Bug Report Slightly different case than others: Mic input audio delay.
Ruhrev
First off, I know that there's plenty of posts about this in the forums, but I think my case is somewhat different.
Here is why:
I've used OBS since 0.411a, I never had a problem with audio delay until 0.466a came out. So this might be a solution for all of the people out there that can't for the love of god, get the audio delay fixed. Try using version 465a or something prior to that.
Every time there's a new OBS version coming out, I hope that the problem has been solved for me, but that's not the case thus far. Every single version after 465a gives me an mic input audio delay. The game, game audio and webcam is synced just fine. It's just the mic audio that gets a delay.
I'm still using 465a, and it's working just fine. But I'm missing out on many new features that I would love to part take in.
Please, help.
Here is the log from 465a - Working perfectly.
Open Broadcaster Software v0.465a - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) 9850 Quad-Core Processor
CPU Speed: 2499MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 3, model 2, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
  Video Adapter: NVIDIA GeForce 9600 GSO
  Video Adapter Dedicated Video Memory: 1581842432
  Video Adapter Shared System Memory: 2683908096
  Base resolution: 1920x1080
  Output resolution: 852x480
Loading up D3D10...
Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 128
Warning -- DShowPlugin: Invalid device: name 'Live! Cam Video IM #2', path '\\?\usb#vid_041e&pid_4053#5&2730ab6&0&1#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce}'
Warning -- D3D10Texture::CreateTexture: CreateTexture2D failed, result = 0x80070057
Using directshow input
Using graphics capture
Video Encoding: x264
    fps: 25
    width: 852, height: 480
    preset: veryfast
    CBR: no
    max bitrate: 950
    buffer size: 950
    quality: 7
SharedTexCapture hooked
    device: Live! Cam Video IM,
    device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
    chosen type: RGB24, usingFourCC: false, res: 320x240 - 320x240, fps: 10-30, fourCC: 00000000
Total frames rendered: 2279, number of frames that lagged: 209 (9.17%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: veryfast
    CBR: no
    max bitrate: 950
    buffer size: 950
    quality: 7
  Server selection: rtmp://live-fra.justin.tv/app
bufferTime: 2340, outputRateWindowTime: 1000, dropThreshold: 2840
Total frames rendered: 5703, number of frames that lagged: 53 (0.93%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 15.618 ms] [avg calls per frame: 1] [children: 95.3%] [unaccounted: 4.69%]
| scene->Preprocess - [0.442%] [avg time: 0.069 ms] [avg calls per frame: 1]
| video encoding and uploading - [94.9%] [avg time: 14.817 ms] [avg calls per frame: 1] [children: 94.7%] [unaccounted: 0.186%]
| | CopyResource - [84.6%] [avg time: 13.216 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.275%] [avg time: 0.043 ms] [avg calls per frame: 0]
| | call to encoder - [9.61%] [avg time: 1.501 ms] [avg calls per frame: 0]
| | sending stuff out - [0.179%] [avg time: 0.028 ms] [avg calls per frame: 0]
Here is a short test stream I did with "0.56.03 MADNESS" (I tried copy/pasting a 2hours held log, but the forum keeps crashing on me when I submit this post)
18:45:49: Open Broadcaster Software v0.56.03 MADNESS - 32bit (´・ω・`)
18:45:49: -------------------------------
18:45:49: CPU Name: AMD Phenom(tm) 9850 Quad-Core Processor
18:45:49: CPU Speed: 2499MHz
18:45:49: Physical Memory:  4095MB Total, 4095MB Free
18:45:49: stepping id: 3, model 2, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
18:45:49: monitor 1: pos={0, 0}, size={1280, 720}
18:45:49: Windows Version: 6.1 Build 7601 S
18:45:49: Aero is Disabled
18:45:49: OBS Modules:
18:45:49: Base Address     Module
18:45:49: 00350000         OBS.exe
18:45:49: 657B0000         OBSApi.dll
18:45:49: 6D630000         DShowPlugin.dll
18:45:49: 70670000         GraphicsCapture.dll
18:45:49: 6F8B0000         NoiseGate.dll
18:45:49: 6D610000         PSVPlugin.dll
18:45:49: ------------------------------------------
18:45:49: Adapter 1
18:45:49:   Video Adapter: NVIDIA GeForce 9600 GSO
18:45:49:   Video Adapter Dedicated Video Memory: 1581842432
18:45:49:   Video Adapter Shared System Memory: 2683908096
18:45:49: Incompatible modules (pre-D3D) detected.
18:46:09: Incompatible modules (pre-D3D) detected.
18:46:48: Incompatible modules (pre-D3D) detected.
18:46:48: =====Stream Start: 2013-09-10, 18:46:48===============================================
18:46:48:   Multithreaded optimizations: On
18:46:48:   Base resolution: 1920x1080
18:46:48:   Output resolution: 1280x720
18:46:48: ------------------------------------------
18:46:48: Loading up D3D10 on NVIDIA GeForce 9600 GSO...
18:46:48: Audio Format: 48000hz
18:46:48: Playback device Default
18:46:48: Using desktop audio input: Högtalare (Realtek High Definition Audio)
18:46:49: ------------------------------------------
18:46:49: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
18:46:49: Audio Encoding: AAC
18:46:49:     bitrate: 128
18:46:49: Using graphics capture
18:46:49: Video Encoding: x264
18:46:49:     fps: 30
18:46:49:     width: 1280, height: 720
18:46:49:     preset: veryfast
18:46:49:     CBR: yes
18:46:49:     CFR: yes
18:46:49:     max bitrate: 950
18:46:49:     buffer size: 950
18:46:49: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
18:46:49: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
18:46:49: Bad timestamp detected, syncing audio to video time
Warning -- SharedTexCapture::Init: Could not open file mapping: 2
18:46:49: Capture window 0x00000000 invalid or changing, terminating capture
18:46:59:
18:46:59: Profiler result for the last frame:
18:46:59: ==============================================================
18:46:59: video thread frame - [time: 125.378 ms (cpu time: 15.6 ms)]
18:46:59: | frame preprocessing and rendering - [time: 0.913 ms (cpu time: 0 ms)]
18:46:59: | | scene->Preprocess - [time: 0.003 ms (cpu time: 0 ms)]
18:46:59: | GPU download and color conversion - [time: 124.46 ms (cpu time: 15.6 ms)]
18:46:59: | | flush - [time: 0.042 ms (cpu time: 0 ms)]
18:46:59: | | CopyResource - [time: 124.394 ms (cpu time: 15.6 ms)]
18:46:59: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
18:46:59: | Convert444Threads - [time: 125.464 ms (cpu time: 0 ms)]
18:46:59: encoder thread frame - [time: 2.121 ms (cpu time: 0 ms)]
18:46:59:
18:46:59:
18:46:59: video thread frame - [time: 111.25 ms (cpu time: 0 ms)]
18:46:59: | frame preprocessing and rendering - [time: 0.587 ms (cpu time: 0 ms)]
18:46:59: | GPU download and color conversion - [time: 110.66 ms (cpu time: 0 ms)]
18:46:59: | | flush - [time: 0.224 ms (cpu time: 0 ms)]
18:46:59: | | CopyResource - [time: 110.39 ms (cpu time: 0 ms)]
18:46:59: | | conversion to 4:2:0 - [time: 0.015 ms (cpu time: 0 ms)]
18:46:59: | Convert444Threads - [time: 111.433 ms (cpu time: 0 ms)]
18:46:59: encoder thread frame - [time: 2.377 ms (cpu time: 0 ms)]
18:46:59:
18:47:00:
18:47:00: Profiler result for the last frame:
18:47:00: ==============================================================
18:47:00: video thread frame - [time: 130.361 ms (cpu time: 0 ms)]
18:47:00: | frame preprocessing and rendering - [time: 0.393 ms (cpu time: 0 ms)]
18:47:00: | | scene->Preprocess - [time: 0.002 ms (cpu time: 0 ms)]
18:47:00: | GPU download and color conversion - [time: 129.962 ms (cpu time: 0 ms)]
18:47:00: | | flush - [time: 0.218 ms (cpu time: 0 ms)]
18:47:00: | | CopyResource - [time: 129.715 ms (cpu time: 0 ms)]
18:47:00: | | conversion to 4:2:0 - [time: 0.01 ms (cpu time: 0 ms)]
18:47:00: | Convert444Threads - [time: 131.649 ms (cpu time: 0 ms)]
18:47:00: encoder thread frame - [time: 2.038 ms (cpu time: 0 ms)]
18:47:00:
18:47:00:
18:47:00: video thread frame - [time: 113.713 ms (cpu time: 0 ms)]
18:47:00: | frame preprocessing and rendering - [time: 0.568 ms (cpu time: 0 ms)]
18:47:00: | | scene->Preprocess - [time: 0.004 ms (cpu time: 0 ms)]
18:47:00: | GPU download and color conversion - [time: 113.141 ms (cpu time: 0 ms)]
18:47:00: | | flush - [time: 0.156 ms (cpu time: 0 ms)]
18:47:00: | | CopyResource - [time: 112.524 ms (cpu time: 0 ms)]
18:47:00: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
18:47:00: | Convert444Threads - [time: 113.716 ms (cpu time: 0 ms)]
18:47:00: encoder thread frame - [time: 1.999 ms (cpu time: 0 ms)]
18:47:00:
18:47:00:
18:47:00: video thread frame - [time: 126.609 ms (cpu time: 15.601 ms)]
18:47:00: | frame preprocessing and rendering - [time: 0.443 ms (cpu time: 0 ms)]
18:47:00: | | scene->Preprocess - [time: 0.003 ms (cpu time: 0 ms)]
18:47:00: | GPU download and color conversion - [time: 126.161 ms (cpu time: 15.601 ms)]
18:47:00: | | flush - [time: 0.039 ms (cpu time: 0 ms)]
18:47:00: | | CopyResource - [time: 126.097 ms (cpu time: 15.601 ms)]
18:47:00: | | conversion to 4:2:0 - [time: 0.008 ms (cpu time: 0 ms)]
18:47:00: | Convert444Threads - [time: 127.485 ms (cpu time: 0 ms)]
18:47:00: encoder thread frame - [time: 2.023 ms (cpu time: 0 ms)]
18:47:00:
18:47:00:
18:47:00: video thread frame - [time: 114.751 ms (cpu time: 15.6 ms)]
18:47:00: | frame preprocessing and rendering - [time: 0.423 ms (cpu time: 0 ms)]
18:47:00: | GPU download and color conversion - [time: 114.324 ms (cpu time: 15.6 ms)]
18:47:00: | | flush - [time: 0.114 ms (cpu time: 0 ms)]
18:47:00: | | CopyResource - [time: 114.181 ms (cpu time: 15.6 ms)]
18:47:00: | Convert444Threads - [time: 114.979 ms (cpu time: 0 ms)]
18:47:00: encoder thread frame - [time: 2.172 ms (cpu time: 0 ms)]
18:47:00:
18:47:00:
18:47:00: video thread frame - [time: 30.232 ms (cpu time: 0 ms)]
18:47:00: | frame preprocessing and rendering - [time: 0.972 ms (cpu time: 0 ms)]
18:47:00: | GPU download and color conversion - [time: 29.25 ms (cpu time: 0 ms)]
18:47:00: | | flush - [time: 0.041 ms (cpu time: 0 ms)]
18:47:00: | | CopyResource - [time: 29.183 ms (cpu time: 0 ms)]
18:47:00: | Convert444Threads - [time: 30.721 ms (cpu time: 0 ms)]
18:47:00: encoder thread frame - [time: 2.811 ms (cpu time: 0 ms)]
18:47:00:
18:47:02: Exit signal received, terminating capture
18:47:07: Total frames encoded: 543, total frames duplicated 81 (14.92%)
18:47:07: Total frames rendered: 487, number of late frames: 34 (6.98%) (it's okay for some frames to be late)
18:47:07:
18:47:07: Profiler results:
18:47:07:
18:47:07: ==============================================================
18:47:07: video thread frame - [100%] [avg time: 18.015 ms (cpu time: avg 4.804 ms, total 2340.02 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.322%]
18:47:07: | frame preprocessing and rendering - [14.5%] [avg time: 2.614 ms (cpu time: avg 1.761 ms, total 858.003 ms)] [avg calls per frame: 1] [children: 0.0111%] [unaccounted: 14.5%]
18:47:07: | | scene->Preprocess - [0.0111%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
18:47:07: | GPU download and color conversion - [85.2%] [avg time: 15.343 ms (cpu time: avg 3.011 ms, total 1466.41 ms)] [avg calls per frame: 1] [children: 85%] [unaccounted: 0.205%]
18:47:07: | | flush - [0.422%] [avg time: 0.076 ms (cpu time: avg 0.064 ms, total 31.2 ms)] [avg calls per frame: 1]
18:47:07: | | CopyResource - [84%] [avg time: 15.136 ms (cpu time: avg 2.882 ms, total 1404.01 ms)] [avg calls per frame: 1]
18:47:07: | | conversion to 4:2:0 - [0.522%] [avg time: 0.094 ms (cpu time: avg 0.032 ms, total 15.6 ms)] [avg calls per frame: 1]
18:47:07: | Convert444Threads - [412%] [avg time: 74.272 ms (cpu time: avg 2.979 ms, total 1450.81 ms)] [avg calls per frame: 2]
18:47:07: encoder thread frame - [100%] [avg time: 2.449 ms (cpu time: avg 1.703 ms, total 904.805 ms)] [avg calls per frame: 1]
18:47:07:
18:47:07: =====Stream End: 2013-09-10, 18:47:07=================================================
18:47:09: Incompatible modules (pre-D3D) detected.
Last game capture log:
D3D11 Present
D3D9 Present
DoD3D9GPUHook: success
dodgepong
Administrator
Community Helper
Re: Slightly different case than others: Mic input audio del
Try increasing your scene buffer time to 700ms in Advanced settings and enable "Use Mic QPC Timestamps" and see if that helps.
Ruhrev
I tried that out just now, it didn't work, if anything it made it worse. I ended up with a 20mb log file.
I'll split it up, and only paste the essentials.
00:54:21: Settings::Video: Enabling Aero
00:54:39: Settings::Video: Enabling Aero
00:56:58: Open Broadcaster Software v0.56.03 MADNESS - 32bit (´・ω・`)
00:56:58: -------------------------------
00:56:58: CPU Name: AMD Phenom(tm) 9850 Quad-Core Processor
00:56:58: CPU Speed: 2499MHz
00:56:58: Physical Memory:  4095MB Total, 4095MB Free
00:56:58: stepping id: 3, model 2, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
00:56:58: monitor 1: pos={0, 0}, size={1920, 1080}
00:56:58: Windows Version: 6.1 Build 7601 S
00:56:58: Aero is Disabled
00:56:58: OBS Modules:
00:56:58: Base Address     Module
00:56:58: 001C0000         OBS.exe
00:56:58: 722E0000         OBSApi.dll
00:56:58: 74170000         DShowPlugin.dll
00:56:58: 74280000         GraphicsCapture.dll
00:56:58: 73710000         NoiseGate.dll
00:56:58: 73280000         PSVPlugin.dll
00:56:58: ------------------------------------------
00:56:58: Adapter 1
00:56:58:   Video Adapter: NVIDIA GeForce 9600 GSO
00:56:58:   Video Adapter Dedicated Video Memory: 1581842432
00:56:58:   Video Adapter Shared System Memory: 2683908096
00:56:58: =====Stream Start: 2013-09-11, 00:56:58===============================================
00:56:58:   Multithreaded optimizations: On
00:56:58:   Base resolution: 1920x1080
00:56:58:   Output resolution: 1280x720
00:56:58: Loading up D3D10 on NVIDIA GeForce 9600 GSO...
00:56:58: Audio Format: 48000hz
00:56:58: Playback device Default
00:56:58: Using desktop audio input: Högtalare (Realtek High Definition Audio)
00:56:58: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
00:56:58: Using Mic QPC timestamps
00:56:58: Audio Encoding: AAC
00:56:58:     bitrate: 128
00:56:58: Using Monitor Capture
Warning -- DShowPlugin: Could not create device filter
00:56:58: Using directshow input
00:56:58: Using bitmap image
00:56:58: Video Encoding: x264
00:56:58:     fps: 30
00:56:58:     width: 1280, height: 720
00:56:58:     preset: veryfast
00:56:58:     CBR: yes
00:56:58:     CFR: yes
00:56:58:     max bitrate: 950
00:56:58:     buffer size: 950
00:56:58: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
00:56:58: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
00:56:59: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 15!  Had to delete audio segment.
00:56:59:
00:56:59: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 5!  Had to delete audio segment.
00:56:59:
00:57:11: ------------------------------------------
00:57:11:     device: Live! Cam Video IM,
00:57:11:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
00:57:11:     chosen type: YUY2, usingFourCC: false, res: 352x288 - 352x288, frameIntervals: 333333-1000000, fourCC: 'YUY2'
00:57:11:     audio device: Disable,
00:57:11:     audio device id Disabled,
00:57:11:
00:58:11: ------------------------------------------
00:58:11:     device: Live! Cam Video IM,
00:58:11:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
00:58:11:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
00:58:11:     audio device: Disable,
00:58:11:     audio device id Disabled,
00:58:11:
00:58:11: Using directshow input
00:59:49: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:59:49:   New Scene
00:59:49: Using directshow input
00:59:49: Using bitmap image
00:59:49: Using graphics capture
00:59:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:59:57:   New Scene
00:59:57: Using bitmap image
00:59:57: ------------------------------------------
00:59:57:     device: Live! Cam Video IM,
00:59:57:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
00:59:57:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
00:59:57:     audio device: Disable,
00:59:57:     audio device id Disabled,
00:59:57:
00:59:57: Using directshow input
00:59:58: Using Monitor Capture
00:59:59: PERFORMANCE WARNING: Scene change took 1481 ms, maybe some sources should be global sources?
00:59:59: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:59:59:   New Scene
00:59:59: Using directshow input
00:59:59: Using bitmap image
00:59:59: Using graphics capture
01:00:19: ------------------------------------------
01:00:19:     device: Live! Cam Video IM,
01:00:19:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
01:00:19:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
01:00:19:     audio device: Disable,
01:00:19:     audio device id Disabled,
01:00:19:
01:00:19: Using directshow input
01:00:29: Using graphics capture
01:00:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:00:40:   New Scene
01:00:40: Using bitmap image
01:00:40: ------------------------------------------
01:00:40:     device: Live! Cam Video IM,
01:00:40:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
01:00:40:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
01:00:40:     audio device: Disable,
01:00:40:     audio device id Disabled,
01:00:40:
01:00:40: Using directshow input
01:00:40: Using Monitor Capture
01:00:41: PERFORMANCE WARNING: Scene change took 1713 ms, maybe some sources should be global sources?
01:00:43: Total frames encoded: 6721, total frames duplicated 620 (9.22%)
01:00:43: Total frames rendered: 6130, number of late frames: 419 (6.84%) (it's okay for some frames to be late)
01:00:43:
01:00:43: Profiler results:
01:00:43:
01:00:43: ==============================================================
01:00:43: video thread frame - [100%] [avg time: 30.32 ms (cpu time: avg 15.007 ms, total 91993.8 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0264%]
01:00:43: | frame preprocessing and rendering - [60%] [avg time: 18.179 ms (cpu time: avg 11.943 ms, total 73211.3 ms)] [avg calls per frame: 1] [children: 53.4%] [unaccounted: 6.57%]
01:00:43: | | scene->Preprocess - [53.4%] [avg time: 16.188 ms (cpu time: avg 11.021 ms, total 67564 ms)] [avg calls per frame: 1]
01:00:43: | GPU download and color conversion - [40%] [avg time: 12.133 ms (cpu time: avg 3.061 ms, total 18766.9 ms)] [avg calls per frame: 1] [children: 39.9%] [unaccounted: 0.0693%]
01:00:43: | | flush - [0.224%] [avg time: 0.068 ms (cpu time: avg 0.063 ms, total 390.004 ms)] [avg calls per frame: 1]
01:00:43: | | CopyResource - [39.4%] [avg time: 11.946 ms (cpu time: avg 2.982 ms, total 18283.3 ms)] [avg calls per frame: 1]
01:00:43: | | conversion to 4:2:0 - [0.323%] [avg time: 0.098 ms (cpu time: avg 0.012 ms, total 78.001 ms)] [avg calls per frame: 1]
01:00:43: | Convert444Threads - [241%] [avg time: 73.081 ms (cpu time: avg 2.784 ms, total 17066.5 ms)] [avg calls per frame: 2]
01:00:43: encoder thread frame - [100%] [avg time: 2.485 ms (cpu time: avg 1.753 ms, total 11746.9 ms)] [avg calls per frame: 1]
01:00:43:
01:00:43: =====Stream End: 2013-09-11, 01:00:43=================================================
01:00:44: =====Stream Start: 2013-09-11, 01:00:44===============================================
01:00:44:   Multithreaded optimizations: On
01:00:44:   Base resolution: 1920x1080
01:00:44:   Output resolution: 1280x720
01:00:44: ------------------------------------------
01:00:44: Loading up D3D10 on NVIDIA GeForce 9600 GSO...
01:00:44: Audio Format: 48000hz
01:00:44: Playback device Default
01:00:44: Using desktop audio input: Högtalare (Realtek High Definition Audio)
01:00:44: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
01:00:44: Using Mic QPC timestamps
01:00:44: Audio Encoding: AAC
01:00:44:     bitrate: 128
01:00:44: Using bitmap image
01:00:44:     device: Live! Cam Video IM,
01:00:44:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
01:00:44:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
01:00:44:     audio device: Disable,
01:00:44:     audio device id Disabled,
01:00:44:
01:00:44: Using directshow input
01:00:44: Using Monitor Capture
01:00:45: ------------------------------------------
01:00:45: Video Encoding: x264
01:00:45:     fps: 30
01:00:45:     width: 1280, height: 720
01:00:45:     preset: veryfast
01:00:45:     CBR: yes
01:00:45:     CFR: yes
01:00:45:     max bitrate: 950
01:00:45:     buffer size: 950
01:00:45: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
01:00:45: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
01:00:46: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 23!  Had to delete audio segment.
01:00:46:
01:00:46: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 13!  Had to delete audio segment.
01:00:46:
01:00:46: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 3!  Had to delete audio segment.
01:00:46:
01:00:48: Using RTMP service: Twitch / Justin.tv
01:00:48:   Server selection: rtmp://live-fra.justin.tv/app
01:00:48:   Interface: Marvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller (ethernet, 1000 mbps)
01:00:50: SO_SNDBUF was at 8192
01:00:50: SO_SNDBUF is now 65536
01:01:37:
01:01:37: Profiler result for the last frame:
01:01:37: ==============================================================
01:01:37: video thread frame - [time: 41.323 ms (cpu time: 15.601 ms)]
01:01:37: | frame preprocessing and rendering - [time: 26.014 ms (cpu time: 15.601 ms)]
01:01:37: | | scene->Preprocess - [time: 24.927 ms (cpu time: 15.601 ms)]
01:01:37: | GPU download and color conversion - [time: 15.302 ms (cpu time: 0 ms)]
01:01:37: | | flush - [time: 0.039 ms (cpu time: 0 ms)]
01:01:37: | | CopyResource - [time: 15.237 ms (cpu time: 0 ms)]
01:01:37: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
01:01:37: | Convert444Threads - [time: 41.865 ms (cpu time: 0 ms)]
01:01:37: encoder thread frame - [time: 3.325 ms (cpu time: 0 ms)]
This is the part where the program started spamming this, over and over and over again:
01:01:39: Profiler result for the last frame:
01:01:39: ==============================================================
01:01:39: video thread frame - [time: 39.209 ms (cpu time: 15.6 ms)]
01:01:39: | frame preprocessing and rendering - [time: 24.69 ms (cpu time: 15.6 ms)]
01:01:39: | | scene->Preprocess - [time: 23.984 ms (cpu time: 15.6 ms)]
01:01:39: | GPU download and color conversion - [time: 14.513 ms (cpu time: 0 ms)]
01:01:39: | | flush - [time: 0.043 ms (cpu time: 0 ms)]
01:01:39: | | CopyResource - [time: 14.446 ms (cpu time: 0 ms)]
01:01:39: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
01:01:39: | Convert444Threads - [time: 39.235 ms (cpu time: 0 ms)]
01:01:39: encoder thread frame - [time: 2.256 ms (cpu time: 0 ms)]
01:01:39:
01:01:39:
01:01:39: video thread frame - [time: 40.622 ms (cpu time: 31.2 ms)]
01:01:39: | frame preprocessing and rendering - [time: 23.756 ms (cpu time: 31.2 ms)]
01:01:39: | | scene->Preprocess - [time: 23.117 ms (cpu time: 31.2 ms)]
01:01:39: | GPU download and color conversion - [time: 16.861 ms (cpu time: 0 ms)]
01:01:39: | | flush - [time: 0.07 ms (cpu time: 0 ms)]
01:01:39: | | CopyResource - [time: 16.765 ms (cpu time: 0 ms)]
01:01:39: | | conversion to 4:2:0 - [time: 0.01 ms (cpu time: 0 ms)]
01:01:39: | Convert444Threads - [time: 42.094 ms (cpu time: 0 ms)]
01:01:39: encoder thread frame - [time: 2.266 ms (cpu time: 0 ms)]
And then we have this, this is what the majority of the log file consists out of:
01:05:36: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 43!  Had to delete audio segment.
And it just kept spamming that, but with an increase of the number, it ended up with this amount:
01:27:38: Audio timestamp for device 'Mikrofon (Realtek High Definition Audio)' was behind target timestamp by 3238!  Had to delete audio segment.
01:27:38:
01:27:38: Total frames encoded: 48361, total frames duplicated 1094 (2.26%)
01:27:38: Total frames rendered: 47542, number of late frames: 779 (1.64%) (it's okay for some frames to be late)
01:27:39: RTMPPublisher::SocketLoop: Graceful loop exit
01:27:39: Number of times waited to send: 0, Waited for a total of 0 bytes
01:27:39: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
01:27:39:
01:27:39: Profiler results:
01:27:39:
01:27:39: ==============================================================
01:27:39: video thread frame - [100%] [avg time: 15.005 ms (cpu time: avg 6.115 ms, total 290723 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0666%]
01:27:39: | frame preprocessing and rendering - [24.5%] [avg time: 3.672 ms (cpu time: avg 2.687 ms, total 127780 ms)] [avg calls per frame: 1] [children: 18.3%] [unaccounted: 6.12%]
01:27:39: | | scene->Preprocess - [18.3%] [avg time: 2.753 ms (cpu time: avg 2.009 ms, total 95550.6 ms)] [avg calls per frame: 1]
01:27:39: | GPU download and color conversion - [75.5%] [avg time: 11.323 ms (cpu time: avg 3.421 ms, total 162647 ms)] [avg calls per frame: 1] [children: 75%] [unaccounted: 0.487%]
01:27:39: | | flush - [0.546%] [avg time: 0.082 ms (cpu time: avg 0.053 ms, total 2558.42 ms)] [avg calls per frame: 1]
01:27:39: | | CopyResource - [74.2%] [avg time: 11.134 ms (cpu time: avg 3.338 ms, total 158731 ms)] [avg calls per frame: 1]
01:27:39: | | conversion to 4:2:0 - [0.227%] [avg time: 0.034 ms (cpu time: avg 0.008 ms, total 405.605 ms)] [avg calls per frame: 1]
01:27:39: | Convert444Threads - [452%] [avg time: 67.814 ms (cpu time: avg 2.711 ms, total 128904 ms)] [avg calls per frame: 2]
01:27:39: encoder thread frame - [100%] [avg time: 2.507 ms (cpu time: avg 1.946 ms, total 94084.2 ms)] [avg calls per frame: 1]
01:27:39:
01:27:39: =====Stream End: 2013-09-11, 01:27:39=================================================
2013-09-11, 01:04:32: we're booting up:
01:04:32: D3D9 Present
01:04:32: DXGI Present
01:04:32: D3D9EndScene called
01:04:32: D3DPRESENT_PARAMETERS {
01:04:32: 	BackBufferWidth: 1920
01:04:32: 	BackBufferHeight: 1080
01:04:32: 	BackBufferFormat: D3DFMT_X8R8G8B8
01:04:32: 	BackBufferCount: 1
01:04:32: 	MultiSampleType: D3DMULTISAMPLE_NONE
01:04:32: 	MultiSampleQuality: 0
01:04:32: 	SwapEffect: D3DSWAPEFFECT_DISCARD
01:04:32: 	hDeviceWindow: 1900992
01:04:32: 	Windowed: true
01:04:32: 	EnableAutoDepthStencil: true
01:04:32: 	AutoDepthStencilFormat: D3DFMT_D24S8
01:04:32: 	Flags: D3DPRESENTFLAG_DISCARD_DEPTHSTENCIL
01:04:32: 	FullScreen_RefreshRateInHz: 0
01:04:32: 	PresentationInterval: 2147483648
01:04:32: };
01:04:32: successfully set up d3d9 hooks
01:04:32: D3D9Present called
01:04:32: DoD3D9GPUHook: success
01:04:32: D3DSURFACE_DESC {
01:04:32: 	Format: D3DFMT_X8R8G8B8
01:04:32: 	Type: D3DRTYPE_SURFACE
01:04:32: 	Usage: D3DUSAGE_RENDERTARGET
01:04:32: 	Pool: D3DPOOL_DEFAULT
01:04:32: 	Width: 1920
01:04:32: 	Height: 1080
01:04:32: };
01:04:32: successfully capturing d3d9 frames via GPU
01:04:33: NV Capture available
01:04:33: FBO available
01:04:33: GL Present
01:04:33: (half life scientist) everything..  seems to be in order
dodgepong
Administrator
Community Helper
What if you remove the Mic QPC Timestamps option and just keep the scene buffer at 700? That should at least get rid of the error spam.
Lain
Forum Admin
Lain
Forum Moderator
Developer
465a.. that's pretty old. If it was working back then then I'll check out to see what changed. Thank you for letting me know. (Also, if you haven't, try the "Mic Sync FIx Hack" option in advanced as well, it's a temporary solution to what the problem is, and I partly know what the problem is, just not easy to fix without breaking everything else, requires a thorough redo, very annoying)
Ruhrev
I tried it out and there was no delay what so ever. The "mic sync fix hack" option actually worked. This is great! Thanks a lot for the help, and as many of us have said, thanks for this amazing software you have created.
And I hope you will be able to find a proper solution to this problem in the near future, I hope my logs will help.
Thanks!
Log from the successful stream, without any delay, using the option "Mic Sync Fix Hack" on v0.56.03 MADNESS - 32bit (This is from a 6 minute stream, but I can confirm that it worked on a 30 minute test stream I did as well.. Here's the 6 minute stream log)
20:34:26: Settings::Video: Enabling Aero
20:34:32: Settings::Video: Enabling Aero
20:38:33: Open Broadcaster Software v0.56.03 MADNESS - 32bit (´・ω・`)
20:38:33: -------------------------------
20:38:33: CPU Name: AMD Phenom(tm) 9850 Quad-Core Processor
20:38:33: CPU Speed: 2499MHz
20:38:33: Physical Memory:  4095MB Total, 4095MB Free
20:38:33: stepping id: 3, model 2, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
20:38:33: monitor 1: pos={0, 0}, size={1920, 1080}
20:38:33: Windows Version: 6.1 Build 7601 S
20:38:33: Aero is Disabled
20:38:33: OBS Modules:
20:38:33: Base Address     Module
20:38:33: 011E0000         OBS.exe
20:38:33: 6E7D0000         OBSApi.dll
20:38:33: 72110000         DShowPlugin.dll
20:38:33: 722C0000         GraphicsCapture.dll
20:38:33: 720B0000         NoiseGate.dll
20:38:33: 707C0000         PSVPlugin.dll
20:38:33: ------------------------------------------
20:38:33: Adapter 1
20:38:33:   Video Adapter: NVIDIA GeForce 9600 GSO
20:38:33:   Video Adapter Dedicated Video Memory: 1581842432
20:38:33:   Video Adapter Shared System Memory: 2683908096
20:38:33: =====Stream Start: 2013-09-11, 20:38:33===============================================
20:38:33:   Multithreaded optimizations: On
20:38:33:   Base resolution: 1920x1080
20:38:33:   Output resolution: 852x480
20:38:33: Loading up D3D10 on NVIDIA GeForce 9600 GSO...
20:38:33: Audio Format: 48000hz
20:38:33: Playback device Default
20:38:33: Using desktop audio input: Högtalare (Realtek High Definition Audio)
20:38:33: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
20:38:33: Audio Encoding: AAC
20:38:33:     bitrate: 128
20:38:33:     device: Live! Cam Video IM,
20:38:33:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
20:38:33:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
20:38:33:     audio device: (null),
20:38:33:     audio device id (null),
20:38:33:
20:38:33: Using directshow input
20:38:33: Using graphics capture
20:38:34: ------------------------------------------
20:38:34: Video Encoding: x264
20:38:34:     fps: 30
20:38:34:     width: 852, height: 480
20:38:34:     preset: veryfast
20:38:34:     CBR: yes
20:38:34:     CFR: yes
20:38:34:     max bitrate: 950
20:38:34:     buffer size: 950
20:38:34: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
20:38:34: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
20:38:34: SharedTexCapture hooked
20:38:52:
20:38:52: Profiler result for the last frame:
20:38:52: ==============================================================
20:38:52: video thread frame - [time: 44.024 ms (cpu time: 0 ms)]
20:38:52: | frame preprocessing and rendering - [time: 0.641 ms (cpu time: 0 ms)]
20:38:52: | | scene->Preprocess - [time: 0.007 ms (cpu time: 0 ms)]
20:38:52: | GPU download and color conversion - [time: 43.379 ms (cpu time: 0 ms)]
20:38:52: | | flush - [time: 0.052 ms (cpu time: 0 ms)]
20:38:52: | | CopyResource - [time: 43.301 ms (cpu time: 0 ms)]
20:38:52: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
20:38:52: | Convert444Threads - [time: 44.078 ms (cpu time: 0 ms)]
20:38:52: encoder thread frame - [time: 1.092 ms (cpu time: 0 ms)]
20:38:52:
20:38:52:
20:38:52: video thread frame - [time: 42.925 ms (cpu time: 0 ms)]
20:38:52: | frame preprocessing and rendering - [time: 0.886 ms (cpu time: 0 ms)]
20:38:52: | | scene->Preprocess - [time: 0.008 ms (cpu time: 0 ms)]
20:38:52: | GPU download and color conversion - [time: 42.034 ms (cpu time: 0 ms)]
20:38:52: | | flush - [time: 0.048 ms (cpu time: 0 ms)]
20:38:52: | | CopyResource - [time: 41.959 ms (cpu time: 0 ms)]
20:38:52: | | conversion to 4:2:0 - [time: 0.01 ms (cpu time: 0 ms)]
20:38:52: | Convert444Threads - [time: 42.988 ms (cpu time: 0 ms)]
20:38:52: encoder thread frame - [time: 1.916 ms (cpu time: 0 ms)]
20:38:52:
20:38:52:
20:38:52: video thread frame - [time: 45.015 ms (cpu time: 0 ms)]
20:38:52: | frame preprocessing and rendering - [time: 0.715 ms (cpu time: 0 ms)]
20:38:52: | | scene->Preprocess - [time: 0.004 ms (cpu time: 0 ms)]
20:38:52: | GPU download and color conversion - [time: 44.297 ms (cpu time: 0 ms)]
20:38:52: | | flush - [time: 0.075 ms (cpu time: 0 ms)]
20:38:52: | | CopyResource - [time: 44.195 ms (cpu time: 0 ms)]
20:38:52: | Convert444Threads - [time: 45.052 ms (cpu time: 0 ms)]
20:38:52: encoder thread frame - [time: 1.085 ms (cpu time: 0 ms)]
20:38:52:
20:38:52:
20:38:52: video thread frame - [time: 70.14 ms (cpu time: 0 ms)]
20:38:52: | frame preprocessing and rendering - [time: 1.046 ms (cpu time: 0 ms)]
20:38:52: | GPU download and color conversion - [time: 69.091 ms (cpu time: 0 ms)]
20:38:52: | | flush - [time: 0.119 ms (cpu time: 0 ms)]
20:38:52: | | CopyResource - [time: 68.942 ms (cpu time: 0 ms)]
20:38:52: | Convert444Threads - [time: 70.205 ms (cpu time: 0 ms)]
20:38:52: encoder thread frame - [time: 1.258 ms (cpu time: 0 ms)]
20:38:52:
20:38:52:
20:38:52: video thread frame - [time: 56.505 ms (cpu time: 0 ms)]
20:38:52: | frame preprocessing and rendering - [time: 1.085 ms (cpu time: 0 ms)]
20:38:52: | | scene->Preprocess - [time: 0.585 ms (cpu time: 0 ms)]
20:38:52: | GPU download and color conversion - [time: 55.416 ms (cpu time: 0 ms)]
20:38:52: | | flush - [time: 0.188 ms (cpu time: 0 ms)]
20:38:52: | | CopyResource - [time: 54.533 ms (cpu time: 0 ms)]
20:38:52: | | conversion to 4:2:0 - [time: 0.675 ms (cpu time: 0 ms)]
20:38:52: | Convert444Threads - [time: 56.182 ms (cpu time: 0 ms)]
20:38:52: encoder thread frame - [time: 1.767 ms (cpu time: 0 ms)]
20:38:52:
20:38:53:
20:38:53: Profiler result for the last frame:
20:38:53: ==============================================================
20:38:53: video thread frame - [time: 42.376 ms (cpu time: 0 ms)]
20:38:53: | frame preprocessing and rendering - [time: 0.467 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.004 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 41.904 ms (cpu time: 0 ms)]
20:38:53: | | flush - [time: 0.078 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 41.798 ms (cpu time: 0 ms)]
20:38:53: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 43.524 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 0.998 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 43.754 ms (cpu time: 0 ms)]
20:38:53: | frame preprocessing and rendering - [time: 1.511 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.933 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 42.24 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 42.135 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 43.738 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 1.283 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 43.154 ms (cpu time: 15.601 ms)]
20:38:53: | frame preprocessing and rendering - [time: 1.157 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.005 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 41.991 ms (cpu time: 15.601 ms)]
20:38:53: | | flush - [time: 0.047 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 41.917 ms (cpu time: 15.601 ms)]
20:38:53: | | conversion to 4:2:0 - [time: 0.01 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 43.197 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 1.012 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 36.285 ms (cpu time: 15.6 ms)]
20:38:53: | frame preprocessing and rendering - [time: 0.616 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 35.666 ms (cpu time: 15.6 ms)]
20:38:53: | | flush - [time: 0.057 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 35.581 ms (cpu time: 15.6 ms)]
20:38:53: | Convert444Threads - [time: 36.275 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 0.987 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 43.962 ms (cpu time: 0 ms)]
20:38:53: | frame preprocessing and rendering - [time: 0.809 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.01 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 43.149 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 43.078 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 44.044 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 1.462 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 44.212 ms (cpu time: 0 ms)]
20:38:53: | frame preprocessing and rendering - [time: 0.889 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.009 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 43.319 ms (cpu time: 0 ms)]
20:38:53: | | flush - [time: 0.075 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 43.212 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 44.221 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 1.153 ms (cpu time: 0 ms)]
20:38:53:
20:38:53:
20:38:53: video thread frame - [time: 49.262 ms (cpu time: 0 ms)]
20:38:53: | frame preprocessing and rendering - [time: 1.23 ms (cpu time: 0 ms)]
20:38:53: | | scene->Preprocess - [time: 0.006 ms (cpu time: 0 ms)]
20:38:53: | GPU download and color conversion - [time: 48.025 ms (cpu time: 0 ms)]
20:38:53: | | flush - [time: 0.039 ms (cpu time: 0 ms)]
20:38:53: | | CopyResource - [time: 47.961 ms (cpu time: 0 ms)]
20:38:53: | Convert444Threads - [time: 49.527 ms (cpu time: 0 ms)]
20:38:53: encoder thread frame - [time: 1.022 ms (cpu time: 0 ms)]
20:38:53:
20:38:54:
20:38:54: Profiler result for the last frame:
20:38:54: ==============================================================
20:38:54: video thread frame - [time: 14.254 ms (cpu time: 0 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.707 ms (cpu time: 0 ms)]
20:38:54: | | scene->Preprocess - [time: 0.005 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 13.545 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.056 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 13.458 ms (cpu time: 0 ms)]
20:38:54: | | conversion to 4:2:0 - [time: 0.01 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 14.491 ms (cpu time: 0 ms)]
20:38:54: encoder thread frame - [time: 1.334 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 45.231 ms (cpu time: 0 ms)]
20:38:54: | frame preprocessing and rendering - [time: 2.361 ms (cpu time: 0 ms)]
20:38:54: | | scene->Preprocess - [time: 1.047 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 42.862 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.082 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 42.74 ms (cpu time: 0 ms)]
20:38:54: | | conversion to 4:2:0 - [time: 0.016 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 45.243 ms (cpu time: 0 ms)]
20:38:54: encoder thread frame - [time: 0.967 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 43.056 ms (cpu time: 0 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.731 ms (cpu time: 0 ms)]
20:38:54: | | scene->Preprocess - [time: 0.007 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 42.321 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.059 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 42.235 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 43.149 ms (cpu time: 0 ms)]
20:38:54: encoder thread frame - [time: 0.98 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 43.346 ms (cpu time: 15.601 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.553 ms (cpu time: 0 ms)]
20:38:54: | | scene->Preprocess - [time: 0.004 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 42.79 ms (cpu time: 15.601 ms)]
20:38:54: | | flush - [time: 0.096 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 42.665 ms (cpu time: 15.601 ms)]
20:38:54: | | conversion to 4:2:0 - [time: 0.009 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 43.308 ms (cpu time: 0 ms)]
20:38:54: encoder thread frame - [time: 1.318 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 44.475 ms (cpu time: 15.6 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.638 ms (cpu time: 15.6 ms)]
20:38:54: | | scene->Preprocess - [time: 0.006 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 43.833 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.11 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 43.698 ms (cpu time: 0 ms)]
20:38:54: | | conversion to 4:2:0 - [time: 0.008 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 44.42 ms (cpu time: 15.6 ms)]
20:38:54: encoder thread frame - [time: 0.981 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 48.736 ms (cpu time: 15.6 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.76 ms (cpu time: 15.6 ms)]
20:38:54: | GPU download and color conversion - [time: 47.971 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.051 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 47.882 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 48.826 ms (cpu time: 0 ms)]
20:38:54: encoder thread frame - [time: 1.532 ms (cpu time: 0 ms)]
20:38:54:
20:38:54:
20:38:54: video thread frame - [time: 5.349 ms (cpu time: 0 ms)]
20:38:54: | frame preprocessing and rendering - [time: 0.624 ms (cpu time: 0 ms)]
20:38:54: | GPU download and color conversion - [time: 4.722 ms (cpu time: 0 ms)]
20:38:54: | | flush - [time: 0.045 ms (cpu time: 0 ms)]
20:38:54: | | CopyResource - [time: 4.651 ms (cpu time: 0 ms)]
20:38:54: | Convert444Threads - [time: 5.701 ms (cpu time: 0 ms)]
20:38:54:
20:39:31: Total frames encoded: 1674, total frames duplicated 116 (6.93%)
20:39:31: Total frames rendered: 1613, number of late frames: 66 (4.09%) (it's okay for some frames to be late)
20:39:31:
20:39:31: Profiler results:
20:39:31:
20:39:31: ==============================================================
20:39:31: video thread frame - [100%] [avg time: 19.013 ms (cpu time: avg 2.911 ms, total 4695.63 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0736%]
20:39:31: | frame preprocessing and rendering - [8.65%] [avg time: 1.645 ms (cpu time: avg 0.783 ms, total 1263.61 ms)] [avg calls per frame: 1] [children: 0.752%] [unaccounted: 7.9%]
20:39:31: | | scene->Preprocess - [0.752%] [avg time: 0.143 ms (cpu time: avg 0.077 ms, total 124.8 ms)] [avg calls per frame: 1]
20:39:31: | GPU download and color conversion - [91.3%] [avg time: 17.354 ms (cpu time: avg 2.118 ms, total 3416.42 ms)] [avg calls per frame: 1] [children: 91.2%] [unaccounted: 0.116%]
20:39:31: | | flush - [0.363%] [avg time: 0.069 ms (cpu time: avg 0.077 ms, total 124.801 ms)] [avg calls per frame: 1]
20:39:31: | | CopyResource - [90.7%] [avg time: 17.238 ms (cpu time: avg 2.011 ms, total 3244.82 ms)] [avg calls per frame: 1]
20:39:31: | | conversion to 4:2:0 - [0.131%] [avg time: 0.025 ms (cpu time: avg 0.009 ms, total 15.601 ms)] [avg calls per frame: 1]
20:39:31: | Convert444Threads - [364%] [avg time: 69.187 ms (cpu time: avg 0.967 ms, total 1560.01 ms)] [avg calls per frame: 2]
20:39:31: encoder thread frame - [100%] [avg time: 1.215 ms (cpu time: avg 0.779 ms, total 1294.81 ms)] [avg calls per frame: 1]
20:39:31:
20:39:31: =====Stream End: 2013-09-11, 20:39:31=================================================
20:39:32: =====Stream Start: 2013-09-11, 20:39:32===============================================
20:39:32:   Multithreaded optimizations: On
20:39:32:   Base resolution: 1920x1080
20:39:32:   Output resolution: 852x480
20:39:32: ------------------------------------------
20:39:32: Loading up D3D10 on NVIDIA GeForce 9600 GSO...
20:39:32: Audio Format: 48000hz
20:39:32: Playback device Default
20:39:32: Using desktop audio input: Högtalare (Realtek High Definition Audio)
20:39:32: Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
20:39:32: Audio Encoding: AAC
20:39:32:     bitrate: 128
20:39:32:     device: Live! Cam Video IM,
20:39:32:     device id \\?\usb#vid_041e&pid_4053#5&2730ab6&0&2#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{15d4a66e-1bd0-40f9-bb23-99519f478dce},
20:39:32:     chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-1000000, fourCC: 'YUY2'
20:39:32:     audio device: (null),
20:39:32:     audio device id (null),
20:39:32:
20:39:32: Using directshow input
20:39:32: Using graphics capture
20:39:34: ------------------------------------------
20:39:34: Video Encoding: x264
20:39:34:     fps: 30
20:39:34:     width: 852, height: 480
20:39:34:     preset: veryfast
20:39:34:     CBR: yes
20:39:34:     CFR: yes
20:39:34:     max bitrate: 950
20:39:34:     buffer size: 950
20:39:34: MMDeviceAudioSource: Frequency for device 'Högtalare (Realtek High Definition Audio)' is 384000, samples per sec is 48000
20:39:34: MMDeviceAudioSource: Frequency for device 'Mikrofon (Realtek High Definition Audio)' is 352800, samples per sec is 44100
20:39:34: SharedTexCapture hooked
20:39:35: Using RTMP service: Twitch / Justin.tv
20:39:35:   Server selection: rtmp://live-fra.justin.tv/app
20:39:35:   Interface: Marvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller (ethernet, 1000 mbps)
20:39:37: SO_SNDBUF was at 8192
20:39:37: SO_SNDBUF is now 65536
20:46:33: Total frames encoded: 12568, total frames duplicated 345 (2.75%)
20:46:33: Total frames rendered: 12537, number of late frames: 37 (0.30%) (it's okay for some frames to be late)
20:46:33: RTMPPublisher::SocketLoop: Graceful loop exit
20:46:34: Number of times waited to send: 0, Waited for a total of 0 bytes
20:46:34: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:46:34:
20:46:34: Profiler results:
20:46:34:
20:46:34: ==============================================================
20:46:34: video thread frame - [100%] [avg time: 12.96 ms (cpu time: avg 2.028 ms, total 25428.2 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0849%]
20:46:34: | frame preprocessing and rendering - [4.06%] [avg time: 0.526 ms (cpu time: avg 0.251 ms, total 3151.22 ms)] [avg calls per frame: 1] [children: 1.01%] [unaccounted: 3.05%]
20:46:34: | | scene->Preprocess - [1.01%] [avg time: 0.131 ms (cpu time: avg 0.085 ms, total 1076.41 ms)] [avg calls per frame: 1]
20:46:34: | GPU download and color conversion - [95.9%] [avg time: 12.423 ms (cpu time: avg 1.775 ms, total 22261.3 ms)] [avg calls per frame: 1] [children: 95.5%] [unaccounted: 0.394%]
20:46:34: | | flush - [0.448%] [avg time: 0.058 ms (cpu time: avg 0.058 ms, total 733.204 ms)] [avg calls per frame: 1]
20:46:34: | | CopyResource - [94.9%] [avg time: 12.303 ms (cpu time: avg 1.679 ms, total 21060.1 ms)] [avg calls per frame: 1]
20:46:34: | | conversion to 4:2:0 - [0.0849%] [avg time: 0.011 ms (cpu time: avg 0.013 ms, total 171.601 ms)] [avg calls per frame: 1]
20:46:34: | Convert444Threads - [516%] [avg time: 66.825 ms (cpu time: avg 1.216 ms, total 15256.9 ms)] [avg calls per frame: 2]
20:46:34: encoder thread frame - [100%] [avg time: 1.329 ms (cpu time: avg 0.938 ms, total 11778.1 ms)] [avg calls per frame: 1]
20:46:34:
20:46:34: =====Stream End: 2013-09-11, 20:46:34=================================================
2013-09-11, 20:38:34: we're booting up:
20:38:34: D3D9 Present
20:38:34: DXGI Present
20:38:34: (half life scientist) everything..  seems to be in order
20:38:34: D3D9EndScene called
20:38:34: D3DPRESENT_PARAMETERS {
20:38:34: 	BackBufferWidth: 1157
20:38:34: 	BackBufferHeight: 651
20:38:34: 	BackBufferFormat: D3DFMT_A8R8G8B8
20:38:34: 	BackBufferCount: 1
20:38:34: 	MultiSampleType: D3DMULTISAMPLE_NONE
20:38:34: 	MultiSampleQuality: 0
20:38:34: 	SwapEffect: D3DSWAPEFFECT_COPY
20:38:34: 	hDeviceWindow: 2229112
20:38:34: 	Windowed: true
20:38:34: 	EnableAutoDepthStencil: false
20:38:34: 	AutoDepthStencilFormat: D3DFMT_UNKNOWN
20:38:34: 	Flags: D3DPRESENTFLAG_LOCKABLE_BACKBUFFER
20:38:34: 	FullScreen_RefreshRateInHz: 0
20:38:34: 	PresentationInterval: 2147483648
20:38:34: };
20:38:34: successfully set up d3d9 hooks
20:38:34: D3D9Present called
20:38:34: DoD3D9GPUHook: success
20:38:34: D3DSURFACE_DESC {
20:38:34: 	Format: D3DFMT_A8R8G8B8
20:38:34: 	Type: D3DRTYPE_SURFACE
20:38:34: 	Usage: D3DUSAGE_RENDERTARGET
20:38:34: 	Pool: D3DPOOL_DEFAULT
20:38:34: 	Width: 1157
20:38:34: 	Height: 651
20:38:34: };
20:38:34: successfully capturing d3d9 frames via GPU
20:39:31: ---------------------- Cleared D3D9 Capture ----------------------
20:39:31: D3D9EndScene called
20:39:31: D3D9Present called
20:39:34: received restart event, capturing
20:39:34: DoD3D9GPUHook: success
20:39:34: D3DSURFACE_DESC {
20:39:34: 	Format: D3DFMT_A8R8G8B8
20:39:34: 	Type: D3DRTYPE_SURFACE
20:39:34: 	Usage: D3DUSAGE_RENDERTARGET
20:39:34: 	Pool: D3DPOOL_DEFAULT
20:39:34: 	MultiSampleType: D3DMULTISAMPLE_NONE
20:39:34: 	MultiSampleQuality: 0
20:39:34: 	Width: 1157
20:39:34: 	Height: 651
20:39:34: };
20:39:34: successfully capturing d3d9 frames via GPU
20:46:33: ---------------------- Cleared D3D9 Capture ----------------------
20:46:33: D3D9EndScene called
20:46:33: D3D9Present called
Lain
Forum Admin
Lain
Forum Moderator
Developer
Yea, that's what I thought it was. The mic sync hack helps with this certain situation. Ngh, very annoying, I am partly to blame for this due to not-so-great audio code, but it's a workaround for the time being until the audio code is thoroughly redone (which it needs to be)
