Question / Help some help
olli
i had no problems using game capture mode on windows 7 but it doesn't work that well on windows 8 yet so i've been using capture monitor to record some gameplay. it works fine for tf2, but for skyrim i just get a black screen, even running skyrim in window mode. any way to fix this?
and a question, i like listening to music on winamp when i play games. is there a plugin or someway i can have obs ignore the audio from winamp when i record?
Well I would actually give game capture or window capture a try for your skyrim problem. If nothing seems to help you could ultimately test using dxtory.
For your Winamp question, I made a guide on how to exclude audio of you stream. There are two ways of doing it, so I´ll link you both guides here:
VAC Guide:
http://obsproject.com/forum/viewtopic.php?f=18&t=3202
StereoMix Guide:
http://obsproject.com/forum/viewtopic.php?f=18&t=3201
If you have problems or questions, just post them here or below the guide and Ill try to help!
