Random sound problems when OBS is turned on!
adzidoz
Hey!
As in the topic name.
I turn on OBS + stream.
For the first hour of transmission is good, sometimes I hear some slight sound cuts but it works tolerably.
After an hour or so the problem starts, I can hear some noise, it sounds like I've partially disconnected my headphones (or they are not fully connected). The audience doesn't hear it, but it bothers me, because music from e.g. songrequest is unlistenable.
Recently it has started to happen quite randomly. I haven't even updated OBS... I have 3 AUDIO tracks, one for songrequest, second for general sound, third for discord.
Any ideas?
cyclemat
did you use the monitoring in obs please post an obs log !
other idea is make it with voicemeter
adzidoz
Problem solved.
Reinstalled Virutal Audio Cable, everything again in OBS from start with mics, audio etc. and its finally good. Idk, looks like VAC bugged smth.
