MikeTPC your log file run through OBS Analyzer shows the following:
Critical Hardware-accelerated GPU Scheduler
The Hardware-accelerated GPU scheduling ("HAGS") feature added with Windows 10 is currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via
this screen or
these instructions.
Warning Old Version (28.1.2)
You are running an old version of OBS Studio (28.1.2). Please update to version 30.1.2 by going to Help -> Check for updates in OBS or by downloading the latest installer from the
downloads page and running it.
Warning Integrated GPU
OBS is running on an Intel iGPU. This hardware is generally not powerful enough to be used for both gaming and running obs. Situations where only sources from e.g. cameras and capture cards are used might work.
Info Windows 10 22H2 (OK)
You are running Windows 10 22H2, which will be supported by Microsoft until
October 2025.
Info Not Admin
OBS is not running as Administrator. This can lead to OBS not being able to Game Capture certain games. If you are not running into issues, you can ignore this.
Info No Output Session
Your log contains no recording or streaming session. Results of this log analysis are limited. Please post a link to a clean log file.
To make a clean log file, please follow these steps:
1) Restart OBS.
2) Start your stream/recording for about 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your stream/recording.
4) Select Help > Log Files > Upload Current Log File. Send that link via this troubleshooting tool or whichever support chat you are using.
Info Third-Party Plugins (2)
You have the following third-party plugins installed:
None of the above addresses the PTZ camera issue you have, which is likely to be a configuration issue.
