Hello,
Does anyone have much experience with the Behringer Xair18 system and getting good sound via the usb? (I have windows 11 computer). I have the system connected to the computer via usb with a long cord (>50 ft) and I am using a usb extender with ethernet cable. (I tried just the usb cable without the extender first, but it did the same thing described below and I read because it was a long cord I needed the extender to help drive the sound as a fix, but it did not work).
OSB recognizes the Xair18 system, and I have it set to the Mic/Aux, and the sound bar moves some (barely gets past -40), but the sound is very low.
I have updated the drivers for the Behringer xair18 and I have looked at several setups on different forums and cannot figure it out.
When I go into the settings on my computer under "sound" and specifically "input" the Behringer Xair 18 shows up but when I check the input setting and "test the microphone" it only shows 1% to 6% of total volume.
Any help or advice would be greatly appreciated.
Thanks
Thanks
