Hello, since I updated the program to the latest version when I capture the screen while recording the selection rectangle remains around the screen, I wanted to ask how it could be removed. Thanks in advance
Are you referring to the red outline for showing in the preview window of OBS? If so, just lock the source. If you are referring to the yellow outline on the screen you are capturing -- that is there as an indicator to show what is being captured, it doesn't show up in recordings.
If you are referring to the yellow outline when capturing a display capture, there is no option to remove it. It's only there as a visual indicator for what is being captured when the display capture source is active, it does not show up on recordings or streams.
