Sound is not currently working.
StellarStudios
Hello, i was going to record but for some reason whenever obs studio is open the sound is being picked up, but its muted through my headphones. I have looked at other threads but the solutions aren't working for me. Here is the most recent log if it helps.
13:25:11.216: CPU Name: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
13:25:11.216: CPU Speed: 2400MHz
13:25:11.216: Physical Cores: 2, Logical Cores: 4
13:25:11.216: Physical Memory: 8064MB Total, 3634MB Free
13:25:11.216: Windows Version: 10.0 Build 19043 (release: 2009; revision: 1566; 64-bit)
13:25:11.216: Running as administrator: false
13:25:11.216: Aero is Enabled (Aero is always on for windows 8 and above)
13:25:11.216: Windows 10 Gaming Features:
13:25:11.216: Game Bar: Off
13:25:11.216: Game DVR: Off
13:25:11.216: Game DVR Background Recording: Off
13:25:11.219: Sec. Software Status:
13:25:11.221: Microsoft Defender Antivirus: enabled (AV)
13:25:11.222: Windows Firewall: enabled (FW)
13:25:11.222: Current Date/Time: 2022-02-23, 13:25:11
13:25:11.222: Browser Hardware Acceleration: true
13:25:11.222: Hide OBS windows from screen capture: false
13:25:11.222: Qt Version: 5.15.2 (runtime), 5.15.2 (compiled)
13:25:11.222: Portable mode: false
13:25:11.653: OBS 27.2.1 (64-bit, windows)
13:25:11.653: ---------------------------------
13:25:11.685: ---------------------------------
13:25:11.685: audio settings reset:
13:25:11.685: samples per sec: 48000
13:25:11.685: speakers: 2
13:25:11.687: ---------------------------------
13:25:11.687: Initializing D3D11...
13:25:11.687: Available Video Adapters:
13:25:11.689: Adapter 0: Intel(R) HD Graphics 620
13:25:11.689: Dedicated VRAM: 134217728
13:25:11.689: Shared VRAM: 4228155392
13:25:11.689: PCI ID: 8086:5916
13:25:11.691: Driver Version: 22.20.16.4749
13:25:11.692: output 0:
13:25:11.692: name=
13:25:11.692: pos={0, 0}
13:25:11.692: size={1600, 900}
13:25:11.692: attached=true
13:25:11.692: refresh=60
13:25:11.692: space=RGB_FULL_G22_NONE_P709
13:25:11.692: sdr_white_nits=80
13:25:11.692: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
13:25:11.692: output 1:
13:25:11.692: name=E20
13:25:11.692: pos={1600, 0}
13:25:11.692: refresh=59
13:25:11.695: Loading up D3D11 on adapter Intel(R) HD Graphics 620 (0)
13:25:11.709: D3D11 loaded successfully, feature level used: b000
13:25:11.709: DXGI increase maximum frame latency success
13:25:12.489: ---------------------------------
13:25:12.489: video settings reset:
13:25:12.489: base resolution: 1600x900
13:25:12.489: output resolution: 1280x720
13:25:12.489: downscale filter: Bilinear
13:25:12.489: fps: 30/1
13:25:12.489: format: NV12
13:25:12.489: YUV mode: 709/Partial
13:25:12.489: NV12 texture support not available
13:25:12.490: Audio monitoring device:
13:25:12.490: name: Headphones (MPOW-059 Stereo)
13:25:12.490: id: {0.0.0.00000000}.{0e36e577-8ada-4c38-9b3c-221fe7038f66}
13:25:12.490: ---------------------------------
13:25:12.496: No AJA devices found, skipping loading AJA UI plugin
13:25:12.496: Failed to initialize module 'aja-output-ui.dll'
13:25:12.497: No AJA devices found, skipping loading AJA plugin
13:25:12.497: Failed to initialize module 'aja.dll'
13:25:12.498: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
13:25:12.508: [CoreAudio encoder]: Adding CoreAudio AAC encoder
13:25:12.509: Failed to load 'en-US' text for module: 'decklink-captions.dll'
13:25:12.510: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
13:25:12.647: [AMF] Unable to load 'amfrt64.dll', error code 126.
13:25:12.650: [AMF] AMF Test failed due to one or more errors.
13:25:12.650: Failed to initialize module 'enc-amf.dll'
13:25:12.671: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
13:25:12.672: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
13:25:12.672: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
13:25:12.712: [obs-browser]: Version 2.17.13
13:25:12.712: [obs-browser]: CEF Version 95.0.0-MediaHandler.2467+g8092a57+chromium-95.0.4638.69
13:25:12.722: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
13:25:12.804: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
13:25:12.815: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
13:25:12.816: No blackmagic support
13:25:12.828: ---------------------------------
13:25:12.828: Loaded Modules:
13:25:12.828: win-wasapi.dll
13:25:12.828: win-mf.dll
13:25:12.828: win-dshow.dll
13:25:12.828: win-decklink.dll
13:25:12.828: win-capture.dll
13:25:12.828: vlc-video.dll
13:25:12.828: text-freetype2.dll
13:25:12.828: rtmp-services.dll
13:25:12.828: obs-x264.dll
13:25:12.828: obs-vst.dll
13:25:12.828: obs-transitions.dll
13:25:12.828: obs-text.dll
13:25:12.828: obs-qsv11.dll
13:25:12.828: obs-outputs.dll
13:25:12.828: obs-filters.dll
13:25:12.828: obs-ffmpeg.dll
13:25:12.828: obs-browser.dll
13:25:12.828: image-source.dll
13:25:12.828: frontend-tools.dll
13:25:12.828: decklink-ouput-ui.dll
13:25:12.828: decklink-captions.dll
13:25:12.828: coreaudio-encoder.dll
13:25:12.828: ==== Startup complete ===============================================
13:25:12.895: All scene data cleared
13:25:12.895: ------------------------------------------------
13:25:12.916: [win-wasapi: 'Desktop Audio'] update settings:
13:25:12.916: device id: default
13:25:12.916: use device timing: 1
13:25:12.992: [Loaded global audio device]: 'Desktop Audio'
13:25:12.993: [win-wasapi: 'Mic/Aux'] update settings:
13:25:12.993: device id: {0.0.1.00000000}.{133642af-8d2e-4690-9016-91a8b9a1b5d5}
13:25:12.993: use device timing: 0
13:25:12.993: [Loaded global audio device]: 'Mic/Aux'
13:25:12.994: [win-wasapi: 'Audio Output Capture'] update settings:
13:25:12.994: device id: {0.0.0.00000000}.{0e36e577-8ada-4c38-9b3c-221fe7038f66}
13:25:12.994: use device timing: 1
13:25:12.997: [duplicator-monitor-capture: 'pc screen'] update settings:
13:25:12.997: display: 1 (1600x900)
13:25:12.997: cursor: true
13:25:12.997: method: DXGI
13:25:13.004: [win-wasapi: 'Audio Input Capture'] update settings:
13:25:13.004: device id: default
13:25:13.004: use device timing: 0
13:25:13.008: Switched to scene 'Scene'
13:25:13.008: ------------------------------------------------
13:25:13.008: Loaded scenes:
13:25:13.008: - scene 'Scene':
13:25:13.008: - source: 'pc screen' (monitor_capture)
13:25:13.009: - source: 'Audio Output Capture' (wasapi_output_capture)
13:25:13.009: - source: 'Audio Input Capture' (wasapi_input_capture)
13:25:13.009: ------------------------------------------------
13:25:13.066: WASAPI: Device 'Headphones (MPOW-059 Stereo)' [44100 Hz] initialized
13:25:13.086: WASAPI: Device 'Headphones (MPOW-059 Stereo)' [44100 Hz] initialized
13:25:13.194: WASAPI: Device 'Microphone (Realtek High Definition Audio)' [48000 Hz] initialized
13:25:13.209: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Mic/Aux)
13:25:13.209:
13:25:13.765: WASAPI: Device 'Headset (MPOW-059 Hands-Free AG Audio)' [8000 Hz] initialized
13:25:36.210: ---------------------------------
13:25:36.210: [x264 encoder: 'simple_h264_stream'] preset: ultrafast
13:25:36.210: [x264 encoder: 'simple_h264_stream'] settings:
13:25:36.210: rate_control: CBR
13:25:36.210: bitrate: 2400
13:25:36.210: buffer size: 2400
13:25:36.210: crf: 23
13:25:36.210: fps_num: 30
13:25:36.210: fps_den: 1
13:25:36.210: width: 1280
13:25:36.210: height: 720
13:25:36.210: keyint: 60
13:25:36.210:
13:25:36.222: [CoreAudio AAC: 'simple_aac']: settings:
13:25:36.222: mode: AAC
13:25:36.222: bitrate: 128
13:25:36.222: sample rate: 48000
13:25:36.222: cbr: on
13:25:36.222: output buffer: 1536
13:25:36.271: ==== Recording Start ===============================================
13:25:36.271: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Sarah/Videos/2022-02-23 13-25-36.mkv'...
13:25:38.776: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Sarah/Videos/2022-02-23 13-25-36.mkv' stopped
13:25:38.776: Output 'simple_file_output': stopping
13:25:38.776: Output 'simple_file_output': Total frames output: 68
13:25:38.776: Output 'simple_file_output': Total drawn frames: 75
13:25:38.777: ==== Recording Stop ================================================
13:25:46.933: ---------------------------------
13:25:46.934: [x264 encoder: 'simple_h264_stream'] preset: ultrafast
13:25:46.934: [x264 encoder: 'simple_h264_stream'] settings:
13:25:46.934: rate_control: CBR
13:25:46.934: bitrate: 2400
13:25:46.934: buffer size: 2400
13:25:46.934: crf: 23
13:25:46.934: fps_num: 30
13:25:46.934: fps_den: 1
13:25:46.934: width: 1280
13:25:46.934: height: 720
13:25:46.934: keyint: 60
13:25:46.934:
13:25:46.948: [CoreAudio AAC: 'simple_aac']: settings:
13:25:46.948: mode: AAC
13:25:46.948: bitrate: 128
13:25:46.948: sample rate: 48000
13:25:46.948: cbr: on
13:25:46.948: output buffer: 1536
13:25:46.967: ==== Recording Start ===============================================
13:25:46.967: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Sarah/Videos/2022-02-23 13-25-46.mkv'...
13:25:57.756: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Sarah/Videos/2022-02-23 13-25-46.mkv' stopped
13:25:57.756: Output 'simple_file_output': stopping
13:25:57.756: Output 'simple_file_output': Total frames output: 316
13:25:57.756: Output 'simple_file_output': Total drawn frames: 323
13:25:57.757: ==== Recording Stop ================================================
problem is the bluetooth headset try to route it over voicemeter. wireless bluetooth headsets make many problems !
