lolshaddeh
Logs: http://pastebin.com/i7n07tfb
Hey,
I've been reading around to try and fix my fps problems, and I found out that switching to the other scene just hides my monitor capture(VIA software capture) and that gives me many issues in league of legends, as it is not being unchecked.
I currently have the plugin that switches the scene for you if you alt tab and all that to the current active one, Is there any other way to stream your screen that shows what you are doing on your desktop, or if there is a way to get a plugin that unchecks that box so that its also disabled when tabbed into the game and lets say re-enables if I alt tab?
Let me know,
Thanks!
Hey,
Let me know,
Thanks!
