No Question anymore, but a solution if anybody ever comes across the same problem:
I'm using a Magewell Capture card which runs perfectly fine under OSX, but when i connected it to a Windows Laptop the Video (the preview in OBS, and also in other software) was lagging / stuttering and just looked like low FPS.
It kinda looked like there is a USB Bandwidth problem.
After several hours of looking in the direction of a USB Bandwidth problem i stumbled across posts that address a problem with a windows component that Microsoft changed in 2016 and was thus able to find a solution in another forum that somebody posted:
This also fixed my problem, the Video is smooth now. Maybe it can save some other persons the time that i had to spend to find this solution if you find it here.
This should restore pre-Windows 10 Anniversary Update behavior and unblock webcams experiencing the freezing-after-few-seconds issue:
Try opening up HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows Media Foundation\Platform and add a DWORD with name EnableFrameServerMode. Set its value to 0 and try again. For 64-bit apps (e.g. UWP Skype), use the same path above, minus WOW6432Node.
