NabbyLloyd
So I used to have an old monitor that had a sort of square shape, but then I changed to a new one which I'm currently using. However OBS still uses the resolution of the old monitor, which means that there's black bars when I try to fit the recording into the frame. Is there a way to fix this? Thanks!
Here's a log incase that's important: https://hastebin.com/uwehajokar
