other things
Bonom Denej
Well... That's awkward but apparently, I just rebooted my computer and it now works fine again. I really don't know what happened. I'll let you know if it happens again.
