This works. -The relevant line wasn't at 000b86e0. I just searched for "IsWow64Process" and found it that way. Then changed 32 to 00 and saved. OBS started properly after that. (I'm also one of those who runs a locked down Windows 10. -During a recording session, you simply can't have anybody, especially not Redmond, randomly taxing your computer resources. I froze Windows 10 at version 1703 and it's great! Photoshop works properly with a stylus in that version.)I found a solution.
1. Install any hex editor.
2. Make a copy of (for safety) ....\obs-studio\bin\64bit\obs.dll and name obs_bkp.dll
3. open the file obs.dll in hex-editor.
4. Search for "IsWow64Process2" (search as ASCII, case sensitive)
5. Select the number 2 in IsWow64Process2 and replace it hex 32 with 00
6. Save the obs.dll file
OBS started, but I can't guarantee that everything works.
I have not tested all functions. I only found a solution to get OBS to start.
I am asking the OBS community to look into this issue.
Sure, what already works won't break when you stop updating, but those who study the updates get a pretty good roadmap for how to break into it.I froze Windows 10 at version 1703 and it's great! Photoshop works properly with a stylus in that version.)
I don't agree, not at all. Very strongly disagree.There's nothing wrong with using outdated systems
Fun fact....This thread is the perfect example for this. A horrible workaround that makes you spend time and actually breaks stuff, because patching obs makes its digital signature invalid.
Life savior! Tested it with the latest version OBS-Studio-31.0.3-Windows and it works.I found a solution.
