Bug Report Solution for LavasoftTCPService Problem
LSJake
Hi,
A number of users here are encountering problems with a component of Lavasoft's Web Companion program, particularly the LavasoftTCPService file. If you are having trouble deleting the file, here are two possible solutions from Lavasoft:
Option #1
How to determine if you have a 32-bit or 64-bit Windows
1. Press
+ R on your keyboard.
2. Type C: and then press ENTER key
If inside your C: drive you see Program Files (x86), you have a 64-bit Windows.
If you don't, you have 32-bit Windows.
How to disable the locked "LavasoftTCPService.dll" file
1. Download this file => KomodiaFix.zip
2. Right-click the file and select Extract All
3. Open the folder named KomodiaFix to find the necessary files inside
4a. If you have a 32-bit Windows, right-click on uninstall.bat and select Run as Admin.
4b. If you have a 64-bit Windows, right-click on uninstall64.bat and select Run as Admin.
5. Once the process is complete, restart your computer.
6. After restart, please delete these two files:
C:\WINDOWS\system32\LavasoftTcpService64.dll
C:\WINDOWS\SysWOW64\LavasoftTcpService.dll
Restart your computer once more to refresh the system.
You may now also delete the KomodiaFix.zip files you downloaded and extracted.
Options #2
1. Start Command Prompt as an administrator by right-clicking it and select Run as administrator.
2. Enter this command to reset the network adapter (end with the Enter key):
netsh winsock reset
3. Restart the computer.
4. Please, delete these two files:
Original Post: http://www.lavasoftsupport.com/inde...asofttcpservice-problem-after-uninstallation/
