Question / Help Sound delay, friend needs help.
Soulkeeperx78
Well friend of mine is attempting to stream, her settings to my eyes are ok (Granted I'm very very new.)
I watched her stream and did notice a 3sec or so sound delay which she cant seem to fix. Told her to link her logs of it, if some one can see this 'sound delay' problem it would be grateful for the help.
Heres the video which is linked to this log http://www.twitch.tv/arracor/b/432670324
02:54:13: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
02:54:13: -------------------------------
02:54:13: CPU Name: AMD Phenom(tm) II X4 810 Processor
02:54:13: CPU Speed: 2600MHz
02:54:13: Physical Memory: 3319MB Total, 1741MB Free
02:54:13: stepping id: 2, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
02:54:13: monitor 1: pos={0, 0}, size={1600, 900}
02:54:13: Windows Version: 6.1 Build 7600
02:54:13: Aero is Disabled
02:54:13: OBS Modules:
02:54:13: Base Address Module
02:54:13: 01350000 OBS.exe
02:54:13: 5BB40000 OBSApi.dll
02:54:13: 726A0000 DShowPlugin.dll
02:54:13: 72680000 GraphicsCapture.dll
02:54:13: 72660000 NoiseGate.dll
02:54:13: 72640000 PSVPlugin.dll
02:54:13: ------------------------------------------
02:54:13: Adapter 1
02:54:13: Video Adapter: ATI Radeon HD 5700 Series
02:54:13: Video Adapter Dedicated Video Memory: 1067024384
02:54:13: Video Adapter Shared System Memory: 1472143360
02:54:13: =====Stream Start: 2013-07-19, 02:54:13===============================================
02:54:13: Multithreaded optimizations: On
02:54:13: Base resolution: 1600x900
02:54:13: Output resolution: 1600x900
02:54:13: Loading up D3D10...
02:54:13: Playback device Default
02:54:13: Using desktop audio input: Speakers (High Definition Audio Device)
02:54:13: Audio Encoding: AAC
02:54:13: bitrate: 128
02:54:13: Video Encoding: x264
02:54:13: fps: 30
02:54:13: width: 1600, height: 900
02:54:13: preset: veryfast
02:54:13: CBR: yes
02:54:13: CFR: no
02:54:13: max bitrate: 1000
02:54:15: Using RTMP service: Twitch / Justin.tv
02:54:15: Server selection: rtmp://live.justin.tv/app
02:54:16: SO_SNDBUF was at 8192
02:54:16: SO_SNDBUF is now 65536
02:55:02: Total frames rendered: 1453, number of frames that lagged: 1 (0.07%) (it's okay for some frames to lag)
02:55:02: RTMPPublisher::SocketLoop: Aborting due to bStopping
02:55:02: Number of times waited to send: 0, Waited for a total of 0 bytes
02:55:02: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:55:02: =====Stream End: 2013-07-19, 02:55:02=================================================
02:55:10: =====Stream Start: 2013-07-19, 02:55:10===============================================
02:55:10: Multithreaded optimizations: On
02:55:10: Base resolution: 1600x900
02:55:10: Output resolution: 1600x900
02:55:10: ------------------------------------------
02:55:10: Loading up D3D10...
02:55:10: Playback device Default
02:55:10: Using desktop audio input: Speakers (High Definition Audio Device)
02:55:10: Audio Encoding: AAC
02:55:10: bitrate: 128
02:55:10: Video Encoding: x264
02:55:10: fps: 30
02:55:10: width: 1600, height: 900
02:55:10: preset: veryfast
02:55:10: CBR: yes
02:55:10: CFR: no
02:55:10: max bitrate: 1000
02:55:12: Using RTMP service: Twitch / Justin.tv
02:55:12: Server selection: rtmp://live.justin.tv/app
02:55:12: SO_SNDBUF was at 8192
02:55:12: SO_SNDBUF is now 65536
02:57:05: Total frames rendered: 3446, number of frames that lagged: 2 (0.06%) (it's okay for some frames to lag)
02:57:05: RTMPPublisher::SocketLoop: Aborting due to bStopping
02:57:05: Number of times waited to send: 0, Waited for a total of 0 bytes
02:57:05: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:57:05: =====Stream End: 2013-07-19, 02:57:05=================================================
02:57:07: =====Stream Start: 2013-07-19, 02:57:07===============================================
02:57:07: Multithreaded optimizations: On
02:57:07: Base resolution: 1600x900
02:57:07: Output resolution: 1280x720
02:57:07: ------------------------------------------
02:57:07: Loading up D3D10...
02:57:07: Playback device Default
02:57:07: Using desktop audio input: Speakers (High Definition Audio Device)
02:57:07: Audio Encoding: AAC
02:57:07: bitrate: 128
02:57:07: Video Encoding: x264
02:57:07: fps: 30
02:57:07: width: 1280, height: 720
02:57:07: preset: veryfast
02:57:07: CBR: yes
02:57:07: CFR: no
02:57:07: max bitrate: 1000
02:57:09: Using RTMP service: Twitch / Justin.tv
02:57:09: Server selection: rtmp://live.justin.tv/app
02:57:10: SO_SNDBUF was at 8192
02:57:10: SO_SNDBUF is now 65536
02:59:40: Total frames rendered: 4563, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
02:59:40: RTMPPublisher::SocketLoop: Aborting due to bStopping
02:59:40: Number of times waited to send: 0, Waited for a total of 0 bytes
02:59:40: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:59:40: =====Stream End: 2013-07-19, 02:59:40=================================================
03:00:48: =====Stream Start: 2013-07-19, 03:00:48===============================================
03:00:48: Multithreaded optimizations: On
03:00:48: Base resolution: 1600x128
03:00:48: Output resolution: 1600x128
03:00:48: ------------------------------------------
03:00:49: Loading up D3D10...
03:00:49: Playback device Default
03:00:49: ------------------------------------------
03:00:49: Using desktop audio input: Speakers (High Definition Audio Device)
03:00:49: Audio Encoding: AAC
03:00:49: bitrate: 128
03:00:49: Using Window Capture
03:00:49: Video Encoding: x264
03:00:49: fps: 30
03:00:49: width: 1600, height: 128
03:00:49: preset: veryfast
03:00:49: CBR: yes
03:00:49: CFR: no
03:00:49: max bitrate: 1000
03:00:50: Using RTMP service: Twitch / Justin.tv
03:00:50: Server selection: rtmp://live.justin.tv/app
03:00:51: SO_SNDBUF was at 8192
03:00:51: SO_SNDBUF is now 65536
03:01:40: Using graphics capture
03:01:42: Total frames rendered: 1598, number of frames that lagged: 1 (0.06%) (it's okay for some frames to lag)
03:01:42: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:01:42: Number of times waited to send: 0, Waited for a total of 0 bytes
03:01:42: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:01:42: =====Stream End: 2013-07-19, 03:01:42=================================================
03:01:44: =====Stream Start: 2013-07-19, 03:01:44===============================================
03:01:44: Multithreaded optimizations: On
03:01:44: Base resolution: 1600x128
03:01:44: Output resolution: 1600x128
03:01:44: ------------------------------------------
03:01:44: Loading up D3D10...
03:01:44: Playback device Default
03:01:44: Using desktop audio input: Speakers (High Definition Audio Device)
03:01:44: Audio Encoding: AAC
03:01:44: bitrate: 128
03:01:44: Using graphics capture
03:01:44: Video Encoding: x264
03:01:44: fps: 30
03:01:44: width: 1600, height: 128
03:01:44: preset: veryfast
03:01:44: CBR: yes
03:01:44: CFR: no
03:01:44: max bitrate: 1000
03:01:45: Total frames rendered: 38, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
03:01:45: Number of times waited to send: 0, Waited for a total of 0 bytes
03:01:45: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
03:01:45: =====Stream End: 2013-07-19, 03:01:45=================================================
03:02:54: =====Stream Start: 2013-07-19, 03:02:54===============================================
03:02:54: Multithreaded optimizations: On
03:02:54: Base resolution: 1600x128
03:02:54: Output resolution: 1600x128
03:02:54: ------------------------------------------
03:02:54: Loading up D3D10...
03:02:54: Playback device Default
03:02:54: Using desktop audio input: Speakers (High Definition Audio Device)
03:02:54: Audio Encoding: AAC
03:02:54: bitrate: 128
03:02:54: Using graphics capture
03:02:54: Video Encoding: x264
03:02:54: fps: 30
03:02:54: width: 1600, height: 128
03:02:54: preset: veryfast
03:02:54: CBR: yes
03:02:54: CFR: no
03:02:54: max bitrate: 1000
03:02:55: Using RTMP service: Twitch / Justin.tv
03:02:55: Server selection: rtmp://live.justin.tv/app
03:02:56: Total frames rendered: 79, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
03:02:57: SO_SNDBUF was at 8192
03:02:57: SO_SNDBUF is now 65536
03:02:57: RTMPPublisher::SocketLoop: Aborting due to loop exit
03:02:57: Number of times waited to send: 0, Waited for a total of 0 bytes
03:02:57: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
03:02:57: =====Stream End: 2013-07-19, 03:02:57=================================================
03:03:21: =====Stream Start: 2013-07-19, 03:03:21===============================================
03:03:21: Multithreaded optimizations: On
03:03:21: Base resolution: 1600x128
03:03:21: Output resolution: 1600x128
03:03:21: ------------------------------------------
03:03:21: Loading up D3D10...
03:03:21: Playback device Default
03:03:21: Using desktop audio input: Speakers (High Definition Audio Device)
03:03:21: Audio Encoding: AAC
03:03:21: bitrate: 128
03:03:21: Using Window Capture
03:03:21: Video Encoding: x264
03:03:21: fps: 30
03:03:21: width: 1600, height: 128
03:03:21: preset: veryfast
03:03:21: CBR: yes
03:03:21: CFR: no
03:03:21: max bitrate: 1000
03:03:23: Using RTMP service: Twitch / Justin.tv
03:03:23: Server selection: rtmp://live.justin.tv/app
03:03:24: SO_SNDBUF was at 8192
03:03:24: SO_SNDBUF is now 65536
03:03:55: Total frames rendered: 1006, number of frames that lagged: 3 (0.30%) (it's okay for some frames to lag)
03:03:55: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:03:55: Number of times waited to send: 0, Waited for a total of 0 bytes
03:03:55: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:03:55: =====Stream End: 2013-07-19, 03:03:55=================================================
03:04:17: =====Stream Start: 2013-07-19, 03:04:17===============================================
03:04:17: Multithreaded optimizations: On
03:04:17: Base resolution: 1600x128
03:04:17: Output resolution: 1600x128
03:04:17: ------------------------------------------
03:04:17: Loading up D3D10...
03:04:17: Playback device Default
03:04:17: Using desktop audio input: Speakers (High Definition Audio Device)
03:04:17: Audio Encoding: AAC
03:04:17: bitrate: 128
03:04:17: Using Window Capture
03:04:17: Video Encoding: x264
03:04:17: fps: 30
03:04:17: width: 1600, height: 128
03:04:17: preset: veryfast
03:04:17: CBR: yes
03:04:17: CFR: no
03:04:17: max bitrate: 1000
03:04:19: Using RTMP service: Twitch / Justin.tv
03:04:19: Server selection: rtmp://live.justin.tv/app
03:04:20: SO_SNDBUF was at 8192
03:04:20: SO_SNDBUF is now 65536
03:05:46: Using graphics capture
03:05:46: SharedTexCapture hooked
03:07:55: Using Window Capture
03:09:27: SharedTexCapture hooked
03:15:32: Total frames rendered: 20143, number of frames that lagged: 17 (0.08%) (it's okay for some frames to lag)
03:15:32: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:15:32: Number of times waited to send: 0, Waited for a total of 0 bytes
03:15:32: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:15:32: =====Stream End: 2013-07-19, 03:15:32=================================================
03:15:36: =====Stream Start: 2013-07-19, 03:15:36===============================================
03:15:36: Multithreaded optimizations: On
03:15:36: Base resolution: 1600x900
03:15:36: Output resolution: 1600x900
03:15:36: ------------------------------------------
03:15:36: Loading up D3D10...
03:15:36: Playback device Default
03:15:36: Using desktop audio input: Speakers (High Definition Audio Device)
03:15:36: Audio Encoding: AAC
03:15:36: bitrate: 128
03:15:36: Using graphics capture
03:15:36: Video Encoding: x264
03:15:36: fps: 30
03:15:36: width: 1600, height: 900
03:15:36: preset: veryfast
03:15:36: CBR: yes
03:15:36: CFR: no
03:15:36: max bitrate: 1000
03:15:36: SharedTexCapture hooked
03:15:38: Using RTMP service: Twitch / Justin.tv
03:15:38: Server selection: rtmp://live.justin.tv/app
03:15:38: SO_SNDBUF was at 8192
03:15:38: SO_SNDBUF is now 65536
03:29:20: Total frames rendered: 24634, number of frames that lagged: 93 (0.38%) (it's okay for some frames to lag)
03:29:20: RTMPPublisher::SocketLoop: Aborting due to loop exit
03:29:20: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
03:29:20: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
03:29:20: Number of times waited to send: 0, Waited for a total of 0 bytes
03:29:20: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:29:20: =====Stream End: 2013-07-19, 03:29:20=================================================
03:46:28: =====Stream Start: 2013-07-19, 03:46:28===============================================
03:46:28: Multithreaded optimizations: On
03:46:28: Base resolution: 1600x900
03:46:28: Output resolution: 1600x900
03:46:28: ------------------------------------------
03:46:28: Loading up D3D10...
03:46:28: Playback device Default
03:46:28: Using desktop audio input: Speakers (High Definition Audio Device)
03:46:28: Audio Encoding: AAC
03:46:28: bitrate: 128
03:46:28: Using graphics capture
03:46:28: Video Encoding: x264
03:46:28: fps: 30
03:46:28: width: 1600, height: 900
03:46:28: preset: veryfast
03:46:28: CBR: no
03:46:28: CFR: no
03:46:28: max bitrate: 1000
03:46:28: buffer size: 1000
03:46:28: quality: 8
03:46:30: Using RTMP service: Twitch / Justin.tv
03:46:30: Server selection: rtmp://live.justin.tv/app
03:46:31: SO_SNDBUF was at 8192
03:46:31: SO_SNDBUF is now 65536
03:47:21: SharedTexCapture hooked
03:54:36: Total frames rendered: 14603, number of frames that lagged: 75 (0.51%) (it's okay for some frames to lag)
03:54:36: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:54:36: Number of times waited to send: 0, Waited for a total of 0 bytes
03:54:36: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:54:36: =====Stream End: 2013-07-19, 03:54:36=================================================
03:54:53:
03:54:53: Profiler results:
03:54:53:
03:54:53: ==============================================================
03:54:53: frame - [100%] [avg time: 3.568 ms (cpu time: avg 2.678 ms, total 191710 ms)] [avg calls per frame: 1] [children: 76%] [unaccounted: 24%]
03:54:53: | scene->Preprocess - [5.04%] [avg time: 0.18 ms (cpu time: avg 0.115 ms, total 8268.06 ms)] [avg calls per frame: 1]
03:54:53: | video encoding and uploading - [71%] [avg time: 2.533 ms (cpu time: avg 2.271 ms, total 162537 ms)] [avg calls per frame: 1] [children: 69.6%] [unaccounted: 1.4%]
03:54:53: | | CopyResource - [0.336%] [avg time: 0.012 ms (cpu time: avg 0.008 ms, total 592.809 ms)] [avg calls per frame: 0]
03:54:53: | | conversion to 4:2:0 - [0.785%] [avg time: 0.028 ms (cpu time: avg 0.006 ms, total 452.404 ms)] [avg calls per frame: 0]
03:54:53: | | call to encoder - [65.8%] [avg time: 2.346 ms (cpu time: avg 2.222 ms, total 159059 ms)] [avg calls per frame: 0]
03:54:53: | | sending stuff out - [2.72%] [avg time: 0.097 ms (cpu time: avg 0.019 ms, total 1372.81 ms)] [avg calls per frame: 0]
03:54:53: | Convert444Threads - [1.87e+003%] [avg time: 66.706 ms (cpu time: avg 2.449 ms, total 175267 ms)] [avg calls per frame: 1]
03:54:53:
