Scene Window Focus after ransition button used - and No Audio Monitoring default for "Monitor & Output"
Eroka
Hi,
I am sure this is super stupid - but I have not been able to find any help for these two really annoying issues:
1. Focus issue in the scene window (bottom left) once a clip is playing
Here is the scenario: I play a scene (windows 10, in multi view - this is going into a zoom event) by selecting the scene in the scene window and then selecting Transition.
At that moment the focus on the current scene switches - but instead of going to the next scene (or even remaining on the scene being played) - the focus switches to the LAST scene played before the current one (not necessarily th one above the current scene - just the last one played). This means I need to go and select the next one in the queue all the time.
WHY and how can I change this? I just want it to switch focus to the NEXT one in the queue.
Why is this the default behaviour anyway?
2. Every time I add a new source with sound I cannot hear it (or stream it) unless I select in the Audio Mixed the gear button of that track, right click, select Advanced Audio Properties - and then in the "Audio Monitoring" select "Monitor and Output". WHY?! Can this be set toa default behavior so that any source with sound is added with that set to these settings? It is so unclear why this is the behaviour - and is causes lots of confusion.
If someone can assist me with these two really annoying basic functions - That would be very much apprecatied!
Eroka
