Hello I am building a raspberry pi4 B based streaming station for streaming some art on twitch and youtube. This is just part of the overall stream environment, I will be using the PI HQ cam with a c-mount lens on the pi 4 then ouputting that camera feed from the OBS instance on the Pi to the OBS instance on my desktop PC using the NDI plugin.
However I have run into a bit of a snag... The stream will be in 1600x900 at 6mbps bitrate (max for non-partnered twitch streaming), however the little 5in touch screen I am using as the "viewfinder" for the pi 4 rig is only 800x480. I went ahead and set the canvas and output to 1600x900 (although I also tried the native resolution of 800x480 for both) this doesnt seem to change the interface size which is good, I dont want it to change with the canvas size as I need that to be 1600x900 anyway). But even set to the native res the interface is outside the bounds of the screen cutting off important controls in OBS.
TL;DR Is it possible to force the OBS interface to display within the bounds of a 800x480 display while still outputting video at 1600x900?
